| Haspin Acres Rally 2021 - 6/23/21 to 6/27/21 | |
+10Rustbucket Garage Budget_gokart murphyslaw Hillbilly Offroading redzz02 Creepycrawler CraftsmanQuad19 Doug MightyRaze TheRainbowBoxer 14 posters |
Age : 21 Join date : 2020-12-23 Points : 2302 Posts : 785 Location : Roachdale IN
| Subject: Re: Haspin Acres Rally 2021 - 6/23/21 to 6/27/21 June 16th 2021, 9:33 pm | |
| Two of my tractors blew belts about a couple minutes ago. And my murray needs a new belt and the pully is comepletly crunchy and became part of the transmission i also dont have any money to buy parts i hope i make it | |
Join date : 2021-01-15 Points : 2879 Posts : 1340 Location : Upstate New York
| Subject: Re: Haspin Acres Rally 2021 - 6/23/21 to 6/27/21 June 16th 2021, 10:55 pm | |
| - Budget_gokart wrote:
- Two of my tractors blew belts about a couple minutes ago. And my murray needs a new belt and the pully is comepletly crunchy and became part of the transmission i also dont have any money to buy parts i hope i make it
Speaking from experience- unless there is an obvious cause for a destroyed belt then check all pulleys for dents or misalignments...ask me how I know. You can get belts cheaper on amazon too if you are in a pinch financially. I’m in that same boat. | |
| Subject: Re: Haspin Acres Rally 2021 - 6/23/21 to 6/27/21 June 19th 2021, 8:32 pm | |
| - CraftsmanQuad19 wrote:
- My tractor is ready, lukes MTD is 99% ready, and I’ll probably run through my buddys murray and get it ready next weekend or sometime this week. Looking to show up with three trail-ready tractors
Ok...I know what I said...one of my buddies just for sure dropped out. So I’m only bringing two trail ready tractors. | |
| Subject: Re: Haspin Acres Rally 2021 - 6/23/21 to 6/27/21 June 20th 2021, 11:10 pm | |
You can get belts cheaper on amazon too if you are in a pinch financially. I’m in that same boat. I know the belts are slightly off on both swaps one worse then the other but so far the belts are lasting for enough driving time im sure it will make it to haspin and back and still be runnable the front belt on the mower im gonna ride needed relaced because it was the origional belt to the tractor and it was bad. It has a rear pully swap. Also my murray we had to weld the the imput shaft gear on because the shaft chipped in the mst206 and also we welded a pully to the hub that was left on the imput because it was siezed on so badly its part of the shaft now | |
Frankenstein06 New Member
Age : 23 Join date : 2018-05-05 Points : 2390 Posts : 3
| Subject: Re: Haspin Acres Rally 2021 - 6/23/21 to 6/27/21 June 21st 2021, 10:59 am | |
| I’ll be out Wednesday after I get off work. I should get there at like 10:30-11. I’m super excited to go, Cooter and I took the tractors all around town to make sure they were running right, and I somehow lost one of the two bolts that hold my hood on...will need to get a new one before I head out so I don’t throw the hood off miraculously. I have to leave Saturday morning to go to a wedding though | |
| Subject: Re: Haspin Acres Rally 2021 - 6/23/21 to 6/27/21 June 27th 2021, 11:33 am | |
| My mower blew a valve spring retainer broke the front hood mounts the bolts came out of the fascia and my bumper broke off. i got it back to my grandpas and we heavily welded the bumper better then ever and fixed the valve spring retainer now it is ready for upgrades to go back to haspin | |
| Subject: Re: Haspin Acres Rally 2021 - 6/23/21 to 6/27/21 June 28th 2021, 5:34 pm | |
| Mine does, but I had to fix the front end enough times I ran through all the spare parts I brought. Wheel bearings, kingpins (separate from the spindle on mine), heck I even had to weld the wheels back together. Was a fun time though, and I’ve got a couple ideas to make the parts that broke stronger | |
