| [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] | |
+18Murraymountain prancstaman TheRainbowBoxer diddie mr.modified Stretch44875 redzz02 Double W Cross Ranch muddstir AllisKidD21 Hillbilly Offroading Crazy_Carl mowerjunkie03 MatthewD TheBeal SebastianAlbrecht MightyRaze CraftsmanQuad19 22 posters |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] Mon 11 Nov - 20:14 | |
| What engine does the one you’re talking about have? If it’s an oppy I’m interested. This one was actually too low because it originally had a single in it. The ones with the oppy are actually slightly taller. I just recently learned that.
The hood that was on it sat really close to the flywheel and hit the front of the shroud, poor engine barely had any airflow.
Got the frame cleaned off but I can’t find my spray paint anywhere and now the mk2 is sitting under about 3 inches of snow. So still no paint. Hopefully I can just kick grandma out of the garage for a bit so I can warm it enough to paint. First things first is fixing the ranger. This bmw is absolutely horrible in the snow (who woulda thought), smacked a curb pretty good on the way home today | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] Mon 11 Nov - 20:35 | |
| Ouch. The roads are bad here too now, gotta be real careful. I actually put the poor ol' Geekuinox right down in a ditch today coming back into town. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] Mon 11 Nov - 20:46 | |
| Yeah man I made the mistake of driving home right through Purdue’s campus. Already the worst time of the day to drive, then factor in the weather, ugh. Just horrible. I need contact solution but I’m not going back out in this crap.
I think the only things I’m gonna get done by the buildoff is paint, bolt on the new engine, and shorten the tie rods so I can at least get the alignment to where I can drive it. I think I’m gonna stick with a craftsman hood, just fits the dash and everything better. There’s a mower yard a couple hours from me that has about 1300 tractors, hopefully somewhere in that mess I can get a couple spare 820s and a hood | |
Murraymountain Veteran Member
Join date : 2019-02-04 Points : 4429 Posts : 2178 Location : North Carolina
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] Mon 11 Nov - 20:59 | |
| - CraftsmanQuad19 wrote:
- What engine does the one you’re talking about have? If it’s an oppy I’m interested. This one was actually too low because it originally had a single in it. The ones with the oppy are actually slightly taller. I just recently learned that.
I don't remember. I've yet to find the mower it belonged to (and when I do it will have already been stripped of anything valuable). Next time I go over there I'll just grab it anyway. Also, the one's with the oppys have vents in the top, not the singles... Just another way to tell. | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] Thu 14 Nov - 20:08 | |
- Until it looks good. Or until I run out of paint. Whichever comes first
That sounds like my kind of thinking! Haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 49 Join date : 2016-09-06 Points : 15659 Posts : 10978 Location : Oklahoma
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] Fri 15 Nov - 10:01 | |
That sounds like my kind of thinking! Haha. I was thinking the same thing! Don't want a show piece, he wants a fun piece! Good enough to keep the rust at bay is my way! LOL | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] Sat 16 Nov - 12:42 | |
| New engine somewhat installed. The crankshaft is shorter, had an automotive style dipstick and the oil fill was in the valve cover. So I had to use my old valve cover from the last engine since it had the fitting for the fuel pump, got the dipstick swapped out for the standard mower style, and all the lines to the fuel pump hooked up. Kill wire is hooked up, but the charging system on this is unregulated and the connector is different. Might run a spade connector if I can find one around.
The crankshaft is also shorter, but I think it’s the same diameter so I think I’ll be able to make my pulley work. Really don’t want to have to drive across town to go to TSC for a new one. | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] Sat 16 Nov - 13:20 | |
| I just watched the video. Paint looks nice! Good idea with adding that C-channel... I was worried about those floorboards bending like that. They're made of pretty flimsy steel... Should be much better now.
If you're running the Murray hood, definitely pods, if it's a Craftsman hood, DEFINITELY a light bar. I'd be pretty cool if you could find the original lens too.
I like those front brakes... Making me rethink my new brakes next year. | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] Sat 16 Nov - 13:55 | |
| LOL, I love that $1 Walmart paint. It's wonderful, dries in no time and looks good. Everything black on the MM was painted with that.
I have some ideas for the fenders, but they're pretty hard to explain... New fenders would probably be best. If your ever down this way again I'll probably have the hood and fenders... Just FYI. I'm sure that junkyard you mentioned would have one though. | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] Sat 16 Nov - 22:04 | |
| Great to see she has a heart again! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] Tue 19 Nov - 17:49 | |
| Having an issue with the new engine. Was cranking over fine to start and just locked up. I can turn it with a breaker bar but it’s very stiff. Yes it has oil in it, and I can’t see anything wrong. Any ideas?
I pulled the spark plugs out and they were dry, so it’s not hydrolocked | |
