I shot some sea foam branded penetrating oil in the spark plug holes while I was turning it over, thick stuff like chain lube. Didn’t seem to help much. Really hoping it’s an external issue and I don’t have to open a brand new engine!
I had this happen once. On my onan. Fired and ran fine, then up and seemed to lock up. Turned out a DirtDobber created a nest in the exhaust port. Running the engine loosened it. One start it got sucked into the piston chamber and it seemed locked up, hard to turn over due to debris.
I'd do like redzz02 said.
Flywheel off, zero charging system. Nothing under there. Borescope shows both cylinders are clear. Thinking at this point it’s either valve train or bottom end. Really hoping for valve train
Hey! Still having issue with the engine, didn't you say you could throw in a smaller engine and do the walk around? Don't let an opportunity slide for an engine with a gremlin in it. Heck, the slant single has bragging rights lasting though Haspin!
Haha I have a single that I can make work for a demo video. I prefer not to, but if all else fails that’s my backup plan. Worst case scenario it needs a carb cleaning and a coil
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
It lives!!! Turns out the hub from the crank pulley was pinching the frame between itself and the sump. Next time I pull the engine off I will make that hole larger with the plasma cutter.
Video will be filmed tomorrow afternoon once I get home from work
Quick rundown of the highlights: -brand new Briggs 16 horse vanguard mounted backwards and moved forward -locked peerless 820 -“slap” shifter with neutral lock -atv independent front suspension -reinforced frame -push button start with toggle switch kill -car horns wired to a push button -front drum brakes -cub cadet 1440 steering box -single sidepipe exhaust (2 into 1) -kenda pathfinder tires all the way around
Good luck to all the finishers!
