| [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] | |
+18Murraymountain prancstaman TheRainbowBoxer diddie mr.modified Stretch44875 redzz02 Double W Cross Ranch muddstir AllisKidD21 Hillbilly Offroading Crazy_Carl mowerjunkie03 MatthewD TheBeal SebastianAlbrecht MightyRaze CraftsmanQuad19 22 posters |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] November 19th 2019, 5:49 pm | |
| Having an issue with the new engine. Was cranking over fine to start and just locked up. I can turn it with a breaker bar but it’s very stiff. Yes it has oil in it, and I can’t see anything wrong. Any ideas?
I pulled the spark plugs out and they were dry, so it’s not hydrolocked | |
Age : 49 Join date : 2016-09-06 Points : 15659 Posts : 10978 Location : Oklahoma
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] November 19th 2019, 7:44 pm | |
| No weird noises, oil looks fine. The engine has but 5 minutes of run time on it. Oil is valvoline 5w30.
There’s no play in the flywheel either direction, so it’s almost like the rods are overtorqued. But it didn’t do that from the beginning, and it wasn’t running when it froze. Just cranking like normal and it stopped so suddenly it was almost like it hydrolocked.
I moved the coils away from the flywheel and it’s still tight. The starter can barely budge it with the battery on the jump box, and I tried pushing the clutch in just in case the bind was in the driveline, no luck.
I’m just stumped guys, Am I missing anything obvious? | |
diddie Member
Age : 57 Join date : 2016-10-02 Points : 3427 Posts : 411 Location : Indiana
Murraymountain Veteran Member
Join date : 2019-02-04 Points : 4429 Posts : 2178 Location : North Carolina
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] November 19th 2019, 9:50 pm | |
| Does the engine have a compression release? The MM has a broken one. Makes it harder to turn but the starter can still start it.
No noises when turning it over?
Starter bendix is not engaged when you're turning it over right?
Is it always hard to spin or only in some spots?
Maybe something is dragging underneath it?
Sorry for all the questions, LOL. Just trying to get simple things out of the way first. | |
Age : 37 Join date : 2013-07-02 Points : 5016 Posts : 731 Location : Logan Ohio
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] November 19th 2019, 11:08 pm | |
| Im guessing something under the flywheel, had a couple do what your talking about, one the magnets came apart, another mice or something hid a bunch of dogfood and various nuts and other sh*t like that and part of a walnut shell got wedged up best i could tell, took off the flywheel and cleaned out the junk and it was good to go | |
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] November 19th 2019, 11:14 pm | |
| As creepycrawler and others have stated, check under the fly wheel. I actually got a vanguard for free because it was “locked up” the magnets grenaded under the fly wheel and seized it up, also another thing that has happened to me is the starter gear would stick engaged and it would start binding with the flywheel gear and make it difficult to turn. You should have a charging system on the motor, they usually come with a pull start and no electric starter if it doesn’t have one, hopefully you had enough oil in it and hopefully it was lubed enough from sitting so long, hopefully a ring isn’t seized or something bad | |
mrshaft696 Established Member
Join date : 2016-07-10 Points : 4056 Posts : 870 Location : Phillydelphia
redzz02 Site VIP
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] November 20th 2019, 10:30 am | |
| - CraftsmanQuad19 wrote:
- Pulling the spark plugs out would negate that though right? Unless it’s physically binding?
The whole time I was turning it over with the breaker bar I had the spark plugs out of it it would be a little easier to turn with the plugs out but not much. | |
redzz02 Site VIP
redzz02 Site VIP
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] November 20th 2019, 12:34 pm | |
| - redzz02 wrote:
- Are you sure your oil block off plate is correct? You probably should have oiled up the cylinder walls before starting it, got my fingers crossed no internal damage but if it felt dry inside
If the cylinders were dry, then they're probably scored by now. But if they're scored, I would think it would make some kind of strange noise when turning it over... You'll never know until you pop the heads though. | |
redzz02 Site VIP
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] November 20th 2019, 3:11 pm | |
| @CraftsmanQuad19 I thought you mentioned it was an oem part was just thinking, tear the fly wheel off and both valve covers if you don’t see any issues, cry and pull the heads, if it’s been sitting for 12 years, there is a good chance everything dried out, just because it had oil may not mean everything was lubricated enough to actual fire just yet, best of luck I have my fingers crossed | |
