| [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] | |
+17Murraymountain tater195 diddie muddstir Crazy_Carl RichieRichOverdrive mrshaft696 Hillbilly Homer SebastianAlbrecht MatthewD prancstaman Double W Cross Ranch CraftsmanQuad19 MightyRaze Hillbilly Offroading TheBeal AllisKidD21 21 posters |
| Subject: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 2nd 2019, 12:41 pm | |
| Hi, my name is AllisKidD21 and I have a tractor addictio-..er no, I'm entering the Build-Off! So here's the new victim: Older Craftsman LT11, dubbed the LT-08 due to the different power plant I'm using. Gonna be basically just a speedy rat rod tractor for racing around on, with a lot of ratty touches to make it as authentic as possible. -The engine will be a small block Kohler K Series (K181). A Bolens style clutch will turn a drive shaft going to a Peerless 600 3-speed transaxle. (Tipped up with the pinion shaft facing forwards to accept a drive shaft.) - Tires will be just turfs on the rear, and maybe small trailer tires on the front. (Need to get those still) -Steering with use the stock gears as they are fairly heavy and have no play. All the steering rods will be custom made and have upgraded rod ends. Also the steering rag joint is being replaced with an automotive steering universal joint. -Front axle is still un-decided, but possibly lengthening a Ford LT front axle and making custom spindles. There's a slight chance of having a hot-rod style radius arm and 1/4 elliptic leaf spring setup in the front, but that's still up in the air..... -Brakes will be a go-kart rotor and mechanical caliper. Thinking about doing pinion brakes with these components as opposed to trying to mount them in the stock location. Everything else will be done on a "play it by ear" basis, like all my other builds! Hopefully I did this right, haha. Good luck to everyone who enters! Approved: MightyRaze 2/2/2019 "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5717 Posts : 1402 Location : Central PA
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2853 Posts : 582 Location : Reeses Mill, WV
Age : 20 Join date : 2017-06-09 Points : 5492 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 2nd 2019, 9:41 pm | |
| Thanks a lot everybody!! I saw that I was approved so I decided to go hard at 'er to get a good start. First thing I did was start mocking up the transaxle. I had to cut a big hole to get it lifted up into the frame enough: Then, after a lot of measuring and some fab work, I got some mounts made up to the frame: Great to have that part done. The mounts weren't too hard to make either, most of it was measuring to make sure the trans was straight, centered, level, etc. I do still have to make the upper trans mount, but I just had to throw some old wheels on and see how things looked: I'm liking it so far! Should have a neat stance when the front is all figured out. Did a little engine mock up next: I wanted to try and use the tractor's original fuel tank, and although it's tight, I think it should fit okay. Still a bit of a gap there which is good. I should be able to get to the pull start cup no problem too, so I think all in all this is a good spot for the engine. Then lastly I made up a quick simple shifter: Not sure if I'll keep that or try and make something a bit cooler looking, we'll see. I do have a neat idea for something to go around the shifter hole, so I might just keep it and do that, haha Anyways I'd say we're off to a pretty good start. Next I'll maybe try and start working on the rest of the drivetrain and get the upper trans mount made up. Let me know what ya think!! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 2nd 2019, 10:17 pm | |
| Thanks guys. Yeah it'll be sorta lowered in the end, I woulda went a bit lower, but that would've involed more cutting of the frame than I would like and also would've caused major drive shaft alignment issues. Should still have a fairly mean stance once it's done.
Also yeah, I forgot to mention I'd like to hit 30mph or so with this tractor. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 2nd 2019, 10:29 pm | |
| They're pretty strong ol' gearboxes. This one was swapped into in my rat rod and I ran it in that rig for quite some time. I swapped one into my MTD a couple years ago and it's going strong. Also my little Ford has one one from the factory and it's in great shape as well. They're kinda my favorite, haha.
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 3rd 2019, 3:56 pm | |
| Thanks a lot fellas. Those aren't the tires I'll be using, but the ones I put on will definitely have white walls. The rims will be a different colour as well. Anyhow, I sorta "forgot" to work on the drivetrain today and ended up messing with some other little stuff instead. First I had to try out an idea I had for the shifter cover: Didn't turn out too bad, everyone loves sharp edges after all! Next I figured out where the engine needs to be and drilled two holes just so I could keep it held on place. Then I started messing with some exhaust stuff: It's a start anyways, I still have to finish it. I did fire it up though to see how it sounds and it's not too bad. I didn't run it too long though with only the rear bolts in place. Lastly, I decided to cut the hood for the air cleaner to poke through. Figured I might as well get that part out of the way. Now... I could've just made a nice clean round shape around the air-cleaner, but this is a rat rod after all! Crazy hood cut-out time!! Oh yeah!! Hahaha. Kinda digging how that turned out actually, compliments the shifter cover in a way as well. So yeah, maybe a bit early to be messing with the decorative stuff, but that's okay. Let me know what ya think! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100
Last edited by AllisKidD21 on February 4th 2019, 6:52 pm; edited 1 time in total | |
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 3rd 2019, 4:02 pm | |
| Thanks! Haha, yeah I sure hope I can get the drivetrain and front axle stuff done as quick as these little things. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100
Last edited by AllisKidD21 on February 4th 2019, 8:24 pm; edited 1 time in total | |
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 3rd 2019, 5:05 pm | |
| I'm sorta still thinking about widening that Ford axle, I think that'd work pretty good. I'd really like to try out that suspension setup I have planned as well. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
prancstaman Veteran Member
MatthewD Veteran Member
