 [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]
tater195
diddie
muddstir
Hillbilly Homer
Hillbilly Offroading
21 posters
Go to page : Previous  1 ... 5 ... 7, 8, 9 ... 11 ... 15  Next
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Empty
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeMay 5th 2019, 9:09 pm
Yeah, I know. Been really slacking off with the Build-Off tractor here. Obviously the first drive shaft setup failing sorta threw a wrench into the gears, but I got a plan worked out using another shaft and joints, so I'l have to get around to that sometime soon.
In the meantime I decided to get the steering wheel all hooked up today, so I did do something!
As some of you know, these tractors used a rag joint that went between the steering shaft and the pinion steering gear. Mine was toast when I got this rig so I planned to use an automotive steering universal joint instead:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 20190515
Drilled a couple holes and tapped them to 1/4- 20:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 20190516
Bolted down all nice:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 20190517
Then I cut an old steering shaft to length and cut a square into the end to fit in the universal:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 20190518
Pinch bolt installled:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 20190519
Then BAM! We have steering!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 20190520
Well.. some of the steering anyways, hahaha. Nice to have that part done!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeMay 7th 2019, 12:55 pm
Nice... better implementation than what I did on my first try.  Any slop in the steering you got going on so far?
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Sig115PROJECTS:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Sig214[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Sig314
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeMay 7th 2019, 10:27 pm
Thanks fellas.
Not too much for steering slop that I can tell Mighty. None at all really, which is surprising, but definitely nice! There are a couple replaceable bushing in the setup though, so they can be replaced/upgraded if any play presents itself in the end.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeMay 7th 2019, 10:55 pm
If it is the bushings I am thinking, I am curious how you do it.  hmm
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 1st 2019, 10:49 pm
Well however slowly, progress is still being made here on the Build-Off tractor.
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 20190614
Today I was able to get a coupler and an adapter made in order to get the new drive shaft put in place. The adapter for the rear still needs to be finished, but this is how things are looking so far.
The coupler:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 20190610
The shaft adapter and universal joint.
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 20190611
Couple other pictures:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 20190612
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 20190613
Haven't tested it out yet, but I think it's gonna work alright. Once I get the adapter at the rear all finished, I can fire it up and see how it performs. Hopefully that'll get done tomorrow!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 1st 2019, 11:07 pm
Nice.... hurry up and get the rear finished!  I'm ready for some front suspension magic!  LOL
Really... it looks so cool.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 1st 2019, 11:18 pm
Hahaha, thanks Mighty. Yeah I'm hoping I can move on to that front end setup real soon!!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 2nd 2019, 3:40 am
Nice job on the driveshaft Allis. Might want to loctite all the bolts on the u joints and whatnot, it's unlikely you'll get it perfectly balanced and all vibrations out. Which brings me to my next idea- balancing. You may be able to balance it like a motorcycle wheel if your bearings are easy enough to turn. Or you can just try trial and error adding little weld beads and filing them off to balance it. Just some ideas. Really hope that setup works for you, it's really cool. I think you should paint the driveshaft black and white lengthwise so it looks like it's flashing black and white when it's at speed. Or something like that, lol.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 2nd 2019, 11:07 am
Thanks a lot Rich. The balancing trick might not be a bad idea. I'm not quite as concerned about it with this shaft as I was with the first one, I think this one will be a lot less rotating mass being that it's so much smaller in diameter and what not. It'll be spinning rally fast though so it still might need a bit of balancing, I guess I'll have to wait and see.
Also my pinion angle is pretty well straight, so that should help a lot with vibration as opposed to having a nasty angle.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 2nd 2019, 11:05 pm
Well I didn't get a whole lot done today, but I did manage to finish up the adapter for the trans side of the shaft:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 20190615
Should work well. I have to shorten the pinion shaft on the transaxle before it can be all put together, but after that I should be able to test 'er out!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 2nd 2019, 11:16 pm
Wow, just checked this thread, phenomenal work on that driveshaft!!  This thing is going to be bad @$$!!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 2nd 2019, 11:42 pm
Well thanks! I'm hoping it will be, haha.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 8th 2019, 10:33 pm
Well of course now that the drive shaft progress is going well, I've run into another problem:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 20190624
We've lost spark! Figures eh? Haha.
Gonna try and shine the points up a bit, see if that helps. If not then I can try a new condenser.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 9th 2019, 10:41 am
SebastianAlbrecht wrote:
#pointsignitionsucks LOL
Try to magnetron swap it!
This style engine he can't magnetron swap it because it's a 12v ignition, he would have to change the whole flywheel and then cast his own bearing plate with a coil mount.
He also plans on using the points to implement a timing advance on this engine, something he can't really do on a magnetron ignition.
Points actually run a lot stronger than any other ignition style, and in fact, someday when I get it wired, I plan to put 12v on the 990.  They're much more reliable and they don't lose power with age. I'm already having issues with the brand new coil losing spark when the engine gets too hot.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 9th 2019, 6:53 pm
This engine actually isn't 12v ignition, it's just the old school mag and breaker ignition, like the 10hp Briggs in my B-110 or the 16hp in your MTD.
I did some more messing around today and I'm pretty sure the coil is dead, so I bolted an automotive coil to the block so I can do the 12v ignition swap and run a battery, like I just did with my old Bolens. At least then it can run again.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 9th 2019, 9:22 pm
So why can't you just buy a brand new coil? Has the part been discontinued? Too expensive?
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 9th 2019, 10:11 pm
Yeah unfortunately it's NLA. I think isavetractors.com has them, but I've never really been a fan of having ignition parts under the flywheel. Not very convenient to work on and what not.
Hopefully the 12v conversion goes well, then progress can continue!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 9th 2019, 10:35 pm
Oh gosh! Under the flywheel!? Yeah I'd forget about it too. Good luck!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 9th 2019, 10:50 pm
Sorry to hear about the coil allis. I bet you'll get her running better than ever with the buzz coil though!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 9th 2019, 11:04 pm
Thanks! Haha, yeah that was pretty common with older engines, even my little Homda G200 has the coil, points, and condenser under the flywheel.
Yeah well of course it had to happen right when I really need it to run, I think that's just the rule. lol!
Thanks Rich, I hope so!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 10th 2019, 12:32 am
Guess the bolens was a practice run for the LT-08. Look cooler with an external coil.   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 2731072446
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 10th 2019, 8:46 am
Yeah haha, I guess it sorta would look neat hanging off the side!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 8 Icon_minitimeJune 10th 2019, 9:43 am
Oh yes, that is most definitely the rule!
Page 8 of 15Go to page : Previous  1 ... 5 ... 7, 8, 9 ... 11 ... 15  Next
» [FINALIST] - Father Daughter project 2019 Build Off [2019 Build-Off Entry]
» [FINALIST] - Murraymountain's Mountain Murray [2019 Build-Off Entry]
» [FINALIST] - HondaX4 By Jason Kahler [2019 Build-Off Entry]
» [FINALIST] - mrshaft696's The Real Horse [2019 Build-Off Entry]
» [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2019 Archive :: Finalist Archive-
