| The Murray with Mow name. | |
+8prancstaman RichieRichOverdrive CraftsmanQuad19 MightyRaze TheBeal AllisKidD21 MatthewD Mow Money Mods 12 posters |
Mow Money Mods Member
| Subject: Re: The Murray with Mow name. September 4th 2017, 1:30 am | |
| sounds good, if the hole in the bash pan doesn't line up I can always cut and shut it, have welder will weld, lol, cheers for your input it is all appreciated. have a great day to all. | |
muckmudd Established Member
Age : 21 Join date : 2017-07-11 Points : 3527 Posts : 825 Location : In the shop
| Subject: Re: The Murray with Mow name. September 4th 2017, 1:37 am | |
| I like the build. Nice lights, I am jealous. Those are some pretty big tires for that transmission, what size are they? I would lock it. | |
Age : 45 Join date : 2017-08-16 Points : 2764 Posts : 124 Location : South Australia
| Subject: Re: The Murray with Mow name. September 4th 2017, 6:04 am | |
| Cheers muckmud, the tyres are 24x12x10, they are just what I had on hand, I think the trans will be getting locked solid axle conversion and whatever else gets recommended in between now and then, cheers for your input. | |
| Subject: Re: The Murray with Mow name. September 4th 2017, 11:33 am | |
| - Mow Money Mods wrote:
- Cheers muckmud, the tyres are 24x12x10, they are just what I had on hand, I think the trans will be getting locked solid axle conversion and whatever else gets recommended in between now and then, cheers for your input.
Dang if those look big i picked up some 26 inch tires but no rims. I hope they aren't to big | |
| Subject: Re: The Murray with Mow name. September 4th 2017, 5:32 pm | |
| I had a set of 25's on it before as mock up and were not much different, sizes seem to vary brand to brand also. | |
| Subject: Re: The Murray with Mow name. September 6th 2017, 4:42 pm | |
| - mightyraze wrote:
- Very clean, looks great!
cheers the plan is to have the mods look as factory as possible. | |
Age : 24 Join date : 2016-04-12 Points : 5938 Posts : 2636 Location : Indiana
| Subject: Re: The Murray with Mow name. September 7th 2017, 8:29 am | |
| Looks very clean! With a coat of paint you wont even be able to tell you made any changes without comparing it to another mower | |
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5683 Posts : 1402 Location : Central PA
| Subject: Re: The Murray with Mow name. September 7th 2017, 4:48 pm | |
| - muckmudd wrote:
- Is the gas tank under the seat now?
cheers to all for the comments, the gas tank will be under the seat, but not the original one, I have a 12 litre unit coming, that's around 2.7 gallons, heres hoping it fits in the tunnel, measurements say yes but you never know when buying off the net. | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5062 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: The Murray with Mow name. September 10th 2017, 1:37 am | |
| - prancstaman wrote:
- NICE!! Great job on the fab work.
cheers, getting there slowly, the want to drive it keeps me going, lol | |
| Subject: Re: The Murray with Mow name. September 10th 2017, 6:47 am | |
| return spring added and that's it for the clutch for now. The rest will have to wait until the transaxle is fitted into the new position for belt alignment etc, so on that note we move to the back end. | |
