| The Murray with Mow name. | |
+8prancstaman RichieRichOverdrive CraftsmanQuad19 MightyRaze TheBeal AllisKidD21 MatthewD Mow Money Mods 12 posters |
| Subject: Re: The Murray with Mow name. August 27th 2017, 9:50 am | |
| - CraftsmanQuad19 wrote:
- less stressed to a point. Once you add wide tires and ride it harsh the axle shafts are basically trying to snap the case in half with the forces put on them
I think I can see your point with these lighter transmissions. They wouldn't be up for that. - Mow Money Mods wrote:
- Gday to all, LED headlights showed up in the post last week also, ebay specials, $30 for the pair delivered 120 watts each, the only thing I had to do was pull one apart to reverse the wiring in it so they were a left and right pair as they are actually sold as work lights. They should do the job perfectly by the looks after a bit of cutting and filing on the surround.
Those look great in there. Good fit! | |
Mow Money Mods Member
Age : 45 Join date : 2017-08-16 Points : 2800 Posts : 124 Location : South Australia
Age : 22 Join date : 2016-10-29 Points : 7224 Posts : 4021 Location : Lewisburg, KY
| Subject: Re: The Murray with Mow name. August 27th 2017, 10:59 pm | |
| Looking good! I need a new battery for my Mutt, the old 330cca isn't what it used to be, especially cranking the big 20hp | |
| Subject: Re: The Murray with Mow name. August 29th 2017, 5:51 pm | |
| Looking good. That should be a pretty reliable setup . "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5755 Posts : 1993 Location : Northern Ireland
| Subject: Re: The Murray with Mow name. August 29th 2017, 7:45 pm | |
| cheers it's looking the goods, with that front bar and a winch tucked in it should come up a treat I think. | |
| Subject: Re: The Murray with Mow name. August 29th 2017, 8:49 pm | |
| - MatthewD wrote:
- Cool! Those headlights made er look mean!
It does have a squinty Clint Eastwood look to it. LOL. Excellent on the frame fab up with the front suspension. Also, I think the wheelbase extension looks good with those monster tires! | |
| Subject: Re: The Murray with Mow name. September 3rd 2017, 6:01 pm | |
| I dont think that battery is gonna work, it says "Just for Boats" on it, I wouldnt risk it. Hahaha, no that should work pretty good for ya. On the drain plug idea I'm not sure if that location would weaken the case or not? It would be handy to have it line up with the skidplate though. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: The Murray with Mow name. September 3rd 2017, 6:05 pm | |
| OH NO!!! I was pretty sure it said just for mowers, lol, not to worry as the local battery distributor I can try all sorts before I settle for one. | |
| Subject: Re: The Murray with Mow name. September 3rd 2017, 6:26 pm | |
| yeah, the decision will be made when pulled apart, if done it will be outsourced to a friend who has the ability to weld cast aluminium and a threaded bung will be welded into place not just drilled and tapped.
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5098 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: The Murray with Mow name. September 3rd 2017, 8:14 pm | |
| That place you are pointing to would be where the main gears are. A weld in tab would be good because you are adding metal thickness to that area, in reference to this metal length when taped for the plug will keep the plug away from the gears when tight. Keep in mind that the plug, when you tighten it, part of the plug will be poking inside the case and there needs to be enough room for that. A good spot in that area maybe would be where the small gears would be, in one of the corners of that area. | |
| Subject: Re: The Murray with Mow name. September 4th 2017, 1:30 am | |
| sounds good, if the hole in the bash pan doesn't line up I can always cut and shut it, have welder will weld, lol, cheers for your input it is all appreciated. have a great day to all. | |
