It’s a little late but I want to throw in my entry for the 2024 Build-Off.
I'm building it for the wife and she is a huge Chiefs Fan so it will be named CHIEF
Here is my Entry Form and a picture of what I started with, an old MURRAY.
It was only a 2speed so I am going to add 1 gear to make it a 3sp.
Also a centrifugal clutch so it will act like an automatic for her. Locked MST-203 with Doc Locker 2.0 upgrade to new bearings, all hubs will be 4x4 pattern and paint it Red and Gold Chiefs colors.
Approved -MR 08-17-24
RichieRichOverdrive, JB_4x4 and hadjiikong like this post
Almost finished the brakes, a cheap disc for mini bike off of Amazon and a brass gear I had laying around that I bored out the center to 3/4" and turned a little off the outside. I just need to broach a new keyway for the axle.
Then I ran into a setback. The engine that came on the mower smoked so bad that it was spitting oil out the exhaust, so off it came.
Luckly I had another Briggs Model 31 out of my LT2000 that it freely donated. (I have an OPPY to re-install in the Craftsman).
torgo Member
Age : 56 Join date : 2016-01-10 Points : 3249 Posts : 34 Location : Mapleton, Iowa
No pictures today, but I did get the keyway broached in the disc brake hub I built, mounted the rotor, rear wheel hubs and started modifying the shifter because I lifted the rear end 2" so now it is not a bolt on.
Going to a swap meet tomorrow. Happy Tractor Hunting!!!!
torgo Member
I didn't find much at the swap meet, only picked up some 1.5" 5 on 4.5" wheel spacers for my Sears.
Continued working on the Chief last night.
I got the master cylinder mounted in location and modified part of the old brake rod/pedal to switch the brake from the right side to the left as I plan on mounting gas pedal on the right.
I cut and fabbed a new tab for the brake pedal and then cut a new slot in the fender pan for the brake as it did not have one on the right. (the master cylinder is getting another bolt)
I got the master cylinder off Amazon and it came with a remote reservoir that I need to mount yet. You can also see I have been doing some painting.
I try to do something every night after work as the deadline is fast approaching.
Age : 22 Join date : 2016-10-29 Points : 7151 Posts : 3986 Location : Lewisburg, KY
Probably will have to bench bleed that master cylinder with it upside down like that. Hopefully it won’t give you much trouble. The one i have on mutt did take a good amount of bleeding after i put it on.
Ok, I haven't posted lately but I still have been working on this. Only 60 days to go.
I flipped the brake master cylinder and got it bled out. Had to make a small adjustment on my brake rotor. But brakes seem great. Got some body work mounted and the steering installed.
(as you can see I left the cup holder on for the "hold my beer" moments.
I added one pulley to the drive line, but didn't take a picture of that.
I am working on the foot throttle and when I get that finished I am taking off the build sawhorses and mounting the wheels. Still to go is the kill switch.
The starter is wired to a manual push button so no starter relay. I haven't decide if I am going to hook up a charging system or just go minimalistic.
I need to start thinking of a front and rear bumper/tow hook option.
This picture of the brake caliper is really dark, sorry.
I'm a bit worried the rear tires will be to wide and I may have to shorten the axle length a little.
Love the little tykes look this build has going on, lol.
Must be a pretty heavy duty push button to run the starter, i dont think you would want less than a 50amp rated one, and that’s a conservative guess. I did have one push button off of an old tractor to start a mower, the thing must have had 3/8” lugs and a button an inch around.
That’s the exact push button i had, except mine was probably 60 years old.
Adding to what mighty said,it would be cool to have a “hood” for the button so it is less likely to be accidentally pushed. Sort of a half moon over the top of the button so if something fell on or pushed against it it would hit the little hood before it pushed the button.
