| The Murray with Mow name. | |
+8prancstaman RichieRichOverdrive CraftsmanQuad19 MightyRaze TheBeal AllisKidD21 MatthewD Mow Money Mods 12 posters |
Mow Money Mods Member
Age : 45 Join date : 2017-08-16 Points : 2800 Posts : 124 Location : South Australia
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5755 Posts : 1993 Location : Northern Ireland
| Subject: Re: The Murray with Mow name. August 25th 2017, 7:01 pm | |
| Thanks MatthewD, had it lying around from another project and the more I looked at it the more it screamed "jam me under the murray" lol | |
| Subject: Re: The Murray with Mow name. August 25th 2017, 7:30 pm | |
| Nice! Likin' the suspension, that setup would be great for a fast trail riding machine. What kinda transaxle is underneath it? Looks like the shifter is missing? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5719 Posts : 1402 Location : Central PA
| Subject: Re: The Murray with Mow name. August 25th 2017, 8:23 pm | |
| yeah the shifter was missing when I got it, but will relocate it to the other side being Australian it feels foreign where it is and probably forward a bit too not sure on that yet, the transaxle is a peerless not sure on model etc, will post a pic of it shortly and get some opinions, Cheers TheBeal I was toying with the idea of mid mounting the engine, that decision will be made when I decide what donk I'm running, that's a 12hp single I am trying to source a 18hp oppy twin at the moment, also fitting a larger fuel tank, marine battery, winch, air compressor, alternator, catch can, snorkel, etc etc, so will see if I end up with the room and what happens there. | |
| Subject: Re: The Murray with Mow name. August 25th 2017, 9:14 pm | |
| Sounds like a sweet build plan ya got there! Any ideas for a front bumper? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: The Murray with Mow name. August 25th 2017, 9:55 pm | |
| certainly do, it is looking like the front bumper from the quad will look the goods with a bit of a mod here and there, will get some pics of that up too sitting in place for some opinions on it. As for the speed, I am hoping for a little more speed than torque but really need a little of both, I have made 2 rear pulleys for it so can play with it a little, I have a fair amount of property to cover on it hence the bigger battery and fuel capacity etc. | |
| Subject: Re: The Murray with Mow name. August 25th 2017, 11:47 pm | |
| Cool, i have an old Murray that i plan independent suspension for next year's build. Nice stuff. | |
| Subject: Re: The Murray with Mow name. August 26th 2017, 8:43 am | |
| The shaft next to the steering is the old mower deck drop lever which I have changed the rotation of and will hook up to the tranny brake for a park brake, will have the hydraulic drums on the front and maybe some discs on the rear yet. | |
| Subject: Re: The Murray with Mow name. August 26th 2017, 9:22 am | |
| I like the look of that bumper there, looks pretty mean. The direct steering setup looks pretty good as well! There should be an ID tag on the trans somewhere near the brake caliper I think. But it kinda looks like a Peerless 801 series transaxle to me. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: The Murray with Mow name. August 26th 2017, 6:18 pm | |
| cheers guys, I will certainly use that link today and work out what I have and where to go with it, for sure. | |
| Subject: Re: The Murray with Mow name. August 26th 2017, 7:32 pm | |
| from the looks of things it's a peerless 930, not sure what can be done with it or whether to lock yet, thinking of getting it going and driving it first, with the wider track and increased speed, larger tyres etc etc, I am thinking it might do well enough to leave it alone for now. | |
| Subject: Re: The Murray with Mow name. August 26th 2017, 10:24 pm | |
| With those big wide tires, a Doc locker would probably help the durability. Those separate axle shafts put a lot of strain on the case because they act as levers. | |
| Subject: Re: The Murray with Mow name. August 26th 2017, 10:58 pm | |
| I would have thought the non-locked would be less stressed? I've only been in this game a couple years, so I am still learning! | |
| Subject: Re: The Murray with Mow name. August 26th 2017, 11:29 pm | |
| less stressed to a point. Once you add wide tires and ride it harsh the axle shafts are basically trying to snap the case in half with the forces put on them | |
| Subject: Re: The Murray with Mow name. August 27th 2017, 2:38 am | |
| the case will be built within a frame to add strength and act as a bash guard also with ladder bars going back to the centre of the chassis to the cross member already fitted and will have outer bearings added for additional strength to the outer parts of the shafts. that certainly makes sense in both cases though, one instance it's the gears we are stressing and in the other case it's the shafts, just beef up as much as possible I am finding is the answer to everything, lol
Last edited by Mow Money Mods on August 27th 2017, 7:43 am; edited 1 time in total | |
| Subject: Re: The Murray with Mow name. August 27th 2017, 9:50 am | |
| - CraftsmanQuad19 wrote:
- less stressed to a point. Once you add wide tires and ride it harsh the axle shafts are basically trying to snap the case in half with the forces put on them
I think I can see your point with these lighter transmissions. They wouldn't be up for that. - Mow Money Mods wrote:
- Gday to all, LED headlights showed up in the post last week also, ebay specials, $30 for the pair delivered 120 watts each, the only thing I had to do was pull one apart to reverse the wiring in it so they were a left and right pair as they are actually sold as work lights. They should do the job perfectly by the looks after a bit of cutting and filing on the surround.
Those look great in there. Good fit! | |
