 The Murray with Mow name.
Mow Money Mods
12 posters
Mow Money Mods
The Murray with Mow name. - Page 4 Empty
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeMon 11 Sep 2017, 3:23 pm
not sure if this is where it's final destination will be yet as I am still tossing up some seat suspension options, one of which could need the rear space under the seat yet, in that case the tank will move forward and a filler will be installed in the body of the mower somewhere.
The Murray with Mow name. - Page 4 Sunp0156
The Murray with Mow name. - Page 4 Sunp0154
The Murray with Mow name. - Page 4 Sunp0155
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeMon 11 Sep 2017, 4:09 pm
That's a pretty neat setup with that tank and the electric pump.
Mow Money Mods
Mow Money Mods
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeMon 11 Sep 2017, 5:03 pm
Cheers, should work out well, I have tripled my fuel capacity and still plenty of room left for the compressor and some storage so a very happy camper here.
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeMon 11 Sep 2017, 6:23 pm
That is pretty nifty! I was looking at those a while back and wished they had a stand up version and I would have put it on my tractor Red.
The Murray with Mow name. - Page 4 Sig115PROJECTS:
The Murray with Mow name. - Page 4 Sig214The Murray with Mow name. - Page 4 Sig314
Mow Money Mods
Mow Money Mods
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeTue 12 Sep 2017, 8:02 am
So after some thinking I ended up moving the fuel tank forward as far as possible to free up the rear under seat area and spun it 180 degrees so the fuel outlet is closer to the engine, following pics are of fabrication and installation of the tank and filler.
first I made an aluminium strap to go over the centre of the tank from end to end, and made fixing points on the mower to accommodate.
The Murray with Mow name. - Page 4 Sunp0210
then I scored these two BFP parts from the local hardware store to make the filler neck, however I only ended up using the one on the left,
The Murray with Mow name. - Page 4 Sunp0160
which I was lucky enough to have screw straight into the original filler opening on the tank.
The Murray with Mow name. - Page 4 Sunp0157
I also added a rubber washer in between the tank and the fitting to seal and allow it to tighten enough.
The Murray with Mow name. - Page 4 Sunp0158
Mow Money Mods
Mow Money Mods
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeTue 12 Sep 2017, 8:07 am
next up was to do more massaging on the bodywork.
The Murray with Mow name. - Page 4 Sunp0161
The Murray with Mow name. - Page 4 Sunp0162
The Murray with Mow name. - Page 4 Sunp0211
The Murray with Mow name. - Page 4 Sunp0212
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeTue 12 Sep 2017, 8:12 am
This is turning out to be quite the machine! Very nice work! What kind of speed are you aiming for exactly? Should do pretty well at speed with the front end you have The Murray with Mow name. - Page 4 2731072446 The Murray with Mow name. - Page 4 2731072446 The Murray with Mow name. - Page 4 102878487
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeTue 12 Sep 2017, 8:35 am
The Murray with Mow name. - Page 4 DEw1z6VV0AEkCLC
Man your fab skills are awesome! I really like the new placement of the tank. Should be good center of gravity when it is full.
Mow Money Mods
Mow Money Mods
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeTue 12 Sep 2017, 8:52 am
Cheers CraftsmanQuad19 I am hoping for a bit of speed as the distances I have to cover on it are quite a way, 1000's of acres to play on, but that said I don't want too much top end and not have enough for the hard yards like towing a small trailer of camping gear etc. I can tell you I have modified the transaxle pulley and is now a 5 inch and the engine pulley I have made is a 5 1/2 inch, not sure what that will get me as this is my first play with modding mowers but should be good for a start I thought.
Last edited by Mow Money Mods on Tue 12 Sep 2017, 9:01 am; edited 2 times in total
Mow Money Mods
Mow Money Mods
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeTue 12 Sep 2017, 8:56 am
haha good old Waynes world, gotta love em, cheers I thought the tank would fair better their for weight also it frees up the rear for my seat idea I am thinking of, not 100% yet but I know what I want just a matter of finding the right parts now.
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeTue 12 Sep 2017, 10:25 am
That should net you about 20 mph. Mine is 4 inch rear and 4.75 inch front and does alright. 1st gear is still nice and torquey and 6th has enough top end for the streets. Also, if you don't do your seat suspension idea, the back end of that tunnel will make a great storage space
Mow Money Mods
Mow Money Mods
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeTue 12 Sep 2017, 4:44 pm
20 mph I can live with that, should be a good place to start, all I know is it had to be faster than mowing lawns, lol, storage options are running through my head also, might have a little bit of a plan for a couple of small ammo box mounts.
Mow Money Mods
Mow Money Mods
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeWed 13 Sep 2017, 7:39 am
so after mentioning my idea about the ammo boxes I dug one out of the shed and had a play, reckon it should work out good looking at it. So out with the grinder and let the fun begin, stay tuned for some mudguard mounted mower storage madness.
The Murray with Mow name. - Page 4 Sunp0216
The Murray with Mow name. - Page 4 Sunp0213
The Murray with Mow name. - Page 4 Sunp0214
The Murray with Mow name. - Page 4 Sunp0215
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeWed 13 Sep 2017, 8:49 am
Next post by Mow Money Mods on "The Murray with Mow Name", will Mow Money Mods get his mudguard mower storage madness!  Or... Will his grinder throw too many sparks and catch his shirt on fire?  Stay tuned.... next time on "The Murray with Mow Name"!
sorry... in a wierd mood!  LOL.
Mow Money Mods
Mow Money Mods
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeSun 17 Sep 2017, 7:33 am
have been doing a little on the build where possible, have one side guard done and swapped the shifter opening while at it to the left hand side, as you can see from the last picture I made it so the ammo boxes can be removed to access the contents as once the rear rack is made you wont be able to access the catches on them if fixed like I had originally planned.
The Murray with Mow name. - Page 4 Sunp0220
The Murray with Mow name. - Page 4 Sunp0217
The Murray with Mow name. - Page 4 Sunp0218
The Murray with Mow name. - Page 4 Sunp0219
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeSun 17 Sep 2017, 7:38 am
Wow that looks really good! Once painted it's gonna look like it was built that way haha.
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeSun 17 Sep 2017, 3:02 pm
Very nice, Just going to use the seat to hold them in, or will you have a lock down of some sort? Hate to see your boxes fall out if you flip or roll some how. (Hopefully you do not, but it happens)
Mow Money Mods
Mow Money Mods
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeSun 17 Sep 2017, 4:01 pm
they will have catches or straps on them to hold them in place, I will be building this with rollovers in mind, ,lol.
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeSun 17 Sep 2017, 4:20 pm
The Murray with Mow name. - Page 4 2731072446 The Murray with Mow name. - Page 4 2731072446 The Murray with Mow name. - Page 4 2731072446
This mower is so cool. I may steal an idea or two in the future.
Mow Money Mods
Mow Money Mods
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeSun 17 Sep 2017, 4:34 pm
that would be cool to see, I will add a few more pics of them once the other side is done and show the bracing etc underneath in more detail, all made with free steel from motorbike shipping crates.
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeSun 17 Sep 2017, 9:02 pm
This thing should've been in the buildoff
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeSun 17 Sep 2017, 9:13 pm
You going to have any issues with the tires and the boxes? They do look close!
Mow Money Mods
Mow Money Mods
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeSun 17 Sep 2017, 9:27 pm
yes as they are I will have issues I think, but doing a solid axle swap and will be adding 10mm either side for clearance, there is about 8mm there now, that will give me a little under an inch of clearance for those confused by all my foreign talk in mm's.
Mow Money Mods
Mow Money Mods
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeSun 17 Sep 2017, 9:29 pm
I think you just made me blush a little, lol, cheers for that.
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeSun 17 Sep 2017, 11:16 pm
You're fine talking in metric. There is a good mix of countries represented here!
Mow Money Mods
Mow Money Mods
PostSubject: Re: The Murray with Mow name.   The Murray with Mow name. - Page 4 Icon_minitimeMon 16 Oct 2017, 11:33 pm
Gday to all, so after 3 weeks of the flu and it almost killing me and another week and a half to catch up both physically and financially I'm back and ready to mod. Just have a quick question for those in the know, with a solid axle conversion would it be a bad move to use stainless steel for the axle itself as I have access to some in the right diameter but am not up to speed with what to use for axles etc. stainless does worry me a little hence the question. Cheers to all and have a great day.
Page 4 of 5Go to page : Previous  1, 2, 3, 4, 5  Next
» murray racers 35mph murray
» Murray Monster Mudder
» the murray
» The 84 murray
