 Husqvarna LT 130 MUD mower
Mow Money Mods
DiezelFuel
17 posters
Go to page : Previous  1, 2, 3 ... 7, 8, 9, 10, 11, 12  Next
Husqvarna LT 130 MUD mower - Page 8 Empty
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeMarch 28th 2018, 8:42 pm
Well this is the current project for this mower. The double pulley clutch. I took off all the old clutch and idler pulleys and I realized just how long the belt really is. I figure since I need to get rid of some of the length somehow and the deck belt is too short. I might just have to put a bigger pulley on the front. I might put a 6 inch or so. It would make it faster by a bit but mostly just get rid of some of that annoying slack that gets in the way of the steering.
Husqvarna LT 130 MUD mower - Page 8 Image226
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeApril 2nd 2018, 7:21 pm
To lazy to go work on the clutch for now and I also need some parts. I have no idea where to find "cheap" pulleys because a slightly bigger one for the front would help for sure. Anyways. I didn't really like having just simply the hand throttle moved down so I broke the rivet off, fabbed up a new piece of metal that would just slide right in place that was way heavier duty and welded a peg to it so I can hold it down more easily. Then I just drilled some stuff out and replaced it with a bolt.
Husqvarna LT 130 MUD mower - Page 8 Image138
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeApril 2nd 2018, 9:00 pm
I like that foot throttle design of yours a lot.  How is it getting to the brake pedal?
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeApril 2nd 2018, 9:49 pm
Yeah, not gonna lie it's a little tricky to get tot he brake, You kid have to just lift your foot off the gas and use your heel to push on it. I might be able to re position the gas pedal sometime if I want to.
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeMay 18th 2018, 9:30 pm
Right so, haven't done much on this but today I this in metalwork. Its a intake kinda like Rich's. It still needs the mounting holes and I need to make a little elbow for the breather to go into the side of it. I am not too sure what I need to do about the little hole that isn't threaded though. Is it a bowl breather? DO I need to tie it into the intake or can it just be shut off? Also, whats the hole that's sticking out for?
Husqvarna LT 130 MUD mower - Page 8 Img_2014
Husqvarna LT 130 MUD mower - Page 8 Img_2013
All that's really left is,
Finish wiring
Finish the 2P clutch
Beef up the steering
Put the links onto the front axle.
test it out and I might have to change my shocks for lighter ones
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeMay 18th 2018, 9:38 pm
Nice velocity stack. Should add a little grunt to it.
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeMay 18th 2018, 9:41 pm
Yeah I'm pretty sure those are vents, but I'm not positive. One will be for the fuel pump.
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeMay 18th 2018, 9:53 pm
I'm not running a fuel pump though. Thanks BTW I will probably get an ebay cone filter.
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeMay 18th 2018, 9:58 pm
Briggs opposed carbs have a built in pulse pump, that's what the peice on the front is with the plate bolted to it.
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeMay 18th 2018, 10:01 pm
Oh yeah right hahah brain fart lol.
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeMay 18th 2018, 10:03 pm
Hahaha. Nice filter adapter by the way! For what it's worth a small round air cleaner like I had on the Briggs single in the MTD would look better than a cone filter. Those always look pretty neat, haha.
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeMay 18th 2018, 10:06 pm
I'm referring to to these two. What does the top one hold on and what does the one on the bottom do?
Husqvarna LT 130 MUD mower - Page 8 2_010
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeMay 18th 2018, 10:08 pm
But I like cone filters, especially since I can easily modify it if I don't like it and make it into a snorkel with some tubing pretty easily.
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeMay 18th 2018, 10:12 pm
I wanna say the one closest to the carb inlet is for the bowl and the other might be for the fuel pump.
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeMay 18th 2018, 11:36 pm
Just a quick idea about the brake/gas pedal arrangement. Maybe cut the gas pedal so it's shorter/narrower (the pipe part) and then add a slight extension to the brake pedal?
Then you might be able to use the tip of your foot more to reach everything instead of your heel on the brake. Maybe possibly...
And If you need more grip, I always take nuts,usually 1/4", and you can spot weld them onto your pedals for traction. Burn them in hot though, because the weld likes to go for the inside of the nuts and then they won't bite in enough. Aim your welder in the center and get a good burn. You can weld on the outside too but looks cleaner if you just weld in the center.
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeMay 18th 2018, 11:37 pm
The one next to the inlet is definitely the bowl vent.
Husqvarna LT 130 MUD mower - Page 8 Sig115PROJECTS:
Husqvarna LT 130 MUD mower - Page 8 Sig214Husqvarna LT 130 MUD mower - Page 8 Sig314
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeMay 18th 2018, 11:46 pm
Ok so I would need to make it so the bowl went ties into the new intake? Thanks for the pedal suggestions but I will ride with it for now and if I don't like it I will modify them accordingly.
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeMay 19th 2018, 9:59 am
The top one is a carb filter mountimg hole, next one is a bowl vent like mighty said. I had a snorkel on an oppy and covered up the vent and I was always running lean or stalling out, then I found out that was a vent and remade my adapter and it worked fine. You could take a grinder and make a little slot over the vent hole and run the slot inwards to the carb barrel, that would be enough for the vent to get pressure release.
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeMay 19th 2018, 1:07 pm
Ok thanks that's the plan.
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeJune 3rd 2018, 9:02 pm
Here you go Allis. Hahaha. I got the links after some mail difficulties. Here are the bars welded up. I still need to make the mounts. I'm thinking one will go on the bottom side of the axle and the one on the other side will go above to balance it out a bit. Also, I had a friend over so that I could weld up the double pulley clutch. I need to put an idler pulley on the other side where there is lots of slack. Then I need to figure out the linkage which should be easier than I think as always.
Husqvarna LT 130 MUD mower - Page 8 Img_2024
Husqvarna LT 130 MUD mower - Page 8 Img_2023
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeJune 4th 2018, 5:26 pm
Now all that needs to be done is electrical and belt retainers!!! Getting really close. This summer when school is out and I have more time I will paint it mat black with more red highlights such as the links. Also need longer bolts for the heim joints because the ones I bought were too short and mismatched by accident. Here's the clutch. Putting the linkage in place was a million times easier than I had anticipated. It de-clutches very well but I need to add retainers to every pulley. That trampoline spring should keep good tension. I hope it's aligned enough but I guess we will see. Husqvarna LT 130 MUD mower - Page 8 Img_2025
Husqvarna LT 130 MUD mower - Page 8 Img_2026
Husqvarna LT 130 MUD mower - Page 8 Img_2027
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeJune 4th 2018, 5:34 pm
Looks good!
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeJune 4th 2018, 5:45 pm
Looks pretty cool muck! I might suggest maybe adding a secondary attatchment point for the axle like so:
Husqvarna LT 130 MUD mower - Page 8 20180630
That would essentially make they into long arms like these:
Husqvarna LT 130 MUD mower - Page 8 Jeep-l10
You would just need two more joints for where the shorter link connects to the main one to give a point of twist so the arms won't just bind up. That'd be a super solid setup and really, if you did that and fabbed up a track bar, you could get rid of the axle pivot.
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeJune 4th 2018, 5:47 pm
Yep! I was definitely considering that. It's just that the tie rod gets in the way. Maybe if I have some rod ends to spare some time I might find a way to make it fit though.
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeJune 4th 2018, 5:53 pm
Yeah I noticed it might sorta be in the way. You could however make up some new steering arms and mount the tie rod out front so it wouldn't be in the way.
PostSubject: Re: Husqvarna LT 130 MUD mower   Husqvarna LT 130 MUD mower - Page 8 Icon_minitimeJune 4th 2018, 5:56 pm
Yes I could. I will see how it goes. I already notice way less play in the steering just by pushing it around the yard.
Page 8 of 12Go to page : Previous  1, 2, 3 ... 7, 8, 9, 10, 11, 12  Next
» Husqvarna mud mower beast "husky" resurrection
» Husqvarna 90's rally mower.
» 04 husqvarna mudder/trail rider
» Husqvarna 324L String trimmer mods
» BUILDING THE MOWER - DAYS OF THUNDER RACE MOWER
