| Husqvarna LT 130 MUD mower | |
+13biggasmowers Double W Cross Ranch Crazy_Carl Buck prancstaman CraftsmanQuad19 Mow Money Mods MatthewD MightyRaze AllisKidD21 DiezelFuel RichieRichOverdrive muckmudd 17 posters |
muckmudd Established Member
| Subject: Re: Husqvarna LT 130 MUD mower March 21st 2018, 10:36 pm | |
| I like to do stuff so it's not permanent. If I would have welded on stuff in the past this tractor would be a mess. I can't get at it with vice grips so I might have to modify it in a bit of a different way. Anyways, tomorrow I have to fix the welder before I do anything. What do you mean by side tension? | |
| Subject: Re: Husqvarna LT 130 MUD mower March 21st 2018, 10:47 pm | |
| Yeah I definitely wouldn't weld it on. Seems okay first until to need to remove it. I think what Mighty means is maybe cock it a bit so it catches in the hole and holds it. I've done that before. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 22 Join date : 2017-07-11 Points : 3558 Posts : 825 Location : In the shop
| Subject: Re: Husqvarna LT 130 MUD mower March 22nd 2018, 1:59 am | |
| You could grind two flat spots on the shaft somewhere so you can stick the open end of a combination wrench on it. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Crazy_Carl Veteran Member
| Subject: Re: Husqvarna LT 130 MUD mower March 22nd 2018, 7:01 am | |
| Or you can cut a slot in the stud with a hacksaw or grinder and keep it from turning with a screwdriver. | |
| Subject: Re: Husqvarna LT 130 MUD mower March 22nd 2018, 12:13 pm | |
| - AllisKidD21 wrote:
- You could grind two flat spots on the shaft somewhere so you can stick the open end of a combination wrench on it.
Yeah but then when I take the wrench out there would be a lot of play. | |
| Subject: Re: Husqvarna LT 130 MUD mower March 22nd 2018, 12:20 pm | |
| Yeah that's true I guess. I'd try what Carl said. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4927 Posts : 1944 Location : Kansas
| Subject: Re: Husqvarna LT 130 MUD mower March 22nd 2018, 12:23 pm | |
| Hey, just a thought, if you can grind a slot on the top of the threaded part that the nut goes over then you can put a box end wrench over it and then stick a flat blade screw driver in the notch and tighten it . | |
| Subject: Re: Husqvarna LT 130 MUD mower March 22nd 2018, 3:38 pm | |
| Isn't that kinda what Carl suggested? Hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Husqvarna LT 130 MUD mower March 22nd 2018, 9:48 pm | |
| Did you try it yet muck? I'm thinking that'll work out for ya. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Husqvarna LT 130 MUD mower March 22nd 2018, 9:53 pm | |
| Yeah sorry I got distracted for a while. I wrecked a few screw drivers though I think the nut must be cross threaded or something because it is very hard to thread on. might get a new nut and thats why there is a stack of washers. I also had to chop of a little piece of axle overhang. | |
| Subject: Re: Husqvarna LT 130 MUD mower March 22nd 2018, 10:12 pm | |
| Interesting. Maybe the nut was the wrong threads? At least it worked I guess, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 20 Join date : 2017-06-09 Points : 5489 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: Husqvarna LT 130 MUD mower March 25th 2018, 7:00 pm | |
| That looks pretty good. Nice and simple. I can't tell from the picture but is there a return spring back there somewhere? | |
| Subject: Re: Husqvarna LT 130 MUD mower March 25th 2018, 7:38 pm | |
| Looks cool muck! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Husqvarna LT 130 MUD mower March 25th 2018, 7:58 pm | |
| Well Carl, I was going to put a return spring but when I put it all together and tested it, It turns out that the stock brakes have a return spring kinda built in so I don't have to have one on the pedal. I was pretty happy about that because it keeps it very simple. | |
| Subject: Re: Husqvarna LT 130 MUD mower March 25th 2018, 8:00 pm | |
| Well really there is two springs back there. The one on the rod I think was to help the parking brake function and the other I think is the return spring because I assembled it before without it and it wasnt working. | |
| Subject: Re: Husqvarna LT 130 MUD mower March 28th 2018, 8:42 pm | |
| Well this is the current project for this mower. The double pulley clutch. I took off all the old clutch and idler pulleys and I realized just how long the belt really is. I figure since I need to get rid of some of the length somehow and the deck belt is too short. I might just have to put a bigger pulley on the front. I might put a 6 inch or so. It would make it faster by a bit but mostly just get rid of some of that annoying slack that gets in the way of the steering. | |
