| Husqvarna LT 130 MUD mower | |
+13biggasmowers Double W Cross Ranch Crazy_Carl Buck prancstaman CraftsmanQuad19 Mow Money Mods MatthewD MightyRaze AllisKidD21 DiezelFuel RichieRichOverdrive muckmudd 17 posters |
muckmudd Established Member
| Subject: Re: Husqvarna LT 130 MUD mower September 8th 2017, 11:28 am | |
| Forgot to post this! I finally found an easy way to set up the throttle as a foot throttle. I simply unbolted it from where it was and brought it around to the other side and welded a little bracket on the mower. I did attach a return spring but its not in the picture. | |
Age : 22 Join date : 2017-07-11 Points : 3558 Posts : 825 Location : In the shop
| Subject: Re: Husqvarna LT 130 MUD mower September 11th 2017, 12:17 am | |
| - mightyraze wrote:
- Looks like a lot of fun!
It sure was. I am planning on making the front axle stronger and maybe getting springs that are a little bit looser. these ones don't even move and the frame just flexes. I might also add some frame strengthening brackets. I am also adding a few hitches to the rear bumper as soon as possible, and I still wait patiently for rims/tires. | |
Buck Member
Join date : 2017-11-01 Points : 2879 Posts : 282 Location : Eastern Ontario
| Subject: Re: Husqvarna LT 130 MUD mower December 18th 2017, 7:30 pm | |
| - Buck Mault wrote:
- nice build, i like the front suspension setup you have
Thanks but it didnt really work, im making a new setup. | |
| Subject: Re: Husqvarna LT 130 MUD mower December 18th 2017, 9:53 pm | |
| Here Allis, they aint great pictures but here is some progress on my new front end. the bolt that you see will go through the axle and there will be some springs somewhere on the side. its not quite finalized but have removed the old piece of junk off the mower. I will post more and try to get it done soon because I WANT TO GO MUDDING!!! I | |
| Subject: Re: Husqvarna LT 130 MUD mower December 18th 2017, 10:00 pm | |
| FINALLY!!!!! Haha, just kidding. Looks cool! That tube steel axle appears to be pretty heavy duty. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Husqvarna LT 130 MUD mower December 18th 2017, 10:05 pm | |
| Yeah its damn solid. i wanted something a little tough and i couldnt find cast iron so I just made it myself, its still pretty much the same dimentions though. Do you think i should mount it on the front of the frame or where it was originaly... people tell me that when the wheels are further apart its better for the mud. | |
| Subject: Re: Husqvarna LT 130 MUD mower December 18th 2017, 10:09 pm | |
| I'd say mount it where it would cause the least amount of clearance issues, so probably where it was originally. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Husqvarna LT 130 MUD mower December 18th 2017, 10:12 pm | |
| - mightyraze wrote:
- It does look pretty heavy duty. Looks good.
Thanks mighty! where do you think i should position it on the mower | |
| Subject: Re: Husqvarna LT 130 MUD mower December 18th 2017, 10:26 pm | |
| I haven't heard about the further apart for the mud before. Personally I would want it under so I could rock it a little better. | |
| Subject: Re: Husqvarna LT 130 MUD mower December 18th 2017, 10:33 pm | |
| - mightyraze wrote:
- I haven't heard about the further apart for the mud before. Personally I would want it under so I could rock it a little better.
good point you got there. Im talking about something like bow tie mud guys build off mower junt in case you dont know what i mean. | |
| Subject: Re: Husqvarna LT 130 MUD mower December 18th 2017, 11:53 pm | |
| AH, i know what you are talking about. It all comes down to personal preference. Most have it under the frame to my knowledge. | |
| Subject: Re: Husqvarna LT 130 MUD mower December 19th 2017, 12:26 am | |
| Ok well its gonna be hard to strengthen the frame where I cut out the old axle so maybe I will just put it back where it was although I kinda like the look of BTMGs mower. | |
| Subject: Re: Husqvarna LT 130 MUD mower December 19th 2017, 8:57 am | |
| Go for it! It's ultimately your build! I think you would be happier if you did! if it doesn't work out or breaks, bust out the wrenches and try again! This is something you should have fun with! (With a little side of safe) Either way, you'll do great! | |
| Subject: Re: Husqvarna LT 130 MUD mower December 19th 2017, 11:16 am | |
| Yeah I will try to move it forward a bit, maybee to where the exhaust was and it will also leave me more room for coil towers and it wont be underneath a return spring that takes up a lot of space. | |
| Subject: Re: Husqvarna LT 130 MUD mower December 21st 2017, 6:07 pm | |
| Did I forget to post pictures of th sick bumper that I made? It's really heavy duty and it looks great in my opinion. I need to figure out how to wire the lights now. Also I found a manual boat trailer winch at the scrapyard for 5 bucks should I mount it on the front? Mod Edit: (Mightyraze) Undid the App thurmbnail to large pix. | |
| Subject: Re: Husqvarna LT 130 MUD mower December 21st 2017, 6:09 pm | |
| Here is another picture. Mod Edit: (Mightyraze) Undid the App thurmbnail to large pix. | |
| Subject: Re: Husqvarna LT 130 MUD mower December 21st 2017, 7:22 pm | |
| - mightyraze wrote:
- Pretty sick looking bumper.
thanks! have you ever put a manual winch on a mower. | |
Crazy_Carl Veteran Member
| Subject: Re: Husqvarna LT 130 MUD mower December 22nd 2017, 6:47 am | |
| I think that manual winch is a good idea. My Dad uses a few of those at his farm for changing the height of elevators and for a crane on his trailer. You don't need a big battery or alternator. You can use a snatch block to double your pulling power. I bet a hand crank winch would almost be 100% reliable too. | |
| Subject: Re: Husqvarna LT 130 MUD mower December 22nd 2017, 11:15 am | |
| - Crazy_Carl wrote:
- I think that manual winch is a good idea. My Dad uses a few of those at his farm for changing the height of elevators and for a crane on his trailer. You don't need a big battery or alternator. You can use a snatch block to double your pulling power. I bet a hand crank winch would almost be 100% reliable too.
yeah then I don't have to rely on a stupid battery all the time. i just need to find a good rope for it now. The only problem is it will stick out the front of the mower in front of the bumper. | |
| Subject: Re: Husqvarna LT 130 MUD mower December 22nd 2017, 11:26 am | |
| Maybe you can build a quick-release for it. Then maybe you can store it somewhere else on the tractor and only put it on when needed? | |
| Subject: Re: Husqvarna LT 130 MUD mower December 22nd 2017, 12:12 pm | |
| Not a bad idea mighty but there would still be a mounting plate sticking out the front of the bumper. | |
