| Husqvarna LT 130 MUD mower | |
+13biggasmowers Double W Cross Ranch Crazy_Carl Buck prancstaman CraftsmanQuad19 Mow Money Mods MatthewD MightyRaze AllisKidD21 DiezelFuel RichieRichOverdrive muckmudd 17 posters |
muckmudd Established Member
| Subject: Re: Husqvarna LT 130 MUD mower June 4th 2018, 5:56 pm | |
| Yes I could. I will see how it goes. I already notice way less play in the steering just by pushing it around the yard. | |
Age : 22 Join date : 2017-07-11 Points : 3558 Posts : 825 Location : In the shop
| Subject: Re: Husqvarna LT 130 MUD mower June 5th 2018, 1:33 am | |
| List of whats left: -Paint EVERYTHING before it rusts bad. -Idler pulley and engine pulley belt retainer -Buy longer link bolts -Remove electrical and simplify -Add a pull start -Tighten down carburetor -Find tube for snorkel -Get sheet metal and make a custom hood -Attach breather to intake -Wire up pod lights -Attach tips to exhaust and some more things that I'm not too sure i'll do yet. I will also find stuff as I go. | |
| Subject: Re: Husqvarna LT 130 MUD mower June 26th 2018, 10:53 pm | |
| Large-ish Update!! I am re doing the front end suspension. I didn't even end up trying the original set up. But it had no bounce or flex to it. and I realized that my goofy system wouldn't be as good as one that has been perfected over many decades. I am going with a long arm setup. I want it to be solid, be able to flex and take a beating. This is a rough design. I quickly chopped off the old system this evening to make a clear starting point. It shouldn't take too long, the most difficult thing will be the springs, I want to take them out of the absorber to test their rigidity if possible?? I will probably just make bucket style retainers for the spring. Enough talking, here's a few pics, Ill keep ya'll updated. | |
Crazy_Carl Veteran Member
| Subject: Re: Husqvarna LT 130 MUD mower June 27th 2018, 10:45 pm | |
| Nice! Always feels good to get stuff painted, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Husqvarna LT 130 MUD mower June 28th 2018, 1:17 am | |
| Lol, you're a far better artist than me.
If I were you, I'd just take an angle grinder and chop everything from the stock axle hole down and forward off, and brace what you have left with square tubing. That way you have a lot more room to work with for suspension. | |
| Subject: Re: Husqvarna LT 130 MUD mower June 28th 2018, 12:28 pm | |
| Thanks for the tip but I think I have enough room to work with now. Shouldn't be to hard to drop a panhard bar in the channel stock there. | |
| Subject: Re: Husqvarna LT 130 MUD mower June 28th 2018, 5:40 pm | |
| painted a few more panels, the clutch pieces, brake linkage, etc.. Quite thick goopy spray paint for some reason, so it might take a day or so to dry, also I bought 20$ worth of nuts and bolts for the various heim joints on the links, now I just need some metal form the scrapyard. All is good. | |
| Subject: Re: Husqvarna LT 130 MUD mower June 29th 2018, 1:26 am | |
| Yes, but would it be ok to get rid the excess material or is that adding rigidity to the hub? | |
| Subject: Re: Husqvarna LT 130 MUD mower June 29th 2018, 12:21 pm | |
| The old part of the actual white rim that sticks out past where the flat hub center piece meets the ATV rim. | |
| Subject: Re: Husqvarna LT 130 MUD mower June 29th 2018, 3:56 pm | |
| Alright, that's what I was thinking. Installed the clutch back in, everything articulates fine. Looks good. The paint on the rims finally set, and it looks sooo good. I will probably do the rear wheels or at least the hubs. | |
| Subject: Re: Husqvarna LT 130 MUD mower June 29th 2018, 3:58 pm | |
| Coming along nice! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Husqvarna LT 130 MUD mower June 29th 2018, 8:39 pm | |
| Got some new shocks that seem to be less stiff. Obviously they bolt on differently but they should work fine. I'll leave them in the absorber for now. The metal is to finish the arms. | |
| Subject: Re: Husqvarna LT 130 MUD mower June 29th 2018, 9:06 pm | |
| I think you'll have better luck with those shocks.
Are you going with rebar link arms? That's pretty cool but what diameter are they? | |
| Subject: Re: Husqvarna LT 130 MUD mower June 29th 2018, 9:44 pm | |
| The rebar is about the same size as the other stuff probably like 3/4 or something. Should be solid enough, I couldn't find any other round stock at the scrapyard. The shocks did drop a little when I set the mower on them, that's a good thing. Ill try and finish the suspension on Monday. | |
| Subject: Re: Husqvarna LT 130 MUD mower June 30th 2018, 4:45 am | |
| That rattle can stuff is really turning out nice.
Oh and I'd cut that outer part of the rim off. You can brace what you have left but I don't really think it's necessary. | |
| Subject: Re: Husqvarna LT 130 MUD mower July 4th 2018, 12:54 am | |
| I am almost done, I need to order a few more heim joints because I messed up and it doesn't flex. I will paint everything when I finish up the panhard bar. Then I will do the steering after. | |
