| | My Rat Rod Mower | |
+13RichieRichOverdrive Mikethepigman MightyRaze Doug Deek AllisKidD21 MatthewD prancstaman mr.modified CraftsmanQuad19 redlinemotorsportts Ryf jahneygeee 17 posters | |
MatthewD Veteran Member
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 26th 2017, 5:41 pm | |
| Nice. I would like to have a go at porting sometime, will have to look at buying a die grinder or dremel. | |
| ![Go down](https://2img.net/i/empty.gif) | | AllisKidD21 Moderator
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 26th 2017, 6:23 pm | |
| Yeah this was my first go at it, wasn't as hard I thought it would be. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| ![Go down](https://2img.net/i/empty.gif) | | prancstaman Veteran Member
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 26th 2017, 9:27 pm | |
| I got a dremel I think. It's for wood working. My wife got it for me, from Aldi's of all places, $50. Been using it for years for porting engine heads, aluminum and cast iron. Works real good. What matters when picking one out mostly are the features. Variable speed comes in handy alot. Just spinning fast will load the cutting tool up with metal, need to slow down the tool to make it last or spin fast to keep the cutting tool clean, depends on the metal. The collet or the part you put the cutting tool in, there are 2 sizes, 1/8 and 1/4. The 1/4 inch collet is the best to get because there are multiple tools you can use, tootsie rolls, stones, carbide cutters to little buffing wheels for porting. You can go to a machinist store to buy the carbide cutters for around $20 each and they last forever which is way better then the stones and tootsie rolls (sandpaper rolls). Comes in handy when doing a V8, LOL. Plus most adapters fit the 1/4 collet that you can buy later, like a cable drive which is lighter to hold then the motor part itself and less cumbersome for the touchy areas. The 1/8 collet is mostly used buy jewelers and limited in the sanding department to where you could only get stones and sanding drums which are small which is OK if you are just doing a 1 or 2 cylinder port job. I done port jobs on 1 cylinders with a drill and stones. took a while but worked great.
For those of you just starting out in this area. | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 26th 2017, 9:53 pm | |
| Good information prancstaman! I've about worn out my old dremmel and need to replace it sometime. Thanks for the information! | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 27th 2017, 9:01 am | |
| Mine doesn't have variable speeds, so I had to feather the trigger, haha. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 27th 2017, 10:54 am | |
| Got everything all back together and ready to go! ![My Rat Rod Mower - Page 9 20170374](https://i.servimg.com/u/f58/19/50/91/63/20170374.jpg) ![My Rat Rod Mower - Page 9 20170375](https://i.servimg.com/u/f58/19/50/91/63/20170375.jpg) Gonna fire it up for the first time in a while tomorrow, might make a video of it but I'm not sure yet. Stay tuned! ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 27th 2017, 11:24 am | |
| Looks great, really stands out from the rest of the mower. :-) | |
| ![Go down](https://2img.net/i/empty.gif) | | MatthewD Veteran Member
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 27th 2017, 11:38 am | |
| - prancstaman wrote:
- I got a dremel I think. It's for wood working. My wife got it for me, from Aldi's of all places, $50. Been using it for years for porting engine heads, aluminum and cast iron. Works real good. What matters when picking one out mostly are the features. Variable speed comes in handy alot. Just spinning fast will load the cutting tool up with metal, need to slow down the tool to make it last or spin fast to keep the cutting tool clean, depends on the metal. The collet or the part you put the cutting tool in, there are 2 sizes, 1/8 and 1/4. The 1/4 inch collet is the best to get because there are multiple tools you can use, tootsie rolls, stones, carbide cutters to little buffing wheels for porting. You can go to a machinist store to buy the carbide cutters for around $20 each and they last forever which is way better then the stones and tootsie rolls (sandpaper rolls). Comes in handy when doing a V8, LOL. Plus most adapters fit the 1/4 collet that you can buy later, like a cable drive which is lighter to hold then the motor part itself and less cumbersome for the touchy areas. The 1/8 collet is mostly used buy jewelers and limited in the sanding department to where you could only get stones and sanding drums which are small which is OK if you are just doing a 1 or 2 cylinder port job. I done port jobs on 1 cylinders with a drill and stones. took a while but worked great.
For those of you just starting out in this area. Thanks Prancstaman! I was looking at this air powered one - BERGEN 15pc MINI 1/4" AIR DIE GRINDERIt comes with 1/8" and 1/4" collets and various tools. Seems decent for 15 quid. Not sure if it has variable speeds or not. BTW mower looks great Allis! | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 27th 2017, 3:08 pm | |
| - mightyraze wrote:
- Looks great, really stands out from the rest of the mower. :-)
Thanks! ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | AllisKidD21 Moderator
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 28th 2017, 10:34 am | |
| A couple small things, but the list will continue to go on I'm sure hahaha! On another note, I got 'er running today! Sorry no video, I figured I should " finish" it before I make a video of it. But here she is! ![My Rat Rod Mower - Page 9 20170376](https://i.servimg.com/u/f58/19/50/91/63/20170376.jpg) ![My Rat Rod Mower - Page 9 20170377](https://i.servimg.com/u/f58/19/50/91/63/20170377.jpg) More welding to do tomorrow so I might get some pics of that. Let me know what ya think! ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 28th 2017, 12:23 pm | |
| Lookin good. Not sure if you mentioned this before. You putting the hand crank back on the front? | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 28th 2017, 3:07 pm | |
| Thanks mighty! Naw that's where the badge is gonna go. I think I'm gonna strap it to the side of the dash or something though, make it look like that's where it goes after you crank the engine over, haha. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 28th 2017, 4:06 pm | |
| That would be cool. I forgot about the badge! That thing will look great up there! | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 29th 2017, 10:40 am | |
| A bit of welding today; I made a fully adjustable stop for the throttle pedal so that it will rest against something when at full throttle.
![My Rat Rod Mower - Page 9 20170378](https://i.servimg.com/u/f58/19/50/91/63/20170378.jpg) ![My Rat Rod Mower - Page 9 20170379](https://i.servimg.com/u/f58/19/50/91/63/20170379.jpg) Should be much better! I also inserted and welded some washers in the gap between the spindle knuckles and the axle beams. ![My Rat Rod Mower - Page 9 20170380](https://i.servimg.com/u/f58/19/50/91/63/20170380.jpg) ![My Rat Rod Mower - Page 9 20170381](https://i.servimg.com/u/f58/19/50/91/63/20170381.jpg) Don't need the knuckles breaking loose! Hahaha, let me know what ya think! ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 29th 2017, 11:10 am | |
| Looks good, only question:
Being that you put the adjuster on the side like that, in a moment of excitement is it possible that you could bend or break it off? | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 29th 2017, 3:12 pm | |
| I thought of that as well, haha. I've been doing it by feel for a while now, so I can only hope I won't press too hard on it. But we' ll see, hahaha! ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 29th 2017, 3:38 pm | |
| HAHA...
I'd be like WHOA and smash it. HAHA... | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 30th 2017, 10:28 am | |
| Hahaha, it's tempting aha. Anyway nothing new today, just gave 'er a good wash for the first time in too long, haha. I'll see what I end up doing on Monday! ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 30th 2017, 10:34 am | |
| OH NO! Not the dirt that holds the rust together! LOL, that's something I use to tease my friend about back in high school. | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 30th 2017, 12:05 pm | |
| Hahaha! No it's ok, I left the dirt in some spots to help hold everything together. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 31st 2017, 9:52 pm | |
BTW mower looks great Allis! Yes, it is variable speed either by the trigger handle, a flat head screw in the housing, or a screw on air valve. But at the lower speeds they usually don't have much torque. Best to use them at medium and high speed since they get their strength from the rpm. All air die grinders are like that. Find out the cfm it uses to make sure your air compressor can keep up, other wise you'll be grinding for 30 seconds and waiting 3 minutes for the air compressor to charge back up. | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 31st 2017, 9:55 pm | |
| Looks pretty good. Going to need some run flats for when the cops throw out the spike strips, LOL. | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower March 31st 2017, 11:26 pm | |
- Going to need some run flats for when the cops throw out the spike strips, LOL.
That's a riot! | |
| ![Go down](https://2img.net/i/empty.gif) | | TheBeal Veteran Member
![TheBeal](https://2img.net/u/2812/37/66/46/avatars/967-1.jpg)
Age : 29 Join date : 2013-06-06 Points : 5643 Posts : 1402 Location : Central PA
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower April 1st 2017, 10:47 am | |
| Id grind down, and reweld the axle. Grind the welds flush, and any porosity or undercut try and grind that out too. Because it was welded once, I wouldnt be afraid to turn the welder up some when welding over it. Just pay attention, it will start to sound different when it gets too hot and close to burning through. Thats not something you want to break loose when your runnin away from the cops! That and, if you deceide to slap some paint on there, that will be the first place you see rust coming through. Then you will be mad. Like me. Another thought, for your throttle stop... IF it end up breaking off.... Drill a hole in the floor board for a long bolt, then use 2 nuts to keep it tight. That should be pretty stout. | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | Subject: Re: My Rat Rod Mower April 1st 2017, 1:20 pm | |
- Looks pretty good. Going to need some run flats for when the cops throw out the spike strips, LOL.
Hahaha, they can't catch me! Haha, thanks! ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
![My Rat Rod Mower - Page 9 Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | My Rat Rod Mower | |
| Who is online? | In total there are 31 users online :: 0 Registered, 0 Hidden and 31 Guests
