| My Rat Rod Mower | |
+13RichieRichOverdrive Mikethepigman MightyRaze Doug Deek AllisKidD21 MatthewD prancstaman mr.modified CraftsmanQuad19 redlinemotorsportts Ryf jahneygeee 17 posters | |
| Subject: Re: My Rat Rod Mower August 28th 2016, 10:16 am | |
| Well, I finally got to take the rat rod for a test drive Tuesday. I finished the wiring, foot throttle, and gas tank. I can now start and run it completely from the seat. I just tried first gear to see how it went. It drove quite nice but when I clutched, the belt would fall off. I put it back on and made it pretty far in second gear. But the belt was still an issue. So I made up some belt retainers and fixed the problem. But now the belt just slips in every gear. So I brought the clutch home because I think my pivot point is the problem. I was able to get rid of the old pivot pin, and center and weld a 3/8" grade 5 bolt on as the pivot. I think it will be much stronger and perhaps more adjustable. I'll let you all know how it goes! | |
| | | AllisKidD21 Moderator
| Subject: Re: My Rat Rod Mower August 30th 2016, 5:17 pm | |
| - MatthewD wrote:
- Nice man! Yeah 600 series are pretty tough old boxes
That's good to know, cuz I'm not interested in having to replace it anytime soon! Hahaha! | |
| | | MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5750 Posts : 1993 Location : Northern Ireland
| Subject: Re: My Rat Rod Mower September 1st 2016, 3:20 pm | |
| Yeah I've read some quite good things about them. Did you get the clutch issue sorted yet? | |
| Subject: Re: My Rat Rod Mower September 1st 2016, 5:44 pm | |
| - MatthewD wrote:
- Yeah I've read some quite good things about them. Did you get the clutch issue sorted yet?
Yeah me too. I finished welding it but I have yet to try it out, I'll let you know how it goes! Fingers crossed!! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower September 2nd 2016, 11:08 am | |
| Thanks, that would be nice. The other thing that could be wrong is you got the wrong size belt. I'm having the same problem with my Westwood T1200. | |
| Subject: Re: My Rat Rod Mower September 5th 2016, 10:02 pm | |
| Subject: Re: My Rat Rod Mower September 6th 2016, 11:19 am | |
| Love it! Those little touches really make it a Rat Rod mower. | |
| Subject: Re: My Rat Rod Mower September 6th 2016, 11:27 am | |
| Thank man! I really wanted to make it rather unique. I'm not done adding stuff either hahaha! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower September 6th 2016, 11:31 am | |
| Yeah, I like the chain around the gas tank | |
| Subject: Re: My Rat Rod Mower September 6th 2016, 11:40 am | |
| Thanks! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower September 6th 2016, 3:36 pm | |
| I'm planning on incorporating this somewhere on the ol' rat rod, but I'm not sure where. Suggestions? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Join date : 2015-02-02 Points : 5093 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: My Rat Rod Mower September 6th 2016, 9:49 pm | |
| That piston would make a great foot pedal. Even got the hole already in it from the wrist pin, LOL. | |
| Subject: Re: My Rat Rod Mower September 6th 2016, 9:59 pm | |
| Never thought about that, I bet the pedal would fit right through the holes. Hmmm...... "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower September 24th 2016, 7:59 pm | |
| A couple things new with the rat rod, I had to move and sorta re-design the the clutch assembly. It would not de-clutch like it should making it nearly impossible to get it into gear. But I moved it all over to what I think is called the slack side of the belt. And after some adjustments it is working much better. But now that that is all figured out, I need to address exhaust. I currently have the muffler on that came with the engine when I got it It's functional but it doesn't look very cool. I was hoping one of you guys could give me some advice as of what would look the best because I can't quite decide. Thanks in advance! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower September 24th 2016, 10:53 pm | |
| If you got a welder, get some 3/4 piping conduit bends and a bicycle fork. The conduit, you can cut up and snake it to under the foot board and cut off one of the forks for the tail pipe with the bend being the end. | |
| Subject: Re: My Rat Rod Mower September 24th 2016, 11:08 pm | |
| Yeah I'm equipped to weld, I also thought going under the foot board would be the best way to go. I was gonna run it under the frame but if I have a clutch issue or something it would suck to get burned on a hot exhaust pipe while trying to fix it, haha. You don't think 3/4" would be too restrictive? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower September 25th 2016, 1:32 pm | |
| Oh sorry, I mean 1 inch. 1 inch is good for 10 hp engines and bigger. 3/4 inch is good for engines up to 10 hp. | |
| Subject: Re: My Rat Rod Mower September 25th 2016, 3:30 pm | |
| Lol you need a big rusty tail pipe on that exhaust man! | |
| Subject: Re: My Rat Rod Mower September 25th 2016, 3:33 pm | |
| Oh ok, I thought 1 inch would work pretty good. I'm probably gonna make a muffler to go on as well just so it's not too obnoxious. It'll just bolt on the underside of the foot board. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower September 25th 2016, 3:36 pm | |
| - MatthewD wrote:
- Lol you need a big rusty tail pipe on that exhaust man!
Hahaha, yeah! That would probably look pretty cool. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower October 3rd 2016, 9:01 pm | |
| Ok, so I've decided on an exhaust plan for the rat rod mower. I got some cool exhaust scraps from work so it's not gonna cost me a thing! Hahaha! So here's what I got- So it's just gonna have a header running under the footboard into a resonator (the big pipe) Here's the header "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower October 4th 2016, 6:33 pm | |
| Ok now on to the resonator pipe. I've mocked this all up once and I love the sound so I'm definitely keeping this setup. So I welded a washer on tom use as a mounting tab When all assembled it's gonna look like this. I also made a little cap to enclose the input end of the resonator Let me know what you think! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower October 4th 2016, 7:35 pm | |
| Thanks! Hopefully I'll get some pictures of it mounted to the mower soon. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower October 4th 2016, 10:02 pm | |
| Thanks man! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Who is online? | In total there are 12 users online :: 1 Registered, 0 Hidden and 11 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
