| Tecumseh HH120 Won't Start | |
+3Stretch44875 Doc Sprocket BlackMountian88 7 posters | |
Doc Sprocket Site VIP
| Subject: Re: Tecumseh HH120 Won't Start September 2nd 2013, 10:37 am | |
| Given the age of the engine (now that I think about it)- what sort of shape are the breaker points and condenser in? | |
| | | matt-man Member
Age : 27 Join date : 2013-07-26 Points : 4389 Posts : 221 Location : North Fort Myers, Florida
| | | | WellThatsSurprising Member
Age : 27 Join date : 2012-04-30 Points : 5005 Posts : 407 Location : East Bethel, MN
| Subject: Re: Tecumseh HH120 Won't Start September 2nd 2013, 12:46 pm | |
| - matt-man wrote:
- What year is the engine?
- BlackMountian88 wrote:
- I've got a 1968 Tecumseh HH120
| | | BlackMountian88 Member
Age : 25 Join date : 2012-09-08 Points : 4891 Posts : 399 Location : NH
| Subject: Re: Tecumseh HH120 Won't Start September 2nd 2013, 1:47 pm | |
| Yes, I was told it's a 1968.
Doc, it's a Solid State ignition module. No points, no condenser, no magnets.
I tried putting fuel in the cylinder, (this is the weird part), and after cranking for 10 seconds with no attempt at starting, I checked the plug again. Completely dry. Now that I think of it, I have never seen the plug wet. Yet, I have tried gas and starting fluid in the cylinder. The gas is that close, but it won't stick to the plug. Why? | |
| | | matt-man Member
| Subject: Re: Tecumseh HH120 Won't Start September 2nd 2013, 1:53 pm | |
| Not that I've noticed. Never taken a whiff down the dipstick tho. It has plenty of compression tho, if the gas was getting past the rings that bad, I would think it'd have no compression. | |
| | | matt-man Member
| Subject: Re: Tecumseh HH120 Won't Start September 2nd 2013, 1:54 pm | |
| Do you notice gas around the exhaust? Maybe you have a valve stuck open. What I would do it pull the head and make sure both valves open and close completely | |
| Subject: Re: Tecumseh HH120 Won't Start September 2nd 2013, 1:57 pm | |
| Yah, the valves are definitely not stuck open. Compression again. And when I bought it, the head was off. So I got a good look in there. | |
| | | Guest Guest
| Subject: Re: Tecumseh HH120 Won't Start September 2nd 2013, 2:13 pm | |
| well, if it has good spark, good fuel and good compression it can really be very few things - first on my mind is timing. Spark may be hitting at wrong time, or the valves may not be opening at the right intervals. Best suggestion I can give at this point. Still, that old of an engine theres not much that can go wrong.
Last edited by prometheusedi on September 2nd 2013, 2:16 pm; edited 1 time in total |
| Subject: Re: Tecumseh HH120 Won't Start September 2nd 2013, 2:15 pm | |
| Well my latest breakthrough suggests the plug is not getting wet. Even after I dump gas in the cylinder... | |
| | | Guest Guest
| Subject: Re: Tecumseh HH120 Won't Start September 2nd 2013, 2:16 pm | |
- Well my latest breakthrough suggests the plug is not getting wet. Even after I dump gas in the cylinder...
then it has to be leaking past the rings somehow. |
Age : 51 Join date : 2013-04-21 Points : 7316 Posts : 2914 Location : Ontario Canada
| | | | matt-man Member
| | | | matt-man Member
| Subject: Re: Tecumseh HH120 Won't Start September 2nd 2013, 2:55 pm | |
| That's bizzarre. I want to know what triggers the ignition. Something behind the coil perhaps? Take it off and look. | |
| Subject: Re: Tecumseh HH120 Won't Start September 2nd 2013, 3:22 pm | |
| I'm researching my brains out on this one, as I am intrigued. Parts and info are hard to come by, but it appears that the coil is a standalone part. There's a stator and magnet behind the flywheel- this is what times the spark. Still digging. | |
| Subject: Re: Tecumseh HH120 Won't Start September 2nd 2013, 3:36 pm | |
| I have a completely disassembled hh120 at home that I could take some good pictures off of later today, just tell me what you want a picture of. | |
| | | | Guest Guest
Age : 28 Join date : 2013-04-10 Points : 5759 Posts : 1408 Location : Galway NY
| Subject: Re: Tecumseh HH120 Won't Start September 2nd 2013, 10:29 pm | |
| this is good to know if i ever have problems with mine.. i have an HH100 on my bolens. same engine just 2 less ponies. never let me down. did blow the windings in the starter gen though... i doubt i'll be of any help, but i'll stick around. | |
| Subject: Re: Tecumseh HH120 Won't Start September 3rd 2013, 7:59 am | |
| Thanks everyone!
Thanks for that post Pro, I have read parts of that a few days ago.
WellThatsSuprising, Your pictures are right where I'm at now. Except I didn't remove the coil and such to that extent.
I don't believe it's adjustable, especially after seeing those pictures. I think I'm going to clean it up nice, and put it back together. There's not much else I can do.
Despite what yall say here, my dad is certain it's not a spark problem. I still think it could be ignition timing, but there doesn't seem that there is a way to adjust it. | |
| Who is online? | In total there are 22 users online :: 0 Registered, 0 Hidden and 22 Guests
