| Flipped tractor and now it wont start. | |
muddawg96 New Member
Age : 28 Join date : 2011-08-29 Points : 4838 Posts : 4 Location : North Carolina
| Subject: Flipped tractor and now it wont start. November 17th 2011, 10:03 pm | |
| Today my friend flipped my tractor over on its side, and when we flipped it back over it smoked alot then cut off. Now it won't start. There is alot of oil in the air filter. Can someone tell me whats wrong/ what to do to fix it?
Thanks! | |
| Subject: Re: Flipped tractor and now it wont start. November 18th 2011, 8:30 am | |
| Youll want to pull the plug and make sure the combustion chamber didnt fill with oil - the motor will hydro lock and snap the flywheel key. youll want to pull the flywheel shroud n check the flywheel key.
Youll also have to clean the carb, most likely change the oil as well. | |
| | | Guest Guest
| Subject: tractor won't start! HELP! November 18th 2011, 1:55 pm | |
| I've had a few do this. they usually dont run long enough upside down to do much damage. just gets oil in places its not supposed to be. change the plug and it should fire up, as long as it didnt stir up crap in the bottom of the gas tank. it will run rough and smoke alot, but it will finally clear out. might need to clean or replace the spark plug when you are done
I buy my plugs 10 at a time. that way I dont to waste a lot of time dicking with spark plugs... when in doubt, change it out. I have seen plugs that have a good spark but wont pop good enough under compression to fire one off. spend an hour jacking around with either and cleaning the carb only to find out that a new plug would have fixed it to start with. |
| | | Ford Boi Member
Age : 40 Join date : 2010-08-22 Points : 5465 Posts : 242 Location : Yarmouth, Nova Scotia, Canada
| Subject: Re: Flipped tractor and now it wont start. November 18th 2011, 11:27 pm | |
| rat88 is right about plugs. I've had them new from the package and not fire. But yes I have also flipped my tractors over MANY MANY times and usually a quick cylinder clean with plug out and some good running will burn off any oil in no time. Depending on what type of engine does it possibly have a low-oil shutoff? Actually usually when I flip tractors I can usually flip em' back over before they stall, or, with my tether switch they shut off BEFORE rolling and running upside-down. Tether switches are a must on a fast tractor. | |
| Subject: Re: Flipped tractor and now it wont start. November 19th 2011, 1:04 am | |
| the plugs look fouled, its an 18.5 briggs twin. Im going to get new plugs tomorrow ans see if that works.
I'm new to all terrain lawn tractors, and ive done lots of mods to the tractor, just now as knowledgeable about engines as I need/ would like to be.
Thanks for the help!
| | | canadianromper Member
Age : 25 Join date : 2011-11-30 Points : 4857 Posts : 114 Location : ontario canada
| | | | Sponsored content
| Who is online? | In total there are 36 users online :: 0 Registered, 0 Hidden and 36 Guests
