| Engine wont start after rain and over night freeze | |
Age : 21 Join date : 2020-12-23 Points : 2307 Posts : 785 Location : Roachdale IN
| Subject: Engine wont start after rain and over night freeze December 24th 2020, 2:17 pm | |
| So i got a new trailer last night and i used the good ol john deere to take it to my back yard it was kinda cold and a pretty bad almost tornado wind and rain storm i was using it in. This morning all that rain was frozen and my ignition was frozen full of water and i got it to turn after chiping away the ice and it tried to turn but it wouldnt turn the motor over then i tried to use my hands to turn the motor over and it wouldnt turn even a tiny bit so its seized and im confused the oil is good and its even a little past full and when i shut the engine off it was normal and the only odd thing is it was puffing a little white smoke which it has since i got it what should i do? | |
2020 Build-Off Top 3 Winner
Age : 48 Join date : 2018-05-05 Points : 2988 Posts : 518 Location : S. Illinois
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5098 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: Engine wont start after rain and over night freeze December 25th 2020, 9:07 pm | |
| Water could have gotten between the ignition coil and flywheel also, then freezing which would lock the rotating assembly. Best thing to do is just wait till it can warm up to unfreeze anything that is frozen. Maybe put it someplace warm to thaw out. Point being, if you don't really need it now then just wait till it thaws because just trying start it up could break something since the part is frozen and locked. Probably just a tiny spot frozen keep it from starting.
I usually park mine outside year round, in the rain, snow, and sun. These mowers are mostly water proof but a couple sections. I just leave them alone till favorable conditions to start them. You get to knowing which system needs attention to weather proof them with oil, WD40, or grease to get them to work in extreme weather. | |
| Subject: Re: Engine wont start after rain and over night freeze December 26th 2020, 12:51 pm | |
| I think the fly wheel was frozen to the coil from the sounds of ice breaking and the belt was all good but idk it mightve just been a frozen belt im so happy i can drive it again! | |
