 8hp briggs wont start?
2 posters
greener179
greener179
8hp briggs wont start? Empty
PostSubject: 8hp briggs wont start?   8hp briggs wont start? Icon_minitimeJuly 17th 2012, 8:46 pm
i have a mongomery ward 8 with a 8hp briggs it was running i shut it off then it wouldnt crank over figured out it was a stuck intake valve freed it up and now it wont start is getting gas and spark any ideas?
arines 1988
PostSubject: Re: 8hp briggs wont start?   8hp briggs wont start? Icon_minitimeJuly 18th 2012, 2:08 pm
pull the plug and put your finger over the hole and spin it over to see if its got compression and if not pull the head and check to make sure the valves are working and see if they are closing all the way just a small gap will make it not run
greener179
greener179
PostSubject: Re: 8hp briggs wont start?   8hp briggs wont start? Icon_minitimeJuly 19th 2012, 3:42 am
ok will do its getting gas and spark but the gas goes right into the oil
arines 1988
PostSubject: Re: 8hp briggs wont start?   8hp briggs wont start? Icon_minitimeJuly 19th 2012, 7:28 am
the gas in to the oil sounds like the needle valve in the carb is not seating right and allowing gas to go in to the combustion chamber
greener179
greener179
PostSubject: Re: 8hp briggs wont start?   8hp briggs wont start? Icon_minitimeJuly 19th 2012, 12:44 pm
so try cleaning the carb and it like sprays gas out of the intake when trying to start it
arines 1988
PostSubject: Re: 8hp briggs wont start?   8hp briggs wont start? Icon_minitimeJuly 20th 2012, 8:27 am
how did the compression test go and it when i dont start when your trying is gas on the plug like its flooded if not pull the head ans check the intake valve to make sure its closeing
greener179
greener179
PostSubject: Re: 8hp briggs wont start?   8hp briggs wont start? Icon_minitimeJuly 20th 2012, 9:28 pm
forgot to test compression but intake valve closes i think but got it to start but shoots oil into oil making it not want to run
arines 1988
PostSubject: Re: 8hp briggs wont start?   8hp briggs wont start? Icon_minitimeJuly 22nd 2012, 8:03 am
try this pick up some carb cleaner and spray it in the inlet of the carb and see if it starts
greener179
greener179
PostSubject: Re: 8hp briggs wont start?   8hp briggs wont start? Icon_minitimeJuly 22nd 2012, 10:21 am
ok got it to start and stay running but smokes really bad any way to callm the smoke down with out honing the cyclinder
greener179
greener179
PostSubject: Re: 8hp briggs wont start?   8hp briggs wont start? Icon_minitimeJuly 22nd 2012, 11:41 pm
calmed the oil burning down with some thick oil but can get the air butterfly to work with the throttle everything is hooked up ok but the choke/air butterfly wont move witth it
greener179
greener179
PostSubject: Re: 8hp briggs wont start?   8hp briggs wont start? Icon_minitimeJuly 24th 2012, 1:49 pm
any idea how to get the choke butterfly working
» Briggs 13hp wont start
» 14.5 I/C Briggs wont start without starter fluid.
» 15.5 hp turbo cooled craftsman briggs and stratton wont start
» briggs 20hp no start/hard start
» B&S 14.5 OHV Wont start.
