| briggs 20hp no start/hard start | |
+3TheRainbowBoxer Thunderdivine ibdalovely1 7 posters |
ibdalovely1 Member
Age : 45 Join date : 2012-12-27 Points : 4469 Posts : 92 Location : dayton ohio
ibdalovely1 Member
| Subject: Re: briggs 20hp no start/hard start February 27th 2013, 5:20 pm | |
| looking around these twins all have some kind of starting issue and need a big battery gonna try the 2 battery trick to see if that will do it | |
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6545 Posts : 2101 Location : Norway, Europe
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5703 Posts : 1091 Location : Galion, OH
| Subject: Re: briggs 20hp no start/hard start February 27th 2013, 5:30 pm | |
| The 16.5HP Twin on my tractor cranks a lot easier than the old 14.5HP single I/C did on my old tractor. | |
| Subject: Re: briggs 20hp no start/hard start February 27th 2013, 5:34 pm | |
| And mind you it's not the size if the batteries that matter like Amp, but rather the CCA of the battery.
How much juice it will give you at 0F for 30seconds. | |
Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5256 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: briggs 20hp no start/hard start February 27th 2013, 5:54 pm | |
| - Thunderdivine wrote:
- And mind you it's not the size if the batteries that matter like Amp, but rather the CCA of the battery.
How much juice it will give you at 0F for 30seconds. Yup Always best to get the biggest Cold cranking amp capacity you can, especially in a colder climate. | |
ibdalovely1 Member
| Subject: Re: briggs 20hp no start/hard start February 27th 2013, 7:11 pm | |
| ive got the battery on charge its deff to small its a 230cca gonna have to look into something different
ibdalovely1 Member
| Subject: Re: briggs 20hp no start/hard start March 17th 2013, 4:27 pm | |
| well ive got it to run a little and i ended up dooing a pull start starter combo to doso im gonna need to clean the carb and prob rebuild the pump | |
ibdalovely1 Member
offroadredneck Member
Age : 26 Join date : 2013-01-03 Points : 4420 Posts : 64 Location : plantcity FL
| Subject: Re: briggs 20hp no start/hard start March 19th 2013, 10:34 am | |
| those opposed twins usually have a hard time starting with any thing less than 350amps. if that doesn't work than its the starter. mine had the same problem, even tried jump starting it off a truck with 2 800amp batteries, so I got a new starter from choo choo's for 90$. works great now. | |
truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5505 Posts : 1070
ibdalovely1 Member
mudmonkey06 Member
Age : 28 Join date : 2013-03-18 Points : 4596 Posts : 327 Location : Rindge, NH
