  Why wont the piston not go down far enough to let gas in on my 40 cc 2 stroke engine?
2 posters
noledroByrreK
noledroByrreK
 Why wont the piston not go down far enough to let gas in on my 40 cc 2 stroke engine? Empty
PostSubject: Why wont the piston not go down far enough to let gas in on my 40 cc 2 stroke engine?    Why wont the piston not go down far enough to let gas in on my 40 cc 2 stroke engine? Icon_minitimeMay 12th 2011, 5:38 pm
alright so on the 40 cc 2 stroke engine the piston will not go down far enough to let gas in. i took a video so yall could see what i mean.
as you can see it will go up and down but wont go any lower than the top of the intake manifold. i stuck my finger in ther and try to move it around and its not loose or wobbly or anything. any advice?
noledroByrreK
noledroByrreK
PostSubject: Re: Why wont the piston not go down far enough to let gas in on my 40 cc 2 stroke engine?    Why wont the piston not go down far enough to let gas in on my 40 cc 2 stroke engine? Icon_minitimeMay 12th 2011, 6:15 pm
oh and i know for sure the engine runs good because i just got it running with the carb off and dumping gas strait into the cylinder through the spark plug hole.
and it sounded pretty good to
DICE464
DICE464
PostSubject: Re: Why wont the piston not go down far enough to let gas in on my 40 cc 2 stroke engine?    Why wont the piston not go down far enough to let gas in on my 40 cc 2 stroke engine? Icon_minitimeMay 12th 2011, 9:21 pm
i want to say its supposed to do that but then how would it suck gas in through the carburater scratch
noledroByrreK
noledroByrreK
PostSubject: Re: Why wont the piston not go down far enough to let gas in on my 40 cc 2 stroke engine?    Why wont the piston not go down far enough to let gas in on my 40 cc 2 stroke engine? Icon_minitimeMay 12th 2011, 10:07 pm
yea u are right. i found out today that its not supposed to go down that far. it sucks gas underneath the piston then blows it through a tube to the top then fires.
but i still have a problem lol. it still wont start without pourin gas directly in the spark plug hole. so i guess its a carb problem but the carb is spotless
DICE464
DICE464
PostSubject: Re: Why wont the piston not go down far enough to let gas in on my 40 cc 2 stroke engine?    Why wont the piston not go down far enough to let gas in on my 40 cc 2 stroke engine? Icon_minitimeMay 13th 2011, 7:53 am
check all your gaskets and it it has a needle valve clean that and make sure nothings blocking it.
» ONAN 20hp horizontal shaft opposed piston engine diagrams
» How do I Prime my 4 stroke engine?
» 19.5 briggs engine wont run
» Engine wont turn over with spark plugs in.
» Engine wont start after rain and over night freeze
