 14.5 hp opposed twin wont run after first start
rarbaugh07
redneckjeff
9 posters
redneckjeff
redneckjeff
14.5 hp opposed twin wont run after first start  Empty
PostSubject: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeJanuary 24th 2014, 1:47 pm
I have a old roper with the 14.5hp opposed twin I picked up I cleaned the fuel tank and carb and I can get it to start for a couple seconds then it dies and I cant get it to start again till it sits for a while any suggestions.
rarbaugh07
rarbaugh07
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeJanuary 24th 2014, 1:53 pm
Sounds like its flooding and when it sits the fuel evaporates and it will restart. Check to to be sure float,needle and seat are working properly. Does it smell like gas?
redneckjeff
redneckjeff
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeJanuary 24th 2014, 1:58 pm
Thats what I thought to but ive pulled that carb off 5 times rechecking everything and I dont smell gas and the couple seconds it does run it doesn't seem like it has full power
redneckjeff
redneckjeff
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeJanuary 24th 2014, 1:59 pm
Its like it gets warm then says im done lol
rarbaugh07
rarbaugh07
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeJanuary 24th 2014, 2:16 pm
If it runs long enough to get warm then the coil could be bad. Sometimes when a wore out coil gets warm they will lose spark enough to kill the engine
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeJanuary 24th 2014, 2:21 pm
Hows the compression?
Hows the spark?
Does it run with Choke on, if yes, it don't get enough fuel. If no, check the carb again.
PostSubject: 14.5 hp opposed twin wont run after first start   14.5 hp opposed twin wont run after first start  Icon_minitimeJanuary 24th 2014, 3:27 pm
it is your coil. mine had the exact same problem.
redneckjeff
redneckjeff
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeJanuary 24th 2014, 4:08 pm
how much does a coil run and what should the compression be at I'll try to check that tonight when I get home
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeJanuary 24th 2014, 4:18 pm
Don't guess, test. As soon as it quits, do a spark test. If there's no spark, your coil is shot. It is very common for a coil to refuse to work once it get's hot. Bad winding.
PostSubject: 14.5 hp opposed twin wont run after first start   14.5 hp opposed twin wont run after first start  Icon_minitimeJanuary 24th 2014, 6:31 pm
mine had spark, but it wasn't enough.
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeJanuary 24th 2014, 8:48 pm
I'll take a swing at this one...
I'd bet it's the solenoid on the bottom of the carb bowl... If those are stuck, the engine will run until the bowl's empty, and then die. Take a screwdriver or something and tap on the side of it several times and then try starting it.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeJanuary 24th 2014, 9:09 pm
Did Oppys have the fuel solenoid? Thought that was pre-EPA?
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeJanuary 24th 2014, 9:30 pm
I THINK the last of them had the anti-afterfire solenoid, not 100% sure. I myself have not come across one.
redneckjeff
redneckjeff
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeJanuary 24th 2014, 10:25 pm
There is no solenoid on the carb Ill take a pic for you guys in the morning when i have daylight if that might help
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeJanuary 25th 2014, 11:59 am
when it doubt, check it out, check you float, I've had them bend enough to flood em out. Also, check your valves by pulling the sump cover if the compression is low. If the valves check out, check your head gasket, generally if its not blowing air out of the side, it is okay, If compression shows up good, check spark (i would actually check this first), you can do this by pulling the spark plug off and grounding the plug on the block and turning it over and watching the plug. Don't be a numb nut and get zapped... An engine needs 3 things to run, fuel (gas/air), compression, and a good spark. Your problem could always be the spark plugs. I've had numerous engines have issues and the problem was the spark plugs...
MowBandit
MowBandit
ive never ever ever seen a oppy with a screw on the bottom because the whole carb pretty much is the bowl to open it there are screws on the top that remove the top plate that allows you to pull the float out
redneckjeff
redneckjeff
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeFebruary 2nd 2014, 2:04 pm
Wow guys work takes alot of time away from me but im trying to go through all my tests you guys have offered but here is the engine info if it helps model#400707 type#0127-01 code#87021912 and does anyone know if this has a low engine oil shutoff that will let it run then not start
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeFebruary 2nd 2014, 2:53 pm
I don't think it has a low oil switch, but there's an easy way to rule it out. Locate the wire for the kill switch. Usually yellow, and exits the engine under the flywheel from the coil. Disconnect that wire. Attempt to start engine and/or check for spark.
redneckjeff
redneckjeff
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeFebruary 2nd 2014, 3:17 pm
Ok should it run or have spark with that disconnected
redneckjeff
redneckjeff
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeFebruary 2nd 2014, 4:48 pm
Well I just did a compression test and I guess the left or drivers side has about 30 lbs on the gauge and the other side has 70 lbs and have spark
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeFebruary 2nd 2014, 4:54 pm
With the kill wire disconnected, you SHOULD have spark.
And that compression test result is spooky- find out why. That said, it should still run on one cylinder.
redneckjeff
redneckjeff
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeFebruary 2nd 2014, 5:26 pm
I do still have spark with that wire disconnected and I was curious on the heads I took the tins off and tried the bolts and was able to turn them about a quarter turn with out forcing them so I dident strip them and I checked the compression again and the low side went up to 50 and the other side went up to 80 what should it normally be at
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeFebruary 2nd 2014, 5:46 pm
Briggs does NOT specify a compression figure, possibly because of compression relief mechanisms, etc. They do spec a comparator on the twins- the low cylinder must not be more than 25% off the value of the high cylinder.
redneckjeff
redneckjeff
PostSubject: Re: 14.5 hp opposed twin wont run after first start    14.5 hp opposed twin wont run after first start  Icon_minitimeFebruary 2nd 2014, 5:50 pm
Ok I think were ok on the 25 percent then so I started tinkering a little more and found out the fuel system froze up from sitting out side so but its in my shed now so I need to fix that now it seems like if it aint one thing its a other lol
PostSubject: 14.5 hp opposed twin wont run after first start   14.5 hp opposed twin wont run after first start  Icon_minitimeFebruary 3rd 2014, 11:25 am
pour some oil down the cylenders and see how much difference there is then. if that doesn't help, then your valves may have seating problems
» 18 hp Opposed twin wont turn over
» Adding a recoil start to your briggs opposed twin.
» Briggs 13hp wont start
» 14.5 I/C Briggs wont start without starter fluid.
» B&S 14.5 OHV Wont start.
