| LawnBoy UTLTV aka MULE | |
+41MoMower Craftsman1998 sadeoo7 kawasaki220 Angchor B440 breadtrk TroyBilt Pony Moose Lawren Wimberly camomanusa 83ratrodmurray WilliesBuilds T-Dub13 1997 Murray LAWN MOWER MUDDER Creepycrawler matt-man crazykid1994 willis923 TheBeal ripcord01 lawnmowerman MowBandit xxXMowerdudeXxx Ariens YT11 Stretch44875 motorizedeverything Doug WellThatsSurprising Nathan43 Jerbear0612 redlinemotorsportts tractorboy567 Chopperhed Thunderdivine Kel TheRainbowBoxer truckin42 richie thomas Doc Sprocket 45 posters |
Doc Sprocket Site VIP
| Subject: LawnBoy UTLTV aka MULE April 21st 2013, 10:18 pm | |
| UTLTV? Utility Lawn Tractor... Vehicle... Thing. LOL I recently picked up this '89 Lawn Boy LT12 for a song. 12hp Briggs L-Head, Peerless 900 series. Fixed the mangled starter, tore out the BS safety switches and wiring, new battery, and it lit right up. Have a slight bit of carb tweaking to do, but nothing out of the ordinary. I plan to make this thing fairly utilitarian. Cargo-carrying capacity, ATV tires, winch, lighting, a canopy (keep the rain off the wife) maybe a windshield. Bumpers, towing frame, couple gauges, toolbox, jerry can rack, etc. I'll post a pic of it as I got it, to begin with. It won't take much to bring you up to speed, I'm just at the beginning of this project.
Last edited by Doc Sprocket on October 13th 2013, 9:29 am; edited 1 time in total | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6400 Posts : 1434 Location : east dublin georgia
| Subject: Re: LawnBoy UTLTV aka MULE April 21st 2013, 10:23 pm | |
| looks like a good start man, ive got alot of tinted plexiglass, ive been debating on building a cab for the winter | |
truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5503 Posts : 1070
| Subject: Re: LawnBoy UTLTV aka MULE April 21st 2013, 10:26 pm | |
| - richie thomas wrote:
- looks like a good start man, ive got alot of tinted plexiglass, ive been debating on building a cab for the winter
Yeah iv always wanted to build a cab or somsort of thing for my mower. | |
| Subject: Re: LawnBoy UTLTV aka MULE April 22nd 2013, 5:18 am | |
| A cab would be cool. Buy when I say "canopy", picture a bimini top for a boat, or something like it. I plan on bending up a couple hoops from 3/4" EMT and the wife's got some of the neat waterproof camo fabris stuff. Sparing all the little details, this is where I'm at as of last night. I've installed an automotive volt meter and temp gauge, 145/70-6 ATV style front tires, and Kenda Scorpion 22x11-8 rears. I took it for a romp throught the mud and scrub and I was pretty impressed with the traction even with the open differential. I decided I wanted a box or trunk or try or something. I hacked off the fenders flush with the back of the frame, and tossed together a box out of 16ga sheet steel. To extend and compete the fenders, I cut up a steel trailer fender and narrowed the pieces. here's what it looks like as of last night. | |
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5701 Posts : 1091 Location : Galion, OH
Kel Member
Join date : 2013-03-06 Points : 4359 Posts : 75 Location : New Franken
Thunderdivine Veteran Member
| Subject: Re: LawnBoy UTLTV aka MULE April 22nd 2013, 7:47 pm | |
| Thanks fellas- I appreciate the props! Funny you should mention the cooler- My wife's best friend came over today while I was at work, and the first thing she said was "Can he make that into a cooler?" LOL
Bumpers are definitely going to happen. The rear is a cakewalk, but I'm having a rough time figuring out the front. When you tilt the hood, the whole grille shell rotates forward and down. This creates a serious problem. If I put the bumper where it should go, I wouldn't be able to open the hood.
In my mind, I have 3 options- 1) Change the hood pivots so that they attach to the bumper directly so instead of hitting it, the hood pivots over it. 2) Fix the hood to the bumper, and make the bumper pivot, so the whole thing will roll forward. 3)Cut the grille shell away from the hood, and solidly mount it. Then, I can either hinge the hood where it meets the grille shell, or to heck with the hinges- pop a couple pins, and the hood lifts off... Thoughts? | |
Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5254 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
tractorboy567 Member
Age : 26 Join date : 2013-01-02 Points : 4457 Posts : 121 Location : PA
| Subject: Re: LawnBoy UTLTV aka MULE April 23rd 2013, 6:49 am | |
| I'm trying to make a hinge for my hood, so that I can have it detachable. I'll have a pin on the dash to the grill and the such. Look around, some one made something. Or make it yourself I guess. | |
| Subject: Re: LawnBoy UTLTV aka MULE April 23rd 2013, 8:25 am | |
- I'm trying to make a hinge for my hood, so that I can have it detachable. I'll have a pin on the dash to the grill and the such. Look around, some one made something. Or make it yourself I guess.
Yeah or mabe hood pins. | |
Jerbear0612 Member
Age : 28 Join date : 2013-04-23 Points : 4343 Posts : 89 Location : Salem ct
| Subject: Re: LawnBoy UTLTV aka MULE April 23rd 2013, 3:59 pm | |
| My group has 3 rally tractors that are the same, and we did the hoods like this. We dumped the original hinge mechanism, pinned the grille with bolts so it no longer flips down, cut down the hood to make it so you won't snag your leg on it, and capped the raw steel with cheap windscreen trim. Yellow - Added hinges from hood to steering tower Red - Bolted Short Bungee straps (less than $1 apiece at the local discount store) to the hood. Green - Cut a slot in the grille side for the hook | |
| Subject: Re: LawnBoy UTLTV aka MULE April 23rd 2013, 4:07 pm | |
I guess. I think they'd be to loose tho | |
| Subject: Re: LawnBoy UTLTV aka MULE April 23rd 2013, 4:12 pm | |
I guess. I think they'd be to loose tho Yeah they might be iv never used em so i dont know. | |
| Subject: Re: LawnBoy UTLTV aka MULE April 23rd 2013, 4:34 pm | |
I guess. I think they'd be to loose tho Yeah they might be iv never used em so i dont know. Then whyd you suggest it? | |
| Subject: Re: LawnBoy UTLTV aka MULE April 23rd 2013, 4:49 pm | |
I guess. I think they'd be to loose tho Yeah they might be iv never used em so i dont know. Then whyd you suggest it? Because some peaple use em for the hood to hold em down. | |
| Subject: Re: LawnBoy UTLTV aka MULE April 23rd 2013, 10:01 pm | |
- really like the look of them fenders and box man, good work
Cant agree more. Those fenders were ment to be, it just, something about it looks so right. Great fab work! | |
| Subject: Re: LawnBoy UTLTV aka MULE April 24th 2013, 9:21 am | |
| Some good ideas with the hoods, guys, keep 'em coming! I'm really going to have to put some thought into it. Between the bumper/winch plans, and what I have in mind for the windshield/canopy front uprights, I really don't know... | |
| Subject: Re: LawnBoy UTLTV aka MULE April 24th 2013, 3:25 pm | |
| im using pins on mine, im going to build a bracket in the front for hood pins and put some rubber washers under it to keep it tight, and doing the same aft the back | |
| Subject: Re: LawnBoy UTLTV aka MULE April 24th 2013, 4:15 pm | |
| Rubber washers are a good idea. Foam weatherstripping tape would work well, too. You could make an adjustable pin by cutting the head off a shoulder bolt. On the pin mounting surface, you could drill the hole and tack weld a nut on the back side. Thread the pin in as far as you need to, and use a jam nut to keep it in place.
Last edited by Doc Sprocket on April 24th 2013, 6:18 pm; edited 1 time in total | |
