| LawnBoy UTLTV aka MULE | |
+41MoMower Craftsman1998 sadeoo7 kawasaki220 Angchor B440 breadtrk TroyBilt Pony Moose Lawren Wimberly camomanusa 83ratrodmurray WilliesBuilds T-Dub13 1997 Murray LAWN MOWER MUDDER Creepycrawler matt-man crazykid1994 willis923 TheBeal ripcord01 lawnmowerman MowBandit xxXMowerdudeXxx Ariens YT11 Stretch44875 motorizedeverything Doug WellThatsSurprising Nathan43 Jerbear0612 redlinemotorsportts tractorboy567 Chopperhed Thunderdivine Kel TheRainbowBoxer truckin42 richie thomas Doc Sprocket 45 posters | |
motorizedeverything Member
| | | | Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5703 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: LawnBoy UTLTV aka MULE May 6th 2013, 7:44 am | |
| With the winch and air compressor, are you thinking of a bigger alternator? I think the stock one is 3 or 5 amps. Our batteries don't charge well, and we are running just headlights and starting. Part of the problem is mowers run for hours at high rpm, and we run much lower rpms for shorter times.
I would recommend locking the axle. We have no problems turning with locked axles, and it performs more predicable off road, and better traction.
Any plans to go faster than stock?
Any other mower projects?
| | | Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7320 Posts : 2914 Location : Ontario Canada
| Subject: Re: LawnBoy UTLTV aka MULE May 6th 2013, 12:48 pm | |
| In no particular order...
Is there a bigger factory alternator available? I know the twins have some good charging options. Might go to a car battery too, at some point.
I was playing with the winch yesterday while keeping any eye on the voltmeter. As you would expect, I got the best results winching with the throttle (governor) maxed. I am planning a foot throttle, but am considering leaving some sort ov override on the dash to keep it pegged while using the accessories.
I will probably swap pullies for a top speed increase, but not by very much. My purpose is not speed. But it would be nice to get from A to B in less than an hour...
Speaking of speed- yes, I am building a racer. I'm probably about 60% done. The body is a 1980 Sears LT11-36. It now sports an 18hp Briggs Oppy twin, Peerless 700, 1 1/4" hollow chromoly axle, etc. | |
Age : 27 Join date : 2013-03-18 Points : 7485 Posts : 3131 Location : raleigh nc
| Subject: Re: LawnBoy UTLTV aka MULE May 6th 2013, 2:44 pm | |
| I have 21" tires rear, and running 3 1/2" front 4 rear, and gained 4-5 mph. But I did swap out the fnr axle so I guess a setup like yours would be different. I really like this tractor. | |
| | | truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5505 Posts : 1070
| Subject: Re: LawnBoy UTLTV aka MULE May 6th 2013, 5:29 pm | |
| Thanks fellas... Yeah- the air is a neat option. No sooner did I install it, I got to use it. My younger son wanted to ride his minibike, and as he went down the driveway (1000ft long) I saw that his rear tire was really mushy. So, I drove down and met him, and 10 seconds later, all was good... | |
Age : 26 Join date : 2013-01-02 Points : 4703 Posts : 356
| Subject: Re: LawnBoy UTLTV aka MULE May 6th 2013, 8:58 pm | |
| Funny you mention that. I have a couple inverters and was thinking about it. Weather and temperature might be an issue. I can mount one in a weatherproof ammo can, but that does not solve extreme temperatures. | |
| Subject: Re: LawnBoy UTLTV aka MULE May 6th 2013, 9:03 pm | |
| you could put it on the inside of the hood and have a few small battery operated fans cool it down | |
| Subject: Re: LawnBoy UTLTV aka MULE May 6th 2013, 9:12 pm | |
| [quote="Doc Sprocket"]Heat is only half the problem. I live in Canada... LOL[/quote\
ok whell the hood should keep it dry and the heat from the engine should keep it worm but tape a pice of paper under the hood and use that to see if there is any water getting up under the hood | |
| Subject: Re: LawnBoy UTLTV aka MULE May 6th 2013, 9:17 pm | |
| Water? Probably... to test the winch, I backed it into the pond yesterday....lol
Will put some thought into it, but I have to decide if it's worth the aggravation. The 400 watt wont run much, the 1000 watt is likely too much electrical load. I gotta check the specs, I don't remember how many amps it draws at full load. | |
| | | Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5256 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: LawnBoy UTLTV aka MULE May 6th 2013, 9:18 pm | |
| [quote="motorizedeverything"] - Doc Sprocket wrote:
- Heat is only half the problem. I live in Canada... LOL[/quote\
ok whell the hood should keep it dry and the heat from the engine should keep it worm but tape a pice of paper under the hood and use that to see if there is any water getting up under the hood So do I, hit 28C here today. | |
| Subject: Re: LawnBoy UTLTV aka MULE May 6th 2013, 9:19 pm | |
| or you could use the amo can and put a little computer fan on the top to remove the heat
| Subject: Re: LawnBoy UTLTV aka MULE May 6th 2013, 9:23 pm | |
| Fan cooled ammo can? Neat idea!
Yeah, it was pretty damned toasty in Toronto today. I was working in the sun all day, and am pretty much toasted. Didn't help that I burnt myself yesterday working on this. | |
| Subject: Re: LawnBoy UTLTV aka MULE May 6th 2013, 9:42 pm | |
| what i would do is have the inverter plug in to were you have the jumper cables plug in | |
| Subject: Re: LawnBoy UTLTV aka MULE May 6th 2013, 10:25 pm | |
| Yea I live the fingerlakes of newyork and it is very nice these past days! | |
| | | Ariens YT11 Established Member
Age : 27 Join date : 2012-10-31 Points : 5166 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Re: LawnBoy UTLTV aka MULE May 7th 2013, 11:49 am | |
| I'm going to make you guys jelous its 80+ the last few days here in Western Washington | |
| Subject: Re: LawnBoy UTLTV aka MULE May 7th 2013, 12:17 pm | |
| - Ariens YT11 wrote:
- I'm going to make you guys jelous its 80+ the last few days here in Western Washington
It hast been in the 80s here yet but it has a couple times but here lately it been in the 60-75s the last coulpe weeks. | |
| Subject: Re: LawnBoy UTLTV aka MULE May 7th 2013, 12:38 pm | |
It hast been in the 80s here yet but it has a couple times but here lately it been in the 60-75s the last coulpe weeks. its been really nice in south louisiana mid 80s | |
| Subject: Re: LawnBoy UTLTV aka MULE May 7th 2013, 12:51 pm | |
| Yeah... it's nice until you're stuck working outside for 3 days with no clouds and no shade. I am absolutely baked... Back on topic, I think the engine ate a bearing the other evening. I'm pissed. Plain bearing engine too, so if a bearing bore is done, so is the block. Dammitall. I'm gonna rip into it this weekend and see. All of a sudden it started running really hot and shutting down. Oil appeared broken down and glimmered in the catch pan. No big metal particles, but kind of resembled a pan of metallic paint. | |
Age : 49 Join date : 2012-04-23 Points : 5703 Posts : 1091 Location : Galion, OH
| Subject: Re: LawnBoy UTLTV aka MULE May 7th 2013, 5:10 pm | |
| Well... like I said- it's a plain bearing block so if the bearing is done, the block is done. Whatever is wrong is wrong, so I have already put an ad out looking for a parts engine.
Another option might be a basket case 16hp oppy twin I bought for parts for my racer. It's missing a couple things like the governor, and I've never run it but it might be an idea. Be a shame to have to redo the winch and the exhaust after I just finished it...
| Who is online? | In total there are 51 users online :: 0 Registered, 0 Hidden and 51 Guests
