| HH120 still a no go! | |
BlackMountian88 Member
Age : 25 Join date : 2012-09-08 Points : 4890 Posts : 399 Location : NH
| Subject: HH120 still a no go! September 26th 2013, 2:31 pm | |
| Hey guys. Well myHH120 is still defunct. But, I have new symptoms! I've pulled the motor out of the tractor, and I've been trying to pull start it. And it will give a big kick, like valve timing. Is there a way to visually check it by taking the head off? I took the head off, and it appears to be opening and closing at the correct times. Also, it's leaking oil quite a bit from the main crankcase gasket, as if maybe it's been opened before, and the "opener" ripped it? Also, this is what I mean when I say the piston is deformed and scorched: The head also looks like this. Any idea why? Thanks, BM88 | |
| | | xxXMowerdudeXxx Established Member
| Subject: Re: HH120 still a no go! September 26th 2013, 3:47 pm | |
| Hey, that looks like a briggs i had once, a screw in the carb came out, and got sucked in, looks like it was in there quite a while, check the muffler, see if anythings in it. Ps u may need new head piston or rings | |
| Subject: Re: HH120 still a no go! September 26th 2013, 4:00 pm | |
| Crap that's not what I wanted to hear.
I can't take the muffler off, it's modified, and welded in.
Do you know how this would affect the motor's performance? | |
| Subject: Re: HH120 still a no go! September 26th 2013, 4:44 pm | |
| - BlackMountian88 wrote:
- Crap that's not what I wanted to hear.
Do you know how this would affect the motor's performance? Its not sucking in as much gas and air, and when t burns it doesn't get rid of it as much. compression test? | |
| Subject: Re: HH120 still a no go! September 26th 2013, 4:47 pm | |
| It's got 100psi of compression, and plenty of vacuum (I had a rag stuck in the carb, and it accidentally sucked it right up!). | |
| Who is online? | In total there are 5 users online :: 0 Registered, 0 Hidden and 5 Guests
