Here's a quick vid of my 17 HP Briggs OHV motor cranking. Not sure if it's the fuel shutoff solenoid, water in the carb, valves out of adjustment, or what. Any suggestions?
gearheadmike Member
Age : 34 Join date : 2011-11-18 Points : 5203 Posts : 392 Location : west chazy ny
idk to me it looks like alot of fuel is in the carb when its cranking ,id take drain the tank along with carb bowl ,put fresh gas in is then try it did u check for fire? and again might be me but kinda sounds like it dont have much compression? i seen on youtube a gay had bad compression on his ohv and it ended up being the rocker came off and bent a push rod he replaced that and it was fixed. good luck
dagr8tim Member
Age : 48 Join date : 2012-01-01 Points : 4938 Posts : 194 Location : Columbus, Oh
Thanks, it did backfire up through the carb once. I had also sprayed some WD40 into the carb before I shot that video because I didn't have any spare gas and I wanted to see if it would run off of priming.
I think I'm going to snag a set of feeler gauges today and check the rocker clearance. I'm still holding out hope that the carb is full of water.
gearheadmike Member
just a little heads up on the wd40, they changed the formula about 10 years ago. I havent had much luck starting one on wd40 since then. If I done have either, I use carb cleaner.
