| Briggs and Stratton 5hp problems | |
THE MTD GUY Member
Age : 27 Join date : 2013-02-15 Points : 4370 Posts : 69
| Subject: Briggs and Stratton 5hp problems February 22nd 2013, 12:55 pm | |
| my dad has this 5hp tiller. use to run great. he stopped using it cause he got a rear tine tiller. last week he cleaned the points and it wouldnt start. it had spark, but no gas. so he cleaned the carb and put a new diaphram in the carb. she started right up, but when we went out to till, when it leans to on side, it cuts out and acts like shes starvin fr gas. the pipe that goes in the take was cracked, so we put a knew 1 in. but it does the same thing. it only does this when the engine is not level. any suggestions? | |
| | | Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5254 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| | | | Tractor Man Jeff Moderator
Age : 29 Join date : 2012-06-26 Points : 5013 Posts : 492 Location : Back in the sticks of VA
| Subject: Re: Briggs and Stratton 5hp problems February 22nd 2013, 4:05 pm | |
| Mine does a similar thing which has me stumped. It will be running great until it gets really bouncing around. Then it will start reving up and down with no power. The only way to stop it is to pull the choke almost completely out. Adjusting the carb did nothing. Once I clean the carb, i'll see what it does then. Does it stop when it's level again? | |
| | | THE MTD GUY Member
| Subject: Re: Briggs and Stratton 5hp problems February 22nd 2013, 9:10 pm | |
| - Tractor Man Jeff wrote:
- Mine does a similar thing which has me stumped. It will be running great until it gets really bouncing around. Then it will start reving up and down with no power. The only way to stop it is to pull the choke almost completely out. Adjusting the carb did nothing. Once I clean the carb, i'll see what it does then. Does it stop when it's level again?
sometimes it will stop, but sometimes it dies. | |
| | | THE MTD GUY Member
| Subject: Re: Briggs and Stratton 5hp problems February 22nd 2013, 10:44 pm | |
| - THE MTD GUY wrote:
- Chopperhed wrote:
- check the float level
its a vacu jet carb I need info, Vacu jet is a term I haven't heard. Any kind of a diagram or part number, and I can figure it out. | |
| Who is online? | In total there are 78 users online :: 0 Registered, 0 Hidden and 78 Guests
