| 16.5hp Briggs and Stratton opposed | |
+3RichieRichOverdrive Caddy_V3 Kleatus 7 posters |
Kleatus Member
Age : 22 Join date : 2016-11-07 Points : 3013 Posts : 54 Location : Memphis tn
Caddy_V3 Member
Age : 24 Join date : 2015-07-10 Points : 3524 Posts : 56 Location : Derry NH
| Subject: Re: 16.5hp Briggs and Stratton opposed February 15th 2017, 4:25 pm | |
| My old snaper with the 12 horse apposed did not have rod kock it just ate a LOT of oil. I knwe the rings were going to go but it still had enough compression. | |
Age : 22 Join date : 2016-10-29 Points : 7210 Posts : 4013 Location : Lewisburg, KY
Age : 25 Join date : 2016-07-10 Points : 8583 Posts : 5190 Location : Ontario Canada
| Subject: Re: 16.5hp Briggs and Stratton opposed February 15th 2017, 6:42 pm | |
| I'm no expert on oppy's, but I'd imagine the camshafts in them are steel unlike modern plastic small engine cams. The sound you hear could just be valve train clatter. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5749 Posts : 1993 Location : Northern Ireland
| Subject: Re: 16.5hp Briggs and Stratton opposed February 15th 2017, 6:52 pm | |
| Most of my flat head Briggs's are 'clattery'. It sounds a little like a rod knock but less pronounced. Your engine could just be worn out internally. | |
Age : 34 Join date : 2013-11-02 Points : 7165 Posts : 2910 Location : New Jersey USA
| Subject: Re: 16.5hp Briggs and Stratton opposed February 15th 2017, 7:10 pm | |
| Yes, my opposed I put together for my GTR mini tractor has a knocking type noise and I even plastigauged the rods when I was putting it together. Redlinemotorsports also had a knocking in his opposed on the MTD, took the cover off and wiggled the rods without issue. I think it must be valve noise in these. Unless it gets louder or is extremely heavy/loud sounding I wouldn't worry about it. | |
Kleatus Member
| Subject: Opposed February 15th 2017, 8:18 pm | |
| Thanks for the help I took the heads off of it and was devastated it always smoked a little when you rev well I did a oil change and it went to knocking and smoking so bad I thought I was gonna die of inhaling so much smoke but anyway I took the heads off and both the head gaskets were blown the valve guides are wore the cylinders were scared and the piston has tons of slop in it I found all this hard to believe with it only having 150 hours on it so I'm just gonna take it off and put a Kohler magnum on it for now | |
Kleatus Member
| Subject: Opposed February 15th 2017, 10:13 pm | |
| I'll problably rebuild it one day you wouldn't know which wire on a Kohler magnum would charge the battery would you | |
