 16hp Briggs and Stratton opposed twin shaving the head
243generallee
243generallee
16hp Briggs and Stratton opposed twin shaving the head  Empty
PostSubject: 16hp Briggs and Stratton opposed twin shaving the head    16hp Briggs and Stratton opposed twin shaving the head  Icon_minitimeMarch 5th 2013, 3:59 pm
im working at a milling shop now and i am using the mill and would like to shave the head on my racing lawnmower motor im not sure how many thousandths i should take off so i dont blow a head gasket or break the heads of the head bolts off can someone tell me whats the best amount to take off?
Marines2621
Marines2621
PostSubject: Re: 16hp Briggs and Stratton opposed twin shaving the head    16hp Briggs and Stratton opposed twin shaving the head  Icon_minitimeMarch 5th 2013, 10:01 pm
U would have to really look into that cause of how far the head bolts go down. Will have smaller combustion chamber if u shave it down. I really wouldn't know about that.
Marines2621
Marines2621
PostSubject: Re: 16hp Briggs and Stratton opposed twin shaving the head    16hp Briggs and Stratton opposed twin shaving the head  Icon_minitimeMarch 5th 2013, 10:02 pm
Also thing about if u shaved it down it could bust the head cause of pressure.
Chopperhed
Chopperhed
PostSubject: Re: 16hp Briggs and Stratton opposed twin shaving the head    16hp Briggs and Stratton opposed twin shaving the head  Icon_minitimeMarch 5th 2013, 10:46 pm
Start at .005" and see what happens, measure the depth of your stud holes to make sure you can get proper clamp.
On OHV engines if you take too much you may have to mill the pistons to allow for valve clearance.
On Flatheads, the problem is similar and different at the same time. you need to open up the area above the valve to allow for flow and valve clearance.
Chopperhed
Chopperhed
PostSubject: Re: 16hp Briggs and Stratton opposed twin shaving the head    16hp Briggs and Stratton opposed twin shaving the head  Icon_minitimeMarch 5th 2013, 10:51 pm
And this would be the time to start looking at Higher octane fuels.
PostSubject: Re: 16hp Briggs and Stratton opposed twin shaving the head    16hp Briggs and Stratton opposed twin shaving the head  Icon_minitimeMarch 6th 2013, 1:53 pm
Don't bother, to risky if you ask me. You can always shim it after you take to much off tho but still.
PostSubject: as opposed to shaving the head   16hp Briggs and Stratton opposed twin shaving the head  Icon_minitimeApril 2nd 2013, 12:47 am
One could also use a small die grinder (dremel etc) to put the 'fire slot' into the heads of the briggs flatties. I use that trick rather than shave heads. Doesn't up the compression but allows for a much better spark to be funneled to the combustion chamber (since there is a slight but noticeable offset between combustion chamber and spark plug location on the flattie). With a tuned carb and a good hot spark (I use E3 plugs for such a mod) one can gain a hp or more doing it, sometimes even more than that depending on other mods, fuel/additives used etc.
I understand now it's an aftermarket thing for smaller briggs engine mods, but its much easier to do it yourself (and a heck of a lot cheaper). Just use a copper gasket (or get the material and make your own like I do) and you're off and running...
» Briggs and Stratton 16hp opposed twin questions
» Briggs and Stratton Opposed Twin Q/A 's!
» Does anyone have a Briggs Opposed Twin L-Head not mounted?
» 11 1/2 hp briggs flat head / 18 1/2 opposed twin question also
» Briggs & Stratton Opposed Twin Engine Questions
