| | Im having trouble starting my 14 hp I/C OHV motor. | |
Salt-Man New Member
![Im having trouble starting my 14 hp I/C OHV motor. Empty](https://2img.net/i/empty.gif) | Subject: Im having trouble starting my 14 hp I/C OHV motor. July 18th 2010, 4:35 pm | |
| I just went and bought a NOMA rider with a 14 hp I/C OHV motor, it was missing the carb, battery + ignition switch and starter was froze up, so I replaced all that , but it will not turn over by the key ? I took the seat safty switch and wired those 2 wires together and eliminated it, still won't turn over ? I found a blown fuse so I hot wired it, still nothing ? so I jumped it at the solenoid with the key ON , spins over great but no fire ? so I pulled the plug wire and stuck a screw driver in it and cranked it over, no spark ? what now ? pull the top cover off and check for rust on the fly wheel and stater/ pick-up ?? ( I don't remember what its called ? ![scratch](https://2img.net/i/fa/i/smiles/icon_scratch.png) ) I got this for $125 and it came with a 16.5 hp I/C OHV motor for my other tractor too so I still happy with the deal but I really need them both running, rack your brains and see if you can help-a-brother out ![Suspect](https://2img.net/i/fa/i/smiles/suspect.gif) I'll get the other motor swapped out and get back to ya, thanks dudes | |
| ![Go down](https://2img.net/i/empty.gif) | | dangeroustoys56 Veteran Member
![dangeroustoys56](https://2img.net/u/2812/37/66/46/avatars/4-60.jpg)
Age : 53 Join date : 2010-02-10 Points : 7002 Posts : 1726 Location : Florida, USA
![Im having trouble starting my 14 hp I/C OHV motor. Empty](https://2img.net/i/empty.gif) | Subject: Re: Im having trouble starting my 14 hp I/C OHV motor. July 18th 2010, 5:27 pm | |
| Try this - unhook all the wires ( cept for the battery cable to the starter) to the motor, specially the magneto kill wire- then try n start it - if it still has no spark, then it might need a new magneto - its not old enough to have points- try cleaning the flywheel and magneto ends and gapping the magneto as well ( gap thickness is a cardbord container for an oil filter) . Also change the spark plug while youre at it. If that doesnt do it, then youll need a new magneto.
The no start with the key is either the fuse ( as you found out) or the starter solenoid is bad- thatll need replacing as well. | |
| ![Go down](https://2img.net/i/empty.gif) | | Chunk Established Member
![Chunk](https://2img.net/u/2812/37/66/46/avatars/2-3.jpg)
Age : 33 Join date : 2010-02-10 Points : 6146 Posts : 779 Location : Angus, Scotland
![Im having trouble starting my 14 hp I/C OHV motor. Empty](https://2img.net/i/empty.gif) | Subject: Re: Im having trouble starting my 14 hp I/C OHV motor. July 18th 2010, 5:52 pm | |
| Again, totally disconnect the wire from the coil. Stick the plug in but leave it against the block (out the spark plug hole though) and make sure its grounding the plug. Then spin it over straight to the starter. If it still doesnt have spark, you'll probably need a new coil. Won't be much for a single coil. Hope that helps you with the no spark. As for the key problem, one of the wires to the key will be a live, my Rally didnt work with the key most of the time I had it. I started tinkering with the wire while it was up for sale and turned out the live wire was broken somewhere down the line. Probably be easier to re-wwire it just for basic operation (starting, charging and killing) Got any photos of the Noma? My mudder started as a Noma based machine. | |
| ![Go down](https://2img.net/i/empty.gif) | | Salt-Man New Member
![Im having trouble starting my 14 hp I/C OHV motor. Empty](https://2img.net/i/empty.gif) | Subject: Re: Im having trouble starting my 14 hp I/C OHV motor. July 18th 2010, 7:47 pm | |
| yea I was thinking about just throwing a start button and toggle switch on it and eliminate the key switch, but perhaps you can in-lighten me as to how the charging system works on these ??? ![scratch](https://2img.net/i/fa/i/smiles/icon_scratch.png) ??? I haven't looked into it yet I figuered you guys could tell me, I figure i will put the motor on the other one tomorrow then get back to this one, I will take pictures then too, thanks for all the help. because of this site I am gaining a whole new respect for my lawnmower | |
![Im having trouble starting my 14 hp I/C OHV motor. Empty](https://2img.net/i/empty.gif) | Subject: Re: Im having trouble starting my 14 hp I/C OHV motor. July 19th 2010, 4:20 am | |
| There's two wires that come from under the flywheel. 1 is for the lights, and the other is charging. I've rewired a tractor from scratch. All a did was run that straight to the +ve of the battery. Maybe not the best way to do it. Could probably have done with a fuse. | |
![Im having trouble starting my 14 hp I/C OHV motor. Empty](https://2img.net/i/empty.gif) | Subject: Re: Im having trouble starting my 14 hp I/C OHV motor. July 19th 2010, 7:02 am | |
| I posted a wiring diagram in the engine tech thread to give you an idea how a tractor is wired.
The ign switch basically uses the same power as the stator ( ign switch needs to be powered in order to start the tractor) - ive had a few instances where the diode is bad and almost fried the stators ( diode is the 'switch' to just let power out from the stator , not in).
Does that motor have a antifire solenoid? Ive had some issues with the one on my 03 murray- a simple fix was to snip the end off that goes into the carb- effectively bypassing it- it would chug and 'diesel' when i shut it down, rev up and down when i was mowing - now that i did that mod- it runs smooth, shuts down normal. | |
![Im having trouble starting my 14 hp I/C OHV motor. Empty](https://2img.net/i/empty.gif) | Subject: Re: Im having trouble starting my 14 hp I/C OHV motor. July 19th 2010, 1:49 pm | |
| the carb that was on it may have had one but it was missing the float bowl so I cant be sure, I just replaced the carb with the one that was on the mower I just bought with the blown motor ( it was fresh carnage ![What a Face](https://2img.net/i/fa/i/smiles/fresse.png) ) but there is a wire that was laying there so probably, I'll get that diagram and get back to ya, I slept till noon today so I don't know what I'll get done today ???? OK Got it thanks.. I'll get back to ya soon | |
![Im having trouble starting my 14 hp I/C OHV motor. Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Chunk Established Member
![Im having trouble starting my 14 hp I/C OHV motor. Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Salt-Man New Member
![Im having trouble starting my 14 hp I/C OHV motor. Empty](https://2img.net/i/empty.gif) | Subject: Re: Im having trouble starting my 14 hp I/C OHV motor. July 27th 2010, 7:11 pm | |
| i re wired the noma and got it running , still have to finish it up but atleast she runs , i built a drag pipe style exhaust but ran out of welding wire before i could finish , i should have it done in a few days | |
![Im having trouble starting my 14 hp I/C OHV motor. Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | Im having trouble starting my 14 hp I/C OHV motor. | |
| Who is online? | In total there are 43 users online :: 0 Registered, 0 Hidden and 43 Guests
