| | Im having trouble with my 12hp briggs starting. | |
SoaresMudder94 Member
![SoaresMudder94](https://2img.net/u/2812/37/66/46/avatars/79-69.jpg)
Age : 30 Join date : 2010-11-07 Points : 5151 Posts : 59 Location : ayr ontario canada
![Im having trouble with my 12hp briggs starting. Empty](https://2img.net/i/empty.gif) | Subject: Im having trouble with my 12hp briggs starting. November 7th 2010, 9:49 pm | |
| Hello there guys. i am currently building a mudder/offroad tractor. i used it all of last week with no problems then 2 days ago. it was running amazing still yesterday i did not use it. but then today i went to go out for a ride. it would not start. it cranks good, theres good spark. i cleaned the carb, checkd valves. everything seems to be ok. but i think that the intake is not letting gass go into the intake to fire the engine. but there is a good gas flow. it is new gas aswell. Help needed. thanks | |
| ![Go down](https://2img.net/i/empty.gif) | | dangeroustoys56 Veteran Member
![dangeroustoys56](https://2img.net/u/2812/37/66/46/avatars/4-60.jpg)
Age : 53 Join date : 2010-02-10 Points : 7002 Posts : 1726 Location : Florida, USA
![Im having trouble with my 12hp briggs starting. Empty](https://2img.net/i/empty.gif) | Subject: Re: Im having trouble with my 12hp briggs starting. November 8th 2010, 1:01 am | |
| Check the gas line and if theres a fuel filter- check that as well. If theyre old, change em. I had a curious issue with my one dynamark- kept having fuel issues, turns out the port from the gas tank ( where fuel line hooks) was crushed when i used a hose clamp on it- i took the tank off, put a small piece of copper tubing in there and it fixed the issue.
As a fluke- disconnect the magneto kill wire and see if it starts- if it does, the ign switch might be bad ( that happened as well on the same tractor). | |
| ![Go down](https://2img.net/i/empty.gif) | | Ford Boi Member
![Ford Boi](https://2img.net/u/2812/37/66/46/avatars/63-77.jpg)
Age : 39 Join date : 2010-08-22 Points : 5394 Posts : 242 Location : Yarmouth, Nova Scotia, Canada
![Im having trouble with my 12hp briggs starting. Empty](https://2img.net/i/empty.gif) | Subject: Re: Im having trouble with my 12hp briggs starting. November 8th 2010, 11:15 am | |
| Make sure there's no water in the system, that always seems to be a silent killer. And check the flywheel key- is that's broken you'll get your spark but at the wrong time. | |
![Im having trouble with my 12hp briggs starting. Empty](https://2img.net/i/empty.gif) | Subject: Re: Im having trouble with my 12hp briggs starting. November 8th 2010, 1:21 pm | |
| good point- forgot about those things - i had a RER with a broken flywheel key - thing was 180 degrees off, would suck in air thru the muffler and exhaust thru the carb .... water in the gas is another annoying issue as well . | |
| ![Go down](https://2img.net/i/empty.gif) | | SoaresMudder94 Member
![Im having trouble with my 12hp briggs starting. Empty](https://2img.net/i/empty.gif) | Subject: got er goin! November 8th 2010, 8:34 pm | |
| UPDATE: Thanks for everyones help, it was none of those tho, i tryed all of them and none of them worked and everything was ok. so i said **** it and i grabedd the gas tank n filled the carb up to the top n turned it overr. she turned on and stayed running for over 30 mins and i turned it off and on high revs low revs. so i am guessing the day it sat.. all the fuel got outta the system and the choke may not be working properly? but i got it going just by given her a prime thanks for everyones help (Y) | |
| ![Go down](https://2img.net/i/empty.gif) | | Trcustoms Member
![Trcustoms](https://2img.net/u/2812/37/66/46/avatars/67-34.jpg)
Join date : 2010-09-19 Points : 5335 Posts : 225 Location : Bear,De USA
![Im having trouble with my 12hp briggs starting. Empty](https://2img.net/i/empty.gif) | Subject: Re: Im having trouble with my 12hp briggs starting. November 8th 2010, 10:49 pm | |
| - SoaresMudder94 wrote:
- UPDATE:
Thanks for everyones help, it was none of those tho, i tryed all of them and none of them worked and everything was ok. so i said **** it and i grabedd the gas tank n filled the carb up to the top n turned it overr. she turned on and stayed running for over 30 mins and i turned it off and on high revs low revs. so i am guessing the day it sat.. all the fuel got outta the system and the choke may not be working properly? but i got it going just by given her a prime thanks for everyones help (Y) Yeah, some times old briggs don't like the cold, if the choke wasn't working then it never would have started without a prime. | |
![Im having trouble with my 12hp briggs starting. Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | Im having trouble with my 12hp briggs starting. | |
| Who is online? | In total there are 54 users online :: 0 Registered, 0 Hidden and 54 Guests
