| 12hp Briggs flathead gas pedal | |
Carshowkid Member
Age : 25 Join date : 2014-07-22 Points : 4168 Posts : 347 Location : Downers Grove Illinois
| Subject: 12hp Briggs flathead gas pedal July 27th 2016, 9:43 pm | |
| how would you guys/gals rig up a gas pedal for this? The cable zig zags into the little plastic box? Cut and bend then attach gas pedal cable to it? Can't figure out a way... | |
| Subject: Re: 12hp Briggs flathead gas pedal July 27th 2016, 11:18 pm | |
| Here is what I've done a couple times now. Have the cable attach to a solid piece. In my case, I had a bicycle brake or shifter cable with an end on it (barrel or whatever it's called). Anyway, I bent up a stock lawn mower carb rod so the one end of course fits into the throttle. The other end I bend around so it forms a hook. Then you need a small nut that just barely fits over the cable end. You slide the nut over the cable end and then put the hook through. Once the hook is through it can't fit back off the cable. You can also loop the cable and crimp it with aluminum things which are made for cable. Avaliable at home depot or lowes near the cable and rope. I don't have a pic or know exactly what they are called, but they're just a small aluminum thing with space for two cables to fit through. They come in different sizes for various cables. Then once everything is adjusted and hooked in, the cable can't fall out. | |
| Who is online? | In total there are 31 users online :: 0 Registered, 0 Hidden and 31 Guests
