 Briggs 12hp flatty oil
Carshowkid
Carshowkid
Briggs 12hp flatty oil Empty
PostSubject: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 20th 2015, 6:31 pm
What kind of oil would a 12 hp briggs and stratton flatly take?... I've heard guys put 5w30 10w30... I would think either would be ok... But just want to make sure...
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 20th 2015, 7:27 pm
winter time 5w-30 summer 10w-30 just make sure the oil is sae and you will be find i run walmart oil in mine and seem to do just find
Carshowkid
Carshowkid
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 20th 2015, 7:32 pm
Could I do 5w30 or 10w30 all year round?
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 21st 2015, 3:23 pm
I usually use 10W30 year round.
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 21st 2015, 3:25 pm
All motor oil is "SAE". SAE is the Society of Automotive Engineers, and is the governing body that sets and maintains the standards for viscosity. SAE 10W30 for example means: "This oil is a 10-30W multigrade as defined by the Society of Automotive Engineers". The SAE marking on a bottle of oil does NOT indicate quality, nor does it indicate whether that particular oil is suitable for your application. In other words, you can pick up a bottle of oil that will bear the SAE logo, but that does NOT mean it's the right stuff for your engine.
Last edited by Doc Sprocket on February 21st 2015, 4:10 pm; edited 1 time in total
Carshowkid
Carshowkid
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 21st 2015, 3:35 pm
Ok I will get sae oil...
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 21st 2015, 3:52 pm
Did you read anything I wrote?
Carshowkid
Carshowkid
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 21st 2015, 3:55 pm
lol yes... But I got confused... Cause all oil is sae... Cause it's the society of automobile engineers
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 21st 2015, 4:04 pm
Go back and re-read both posts I just made. Slowly.
Carshowkid
Carshowkid
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 21st 2015, 4:12 pm
On so I didn't see your post saying 10w30 year round... And all motor oil is sae cause that company that maintains the standard of viscosity... Sorry your second post was a little confusing... And now I understand what you ment...
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 21st 2015, 4:21 pm
Good stuff.
Carshowkid
Carshowkid
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 21st 2015, 4:44 pm
Sorry... Understanding things I read isn't one of my best Qualtys... But thanks for the help!
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 21st 2015, 4:57 pm
You're welcome. Don't forget that if you (or anyone else) needs a wee bit of extra help, you can always hit me up through PM or FB.
Carshowkid
Carshowkid
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 21st 2015, 5:25 pm
okie dokie!! Thanks for the help! And if you may know my 12 hp briggs flathead has a chewed coil wire... Would any one work or would it just need to be a coil with a single wire?
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 21st 2015, 5:39 pm
A coil for any engine from the same series will work.
Carshowkid
Carshowkid
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 21st 2015, 5:41 pm
... How would I know what series my engine is?
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 21st 2015, 5:44 pm
Best way would be to find out the part number for your coil. Then you can google the part number and find out all the other engines it fits.
Last edited by Doc Sprocket on February 21st 2015, 6:58 pm; edited 1 time in total
Carshowkid
Carshowkid
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 21st 2015, 5:49 pm
Doc Sprocket wrote:
Best way would be to find out the part number for your coil. Then you can google the part umber and find out all the other engines it fits.
okay! Thanks!
Carshowkid
Carshowkid
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 21st 2015, 7:33 pm
Is a 12hp briggs a "L head"?
willysjeepmb
willysjeepmb
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 26th 2015, 3:19 pm
All flat heads are L head?
Carshowkid
Carshowkid
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 26th 2015, 4:36 pm
ok thanks! Cause I didn't know that
PostSubject: Re: Briggs 12hp flatty oil   Briggs 12hp flatty oil Icon_minitimeFebruary 27th 2015, 2:09 pm
Gravely walk behind tractors used T head engines. One valve on each side of the cylinder. Probably other examples of this on early car engines ect. but I don't know.
Briggs 12hp flatty oil Images?q=tbn:ANd9GcTRxQ6feNis_hzqQa7D53l8kBsct_BYeEsaWE5lwMHzYgt8ALZu
» Briggs Flatty Low-Buck Buildup
» 11hp briggs flatty would be fine for an offroad mower, but how well would it turn a mowing deck?
» Briggs 12hp air filter
» more rpms from a briggs 12hp flathead
» How much weight can a 12hp Briggs pull?
