| briggs 8hp flathead | |
greener179 Member
| Subject: briggs 8hp flathead August 17th 2012, 12:38 am | |
| i got a briggs 8hp flathead model 190707 it will start but then die after 45 seconds or so then wont start again till later | |
Age : 49 Join date : 2012-04-05 Points : 5701 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: briggs 8hp flathead August 17th 2012, 12:16 pm | |
| bad coil, or more likely, gas is very slowly feeding the carb. Pinched line, gas tank not vented, or clogged fuel filter. | |
| | | Tractor Man Jeff Moderator
Age : 29 Join date : 2012-06-26 Points : 5013 Posts : 492 Location : Back in the sticks of VA
| Subject: Re: briggs 8hp flathead August 17th 2012, 12:42 pm | |
| Does it have an Anti Backfire Solenoid? My tractor was doing something similar because of the ABS. | |
| | | greener179 Member
| Subject: Re: briggs 8hp flathead August 17th 2012, 12:49 pm | |
| just replaced coil got good spark i think i know what it is my friend thought he was helping me and jb welded a little hole in the gas cap and its a 1974 mogomeryward 8 | |
| Subject: Re: briggs 8hp flathead August 17th 2012, 12:51 pm | |
| HAHA. Take gas cap off and run it, then see how long it will run. That would do it. | |
| | | greener179 Member
| Subject: Re: briggs 8hp flathead August 17th 2012, 1:47 pm | |
| Yep, gas tanks need to be vented. I've had a couple get plugged. | |
| | | greener179 Member
| Subject: Re: briggs 8hp flathead August 17th 2012, 11:09 pm | |
| i got it to started and run i just need to mess with the carb it ran way longer then it use to if only my battery charger would work | |
| Who is online? | In total there are 74 users online :: 0 Registered, 0 Hidden and 74 Guests
