| | Starting Problems | |
RebelMechanic New Member
Age : 24 Join date : 2017-09-30 Points : 2553 Posts : 8 Location : Tawas City, MI
![Starting Problems Empty](https://2img.net/i/empty.gif) | Subject: Starting Problems October 19th 2017, 11:06 am | |
| I have a briggs 19.5 two cylinder that iḿ have problems getting started . If the spark plugs are in it the its ruff turning over with a fully charged battery even tried jumping if with a truck battery but still nothing . Then when i take out spark plug its turn over fine. I think it might be a bad starter but i don't want to spend the money until i know for sure. Any suggestions?
| ![Go down](https://2img.net/i/empty.gif) | | AllisKidD21 Moderator
![Starting Problems Empty](https://2img.net/i/empty.gif) | Subject: Re: Starting Problems October 19th 2017, 11:10 am | |
| You could take the starter apart and clean it/oil the bushings. Sounds like it is creating a lot of drag.
Another thing is I'm pretty sure those bigger oppys have automatic compression releases in them (I could be wrong) but if so maybe yours isnt working properly. Since you said it's fine if the plugs are out that would make sense.
![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| ![Go down](https://2img.net/i/empty.gif) | | Doug Site Owner
![Starting Problems Empty](https://2img.net/i/empty.gif) | Subject: Re: Starting Problems October 19th 2017, 11:27 pm | |
| Good chance its the starter. Best bet to test is to rob one from a good starting engine, swap and test. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| ![Go down](https://2img.net/i/empty.gif) | | RichieRichOverdrive Moderator
![RichieRichOverdrive](https://2img.net/u/2812/37/66/46/avatars/2731-86.jpg)
Age : 22 Join date : 2016-10-29 Points : 7020 Posts : 3898 Location : Lewisburg, KY
![Starting Problems Empty](https://2img.net/i/empty.gif) | Subject: Re: Starting Problems October 19th 2017, 11:42 pm | |
| I'd do like Doug said. These oppy starters are pretty bad about the bushings drying up or locking up and such. I've had to replace the starter gears on them more than once, and take em apart to lube up the bushings a few times. It's a pretty easy task if you've done it before. Hardest part about it is getting the brushes to stay apart when you're putting it back together, but there's a trick for that. | |
![Starting Problems Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Sponsored content
![Starting Problems Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | Starting Problems | |
| Who is online? | In total there are 133 users online :: 1 Registered, 0 Hidden and 132 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
