| | Starting issue | |
paulnb57 Member
Join date : 2017-10-13 Points : 2607 Posts : 54 Location : Isle of Wight UK
![Starting issue Empty](https://2img.net/i/empty.gif) | Subject: Starting issue October 19th 2017, 3:05 am | |
| Sometimes when I turn the key to start the AlKo 10/36 (Noma) all I get is a clunk noise from the solenoid, a couple more flicks of the key and it turns over and starts.....Ive removed cleaned and greased the solenoid contacts, still does it, where should I be looking to effect a cure please? Battery has good charge, engine is B and S 10HP flathead
Thanks! | |
![Starting issue Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | AllisKidD21 Moderator
![Starting issue Empty](https://2img.net/i/empty.gif) | Subject: Re: Starting issue October 19th 2017, 10:35 am | |
| Make sure your battery cables are clean and tight on their connections, might be a bit corroded and not letting full power get to the solenoid. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
![Starting issue Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | Starting issue | |
| Who is online? | In total there are 123 users online :: 0 Registered, 0 Hidden and 123 Guests
