I plan on replacing mine with 4 on 4 hubs, they come with bearings. On one of my LT, I think I am going with the 1" trailer axle stub with the 4 on 4 hub.
Ifitaintbroke likes this post
ranch king pro 08 Member
2023 Build-Off Top 3 Winner
Age : 16 Join date : 2023-06-01 Points : 981 Posts : 461 Location : East Texas
I might be secretly accumulating parts for my GT 18 Atwoods was running a sale on the trailer axles I picked those up for $8 a piece I may or may not have found some pretty cool tires on Facebook Marketplace, i also bought a nice engine and a steering rack out of a golf cart for it
Ifitaintbroke Member
Age : 24 Join date : 2024-02-19 Points : 522 Posts : 296 Location : South georgia
Do a write up when you get to it so I can steal your ideas. I haven't seen many builds of these.
These are the most heavy duty mower wheelbearings I know of. They aren’t sealed but you can just keep pumping grease through them to push junk out. Ran them on the 21s on mutt for several months and they were still good when I went to trailer spindles. They won’t come apart like ball bearings, they will keep working until the cage inside gets tore up and the needles fall out when you pull the wheel off, which takes a few years of really hard use to do.
I like those. Might try that.
Front end on this thing is wore slap out. Like completely gone. I'm going to try tightening everything up. Curious about how to do that with the axle pivot.
Age : 22 Join date : 2016-10-29 Points : 7020 Posts : 3898 Location : Lewisburg, KY
Not sure if you have the missing hitch plate in your pic, if not you might make something to connect the sides for support. That way your transaxle isn't the support.
I have it, just haven't put it back on yet.
Thinking about the steering. Tractor drives great other than that, but the slop is awful. I was considering a rack and pinion, and the price on them isn't bad, but I don't really have that kind of money right now. I need to use my harrow, so will be driving it a good bit. I found that most of the slop is because the shaft bushing is completely worn out. Fixing that won't get it to 100%, but I'm sure will make it tolerable. The part number search begins...
