| | Tiny Alternator from Kubota, Nice for tractor builds... | |
![Tiny Alternator from Kubota, Nice for tractor builds... Empty](https://2img.net/i/empty.gif) | Subject: Tiny Alternator from Kubota, Nice for tractor builds... November 6th 2019, 6:10 pm | |
| I was just looking through some stuff trying to find a light weight alternator after discovering that ARC's billet flywheels don't have any charging magnets. Saw this on amazon. It's a small alternator that puts out 14amps (12 volts). There is also a 20amp model for a bit more $$$. It's supposed to weigh 3.5 lbs. I'm trying to find out what the dimensions are but it looks small. Just thought it might help someone out if they wanted a small alternator to fit their project. Car alternators can be pretty big. Tiny AlternatorIf I end up ordering one, I will post some pics to show the size better. They look pretty cool. Guess they are for a kubota engine. ![Tiny Alternator from Kubota, Nice for tractor builds... Tiny_a10](https://i.servimg.com/u/f23/18/60/28/82/tiny_a10.jpg) Also looks easier to make a mount for it than a car alternator. ![Tiny Alternator from Kubota, Nice for tractor builds... Tiny_a11](https://i.servimg.com/u/f23/18/60/28/82/tiny_a11.jpg) | |
| ![Go down](https://2img.net/i/empty.gif) | | AllisKidD21 Moderator
![Tiny Alternator from Kubota, Nice for tractor builds... Empty](https://2img.net/i/empty.gif) | Subject: Re: Tiny Alternator from Kubota, Nice for tractor builds... November 6th 2019, 6:15 pm | |
| Yeah I've seen ads for those little units a bunch of times and they always seemed like a perfect compact little unit. I thought you could even use one for a vertical shaft engine really, being that they're so small.
I'm looking forward to seeing how it works for ya! ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| ![Go down](https://2img.net/i/empty.gif) | | prancstaman Veteran Member
![Tiny Alternator from Kubota, Nice for tractor builds... Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | prancstaman Veteran Member
![Tiny Alternator from Kubota, Nice for tractor builds... Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | mr.modified Veteran Member
![Tiny Alternator from Kubota, Nice for tractor builds... Empty](https://2img.net/i/empty.gif) | Subject: Re: Tiny Alternator from Kubota, Nice for tractor builds... November 6th 2019, 10:32 pm | |
| I guess you need to run a regulator yeah. I'm thinking that's the way to go for my new build though if I run an ARC flywheel. Too bad they don't just have the charging magnets in their flywheels though. I heard the stock briggs charging coils only put out like 3 amps? So this would be a step up anyway. | |
| ![Go down](https://2img.net/i/empty.gif) | | RichieRichOverdrive Moderator
![RichieRichOverdrive](https://2img.net/u/2812/37/66/46/avatars/2731-86.jpg)
Age : 22 Join date : 2016-10-29 Points : 7020 Posts : 3898 Location : Lewisburg, KY
![Tiny Alternator from Kubota, Nice for tractor builds... Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Creepycrawler Established Member
![Creepycrawler](https://2img.net/u/2812/37/66/46/avatars/999-39.jpg)
Age : 37 Join date : 2013-07-02 Points : 4945 Posts : 731 Location : Logan Ohio
![Tiny Alternator from Kubota, Nice for tractor builds... Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Sponsored content
![Tiny Alternator from Kubota, Nice for tractor builds... Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | Tiny Alternator from Kubota, Nice for tractor builds... | |
| Who is online? | In total there are 122 users online :: 1 Registered, 0 Hidden and 121 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
