MightyRaze - Red Bandit
+9 Crazy_Carl
PizzaKitty26
Hillbilly mowers
Rustbucket Garage
ranch king pro 08
BairleaFarm
13 posters
Author Message MightyRaze Admin istrator
Join date : 2016-09-06Posts : 10860 MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 15444Posts : 10860Location : Oklahoma Subject: Re: MightyRaze - Red Bandit November 27th 2023, 1:59 pm Yep it appears to be cast aluminum rod. Can't weld that dipper back on. I could get another rod, but do I want to keep dumping $$ into this engine? Hmm. I might could polish that crank back out. We're talking mower engine here. Hmm... what to do. Kind of thinking of making a dipper that connects to the bolt and sending it till she's done.
Age : 49Join date : 2016-09-06Points : 15444Posts : 10860Location : Oklahoma Subject: Re: MightyRaze - Red Bandit November 27th 2023, 2:38 pm OK, I am going to give the kohler 1 more chance. I went ahead and purchased a new rod. Should be here friday. Maybe I'll get it fired up again Saturday.
Age : 49Join date : 2016-09-06Points : 15444Posts : 10860Location : Oklahoma Subject: Re: MightyRaze - Red Bandit November 27th 2023, 3:39 pm Crank cleaned up nicely at lunch today. This looks promising. There are a couple knicks in one spot, but I think it will be fine.
Age : 49Join date : 2016-09-06Points : 15444Posts : 10860Location : Oklahoma Subject: Re: MightyRaze - Red Bandit November 27th 2023, 5:49 pm #savethekohler #KeeptheKohler Here is some more Kohler intimate shots for you guys to drewel over.
Rings looked new.
rod was slapping the bottom of the piston wall. Piston wall is ok.
.010 piston.
Cleaned pretty well.
Piston wall looks good.
Made some pins to help put the engine back on without fighting the gasket etc.
RichieRichOverdrive likes this post
Like 1
Brianator Mod erator
Age : 45Join date : 2019-07-02Points : 4474Posts : 2385Location : Ontario, Canada Subject: Re: MightyRaze - Red Bandit November 27th 2023, 7:26 pm Nice to see you giving it surgery even if it will end up getting shelved! So it looks like it's already been into as it has a 10 thou over piston, guess they didn't follow the proper torque procedure for the rod end (which is an odd one IMO) and I'll assume no Loctite either? You caught it just in time man, good for you!
Age : 49Join date : 2016-09-06Points : 15444Posts : 10860Location : Oklahoma Subject: Re: MightyRaze - Red Bandit November 27th 2023, 7:57 pm I bet those rod cap bolts were only finger tight. Also, the camshaft looks pretty new as well. Lobes are perfect. As for shelving... that could get pushed out a while.
Like 1
Age : 49Join date : 2016-09-06Points : 15444Posts : 10860Location : Oklahoma Subject: Re: MightyRaze - Red Bandit November 27th 2023, 8:36 pm More research on these engines. I have found out that aftermarket rods seem to come loose. We we have established the engine has been rebuilt at least once. Also, the balance gears. In the pulling world, they recommend you yank them out or they may grenade on you. I believe, that with offroad use, the recommendation will probably be the same! Those will be coming out. The bottom one is already looking sketchy and ragged.
Crazy_Carl Veteran Member
Age : 35Join date : 2017-10-30Points : 5259Posts : 2561Location : Rochester, New York Subject: Re: MightyRaze - Red Bandit November 27th 2023, 9:23 pm The machine shop yanked the balance gears out of my K301 when that got done. I think they were already broken. There is still aluminum deposited on that crankshaft. Do this outside! You can dissolve it off with muriatic acid or perhaps white vinegar will do the same. Then you can polish it up again. Looks like a perfect candidate for a new rod.
Age : 49Join date : 2016-09-06Points : 15444Posts : 10860Location : Oklahoma Subject: Re: MightyRaze - Red Bandit November 27th 2023, 9:35 pm @Crazy_Carl ,
I haven't really finished with the cleaning of the crank. I just did a quick 2-3 minute cleaning. I saw that it was coming off pretty easy. I was going to give it more love between now and the new rod Friday.
With the recommendation from The Captain,
@Wheelinhorse , I did go and yank the balance gears out. Good thing too.
One was missing needles in the needle bearing. I search all over the inside of the block with a magnet to be sure they didn't fall out. That could have been some flaky debris I found in the pan.
One of the gears was already starting to flake apart.
Empty shafts where they were.
Note the shaft closest to the camera. See the scoring from the missing needles?
I've read that without the balance gears, I will see anywhere from, unnoticeable to some shake that will eventually not be noticed after some time.
Now to figure out how to get the spacers off.
Age : 35Join date : 2017-10-30Points : 5259Posts : 2561Location : Rochester, New York Subject: Re: MightyRaze - Red Bandit November 27th 2023, 9:39 pm My k301 and K241 are both solid mounted and vibrate quite a bit. Bonus: free foot massage!
Like 1
Age : 49Join date : 2016-09-06Points : 15444Posts : 10860Location : Oklahoma Hillbilly mowers Member
Age : 37Join date : 2023-10-12Points : 674Posts : 291Location : Booneville ky MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 15444Posts : 10860Location : Oklahoma Subject: Re: MightyRaze - Red Bandit November 28th 2023, 12:52 am Actually there is a problem with aftermarket rods coming loose. This engine had an aftermarket rod.
BairleaFarm Member
Join date : 2023-10-11Points : 510Posts : 140Location : Georgetown, KY Subject: Re: MightyRaze - Red Bandit November 28th 2023, 9:42 am MightyRaze wrote: Actually there is a problem with aftermarket rods coming loose. This engine had an aftermarket rod. Definitely feel like an oppy swap would be the quickest bestest fix lol
MightyRaze and PizzaKitty26 like this post
Like 2
Wheelinhorse Member
Age : 49Join date : 2020-11-27Points : 1458Posts : 55Location : Mocksville NC TechnoChicken Established Member
Join date : 2021-12-10Points : 1891Posts : 862Location : Ontario, Canada Subject: Re: MightyRaze - Red Bandit November 30th 2023, 8:39 am I had a kohler magnum 20hp and even with 2 cylinders it shook like hell, pretty sure thats just normal kohler stuff
RichieRichOverdrive Mod erator
Age : 22Join date : 2016-10-29Points : 7020Posts : 3898Location : Lewisburg, KY Subject: Re: MightyRaze - Red Bandit November 30th 2023, 10:41 am Wow mighty, I didn’t know those engines fall apart like that! Be interesting to see how the new rod turns out, I bet it will work fine.
Like 1
Age : 49Join date : 2016-09-06Points : 15444Posts : 10860Location : Oklahoma Subject: Re: MightyRaze - Red Bandit December 3rd 2023, 10:16 pm New rod is back in town. Here is hoping it comes to the house tomorrow as they say and not back to Florida.
Like 1
Age : 49Join date : 2016-09-06Points : 15444Posts : 10860Location : Oklahoma Subject: Re: MightyRaze - Red Bandit December 3rd 2023, 10:37 pm OH! Forgot to mention. I left my mark inside the block on the crank. LOL
Like 1
Age : 49Join date : 2016-09-06Points : 15444Posts : 10860Location : Oklahoma Subject: Re: MightyRaze - Red Bandit December 4th 2023, 3:58 pm Yay! Rod finally made it today. Shocked it was not made in china, but was made in Taiwan. LOL. Anyways, I was excited to get it in that I forgot to take any pictures.
Engine is back on and all hooked up. I have not tired to fire it yet. I'll do that after work.
Brianator and Hammernco like this post
Like 2
Age : 49Join date : 2016-09-06Points : 15444Posts : 10860Location : Oklahoma PizzaKitty26 Member
Join date : 2023-01-24Points : 767Posts : 149Location : ON MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 15444Posts : 10860Location : Oklahoma Subject: Re: MightyRaze - Red Bandit December 4th 2023, 8:57 pm Not yet, My belt is 1 inch too small so it does not disenguage. I know I don't have the guides on yet, but I'm going by the clutch pulley placement. It's close to driving.
PizzaKitty26 likes this post
Like 1
Age : 49Join date : 2016-09-06Points : 15444Posts : 10860Location : Oklahoma Subject: Re: MightyRaze - Red Bandit December 4th 2023, 9:03 pm In other news, I have myself a battery box welded up now! Not finished, but seems to be good to go.
Age : 35Join date : 2017-10-30Points : 5259Posts : 2561Location : Rochester, New York Sponsored content
