 MightyRaze's The Green Machine
BlakeGroce
LJHunter429
Nevadablue
Budget_gokart
Rustbucket Garage
MN mudder
15 posters
Go to page : 1, 2, 3, 4, 5, 6, 7  Next
MightyRaze's The Green Machine Empty
PostSubject: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 12th 2021, 9:51 pm
#TheGreenMachine
I was hoping to put it in the build-off next year, but I just don't see that happening.  I will go ahead and put all these parts together and build the tractor.  This would have been the 3rd time I have rebuilt this tractor for the build-off
First time was a speed/hotrod build: Sasquatch II Hotrod Craftsman
MightyRaze's The Green Machine Mighty10
Second was a utility build: Project Patriot
MightyRaze's The Green Machine Img_2113
This time was for an Rally/Mud build: The Green Machine.
This one takes me WAY BACK!
Back when I was a kid in the early 1980's I use to take things apart and put them back together, sometimes take things from one toy and mod it to another.  For instance I use to take STOMPER engines and put them on other toys or models.  One time I took a stomper engine and put it on a model airplane so I could display it with the prop spinning. There use to be a dump site near where my Grandmother lived that had many toys, car parts, bikes, you name it...  One day I found a radio flyer wagon.  The back wheel supports were pulled through the bottom of the wagon, but I still wanted to drag it home.  At home, my dad had a 2x12 by about 5 ft long left over from my dad building on an extension to our home.  I mounted those wheels on one side of that board and the wagon bed to the top side.  I had enough room in front of that bed for me to sit and ride the wagon machine.  I found some hunter green paint and painted the whole thing.  I called it the Green Machine!  I later found some wide power wheel wheels that I put on the back so it looked like a hot-rod to me.  I'd say I was about 8-10 years old at the time.  Many times, I would pick the Green Machine over my bike as it was pretty fun.  I could just about keep up with my friends on it with a one leg peel going down the road.  That thing lasted for a while with no fixes.  When I was about 12 we moved.  The green machine was used by my dad a bother to move our large doghouse.  It was a good 300-500lbs.  The green machine handled it like a champ loading up the doghouse.  Unfortunately met it's demise later unloading the doghouse when it was dropped on it.  At that time, I had started using it less due to the fact I had grown almost a foot taller since I built it.  I think I was able to fix it enough to use it as a trailer for the Sears ST/16 tractor.  Not sure what exactly happened to it, as I do not remember it going to where my parents live now.  I think it got repurposed by someone else.  So this brings me to today.  I am planning to turn what was once patriot, into the new Green Machine!
The green machine will be a Rally/Mud mower build.  It is a 1989 Craftsman II GT18.
  • I will be using an 18hp Briggs and Stratton Opposed twin running 90' clockwise from the factory location.  This will give a non-twist belt configuration for the tractor.
  • The Roper 122419X (craftsman ver 633a) will be locked.
  • The front axle will be moved forward 8-10 inches.
  • New rack and pinion steering.
  • Repainted
  • Finish rear bumper?
  • Add toolbox
  • New tires
  • New LED light upgrades
  • New exhaust (since old was was taken for kal then chopped up)
  • Brake lights? Again?
  • Completely rewired.
  • 4 on 4 hubs on front axle
Things re-used:
  • Front bumper and winch
  • Rear hitch mount created for patriot
Now for the things already done:
New rear tires:
MightyRaze's The Green Machine 0-entr10
Engine repainted:  Fixed bad vibration in the engine.  Turned out the magnets came loose under the flywheel.
MightyRaze's The Green Machine 0-entr11
Welded a tip of the correct size and splines to a gopowersports rack and pinion so I can reuse my extendable with universals steering shaft.
MightyRaze's The Green Machine 0-entr12
Up next locking the transaxle and adding gopowersports 4 on 4 hubs to the front axle.
MightyRaze's The Green Machine Sig115PROJECTS:
MightyRaze's The Green Machine Sig214MightyRaze's The Green Machine Sig314
Nevadablue and MN mudder like this post
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 13th 2021, 12:18 am
I forgot to take a pic of the welded diff.  I just did a standard weld the gears together.  I think they call that a Lincoln locker.  I did not flip any gears as I think with welding would be more structural.
More easy stuff...  Just like the BMIKart hub, I had to trim the gopowersports hub by 1/2 inch.  I found this hub to be comparable to the bmikart one and MUCH cheaper.
MightyRaze's The Green Machine 2a10
I got a shot before I opened and when I was putting it back together.  I forgot to pic the weld.  Probably because I was anxious at first to bust this open.  Once inside, it wasn't too bad.  I was excited to get it apart and put back together.
MightyRaze's The Green Machine 2b10
I know when I drained it, it seemed to have bar and chain 30w oil.  I put similar back in.  5 qts through the shifter hole before reinstalling.
MightyRaze's The Green Machine 2c10
Painted the frame before it gets cold.  I should have some pix of that tomorrow!
Teaser of the frame tore down to frame for paint.
MightyRaze's The Green Machine Img_1316
Things go fast when you have it all staged out.  I figure I will have this mostly complete before the end of the month, "back depending".
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 13th 2021, 12:41 pm
Frame painted, and the original engine plate I had used on red as a skid plate is reinstalled.  Drilled some holes for the rotated engine.  Front axle painted as well as the hood mount.  (Not pictured yet)  I'll show that later after install.
MightyRaze's The Green Machine 3a10
Steering column in the background was painted as well.  Pictures soon.
Nevadablue likes this post
MN mudder
MN mudder
2022 Build-Off Finalist
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 13th 2021, 2:32 pm
looks good I will be watching this one!
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 13th 2021, 2:52 pm
Reinstalled steering.  Rack is done...
MightyRaze's The Green Machine 4a10
Dash as well.
MightyRaze's The Green Machine 4b10
Now the tricky part for me.  Glad I have an engine hoist.  Engine install soon.
Rustbucket Garage, Nevadablue and MN mudder like this post
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 13th 2021, 5:09 pm
Looking good as always! Going to keep the front tires you have on now or go with something wider/more aggressive?
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 13th 2021, 10:30 pm
I got a set just like red but with a wider rim and tubes.  I'll get to them soon.  These tires are just there to get it moved around for now.
Engine dropped in and bolted in.
MightyRaze's The Green Machine 4c10
MightyRaze's The Green Machine 4d10
Rear transaxle is in too as well as the new rear tires reinstalled.  Yes they are still clocked the same.  I have also started some wiring.  LOL
MightyRaze's The Green Machine 5d10
MN mudder likes this post
Budget_gokart
Budget_gokart
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 13th 2021, 10:42 pm
Im building the same tractor but the front axle is moved forward and widened and i am considering the onan engine i was offered one
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 13th 2021, 10:44 pm
Very cool!  Onan's are good engines, can be a bit finicky.  I think these craftsmans look good with the axle moved forward a bit.  I'll see about getting the new fronts on next.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 14th 2021, 10:37 am
I'll see if I can get the new front tires today.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 14th 2021, 8:33 pm
Did some wiring, got most of the basics and light bar installed/wired.
MightyRaze's The Green Machine 6e10
New fronts installed!  Same tires I have on Red, but with a wider rim.  They came out WIDE!
MightyRaze's The Green Machine 7a10
MightyRaze's The Green Machine 7b10
Also welded up some cracks in the rear fenders.
MightyRaze's The Green Machine 8a10
Not pictured, I did get it (rear fenders) painted as well as the foot boards.
MOVING FAST!
Suppose to turn MUCH colder tomorrow.
Nevadablue
Nevadablue
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 14th 2021, 10:03 pm
Looking good! I really want to build a horizontal shaft machine one day.
MightyRaze and muddybasilisk like this post
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 15th 2021, 12:07 am
Fenders painted and partially bolted down.  Hood sat back on for now.
MightyRaze's The Green Machine 9_110
Got some button lights for rear lights.  Going to have tail and brake lights.
LJHunter429
LJHunter429
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 15th 2021, 7:02 am
I'm loving it so far!
MN mudder
MN mudder
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 15th 2021, 9:50 am
neat, good progress are you going to paint the hood or leave it. also really digging those executioners on there!
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 15th 2021, 10:35 am
I'll be painting it.  I'm thinking a Green/Black combo.
MN mudder
MN mudder
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 15th 2021, 10:44 am
that's gonna look pretty mean looking forward to seeing it done! I also like the grab handles on the fenders I may have to borrow that idea.
Nevadablue
Nevadablue
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 15th 2021, 12:43 pm
I like those handles too, I had missed them.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 15th 2021, 1:12 pm
I haven't finished bolting those handles down yet.  Debating on painting them black.  I think it would look nice, but I think greasy hands would just strip the paint back off.  Took some morning break time to show you the rear lights.  Also, I am going to do a green/black scheme on the hood like the  rear fenders.
No lights:
MightyRaze's The Green Machine 9_210
Headlights on.
MightyRaze's The Green Machine 9_310
Lights on Brakes pressed (in this case parking brake locked):
MightyRaze's The Green Machine 9_410
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 15th 2021, 1:16 pm
Not pictured above, hood is off and green applied.  Waiting for it to dry before putting the black down.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 15th 2021, 7:35 pm
Installed and the handles are not installed too.
MightyRaze's The Green Machine 10_110
MightyRaze's The Green Machine 10_210
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 15th 2021, 7:58 pm
Few more pix...   Danceparty
MightyRaze's The Green Machine 10_511
MightyRaze's The Green Machine 10_610
MightyRaze's The Green Machine 11_110
Rustbucket Garage and MN mudder like this post
MN mudder
MN mudder
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 15th 2021, 9:10 pm
man, it's coming together quickly. looking good.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 16th 2021, 11:05 am
I put the rear 2" hitch I made for it back on.  I bought an ammo box.  I think I can attach it on top and put some angle across for a bumper.
MightyRaze's The Green Machine 11_210
Rustbucket Garage and Nevadablue like this post
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine Icon_minitimeOctober 16th 2021, 5:46 pm
Man… I don’t know what your secret is, but you always seem to get beautiful paint work! She looks good!
Page 1 of 7Go to page : 1, 2, 3, 4, 5, 6, 7  Next
» The green machine
» Murray "Green Machine" Mud Mower
» The Green Hornet's Dynamark Street Machine [2017 Build-Off Entry]
» Little green Craftsman.
» "LGC" Little Green Craftsman
