 MightyRaze's The Green Machine
BlakeGroce
LJHunter429
Nevadablue
Budget_gokart
Rustbucket Garage
MN mudder
15 posters
MightyRaze's The Green Machine - Page 3 Empty
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 20th 2021, 8:42 pm
A bellcrank can multiply input vs output and is easy to make, just a thought.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 20th 2021, 8:54 pm
Ooooo out of the box thought.  I may keep that in mind when I go at it again.
MightyRaze's The Green Machine - Page 3 Sig115PROJECTS:
MightyRaze's The Green Machine - Page 3 Sig214MightyRaze's The Green Machine - Page 3 Sig314
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 20th 2021, 9:37 pm
OK, I went out and looked.  I can fix the foot pedal issue with a simple trim of metal to give a little more pivot.  -Easy
Top side.  I think I will need to make a new cable connect point on the intake manifold.  That will fix the angle issue.
Need to come in from the angle in red.  Just need to figure out where to place my spring because my heat shield is in the way.
MightyRaze's The Green Machine - Page 3 Img_2514
Nevadablue likes this post
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 20th 2021, 9:49 pm
Awesome job on the new build so far Mighty, that exhaust header looks super slick!
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 20th 2021, 9:51 pm
Thanks AK!  I've finally got good enough welding that I don't instantly blow a hole in the tube.  LOL
I think I see what you're doing there, keeping the hand throttle with foot pedal override ya?
My All Terrain Tractors:
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 20th 2021, 9:54 pm
Yep!  I tend to use the foot for a little "boost" but mostly use the dash.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 20th 2021, 10:03 pm
Not able to put the return spring from the throttle directly to the heatshield by drilling a small hole? Your eyelet could still be in play if you put it on the spring before the spring on the throttle linkage, can't (well shouldn't) pop off then especially if you put a stop on the end of the spring
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 21st 2021, 12:12 am
That's pretty much what I did.  Yeah, I said I would step away and give it a rest, but I couldn't sleep with thoughts in my head.  Foot throttle is now connected.
Danceparty
I kept it simple...  Created a spring mount on the heat shield.
MightyRaze's The Green Machine - Page 3 Img_2515
Drilled one new hole about 3/4 inch center to center higher.
MightyRaze's The Green Machine - Page 3 Img_2517
Now it is the exact same travel as the governor arm itself.  No need for a stopper as the floorboard will stop but, the extension doesn't go any further.
MightyRaze's The Green Machine - Page 3 Img_2516
Petal is high enough to rest my foot under while cruzing with the dash throttle.  Not too high to mash it when needed.  Also not too much in the way to get tangled up on.
MightyRaze's The Green Machine - Page 3 Img_2518
All that is left is zip tie the cable so it does not get tangled in the frame.
This is my next item up for work.  I will let this one go till Friday or Saturday.
MightyRaze's The Green Machine - Page 3 Img_2519
BlakeGroce
BlakeGroce
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 21st 2021, 12:51 am
I'm just glad I'm not the only one guilty of using grade 8 bolts on literally everything!lol!  Looking good as usual! Should be one stout rig!
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 21st 2021, 1:02 pm
HAHA.... yeah I use them on everything.  I got my 3/8ths, 5/16's, 1/4's... I try to keep them in stock!.
I actually have a pic of the last time I was adding to my stock.
MightyRaze's The Green Machine - Page 3 Img_2415
I go through a lot of 1/4 stock.
I was sweeping up the floor this morning and realized, I will have a green stain now in the garage for a good time to come.  Thanks to The Green Machine.
MightyRaze's The Green Machine - Page 3 Img_2520
After sweeping, I felt really good in the back so I tackled the horns at lunch.  Pretty quick install.
MightyRaze's The Green Machine - Page 3 Img_2521
MightyRaze's The Green Machine - Page 3 Img_2522
MightyRaze's The Green Machine - Page 3 Img_2523
Also... looks like I have a new tractor "FREE" about to drop in my lap.
Budget_gokart and MN mudder like this post
MN mudder
MN mudder
2022 Build-Off Finalist
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 21st 2021, 1:09 pm
Ooo free is the best price for an old tractor ! Looks like your getting closer to being done.
Budget_gokart
Budget_gokart
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 21st 2021, 1:10 pm
man i really love this tractor its a really well thought out build and everything is way overdone i do all the same on my builds over think it and build it better then needed aand if i cant do as best as possible
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 21st 2021, 7:43 pm
Sweet build mighty! Those executioners sure do look great under a square fender craftsman MightyRaze's The Green Machine - Page 3 2731072446
Nevadablue
Nevadablue
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 21st 2021, 9:36 pm
Glad you are feeling better!
FREE tractors for everyone. (I hope)
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 21st 2021, 10:48 pm
Yeah getting there!  I need to fix a belt issue.  I think my belt is about 1 inch way too long.  Also need 1 guide.  What is so cool, with the issues I have, it still hasn't dropped the belt.
This one is the most planned and thought out tractor I have built.  I even have had parts stored up for it SEVERAL months.
HAHA.... yeah.  Can't quite put my finger on where I use to see it all the time..  ...MUTT...  I got the pair for $97 .  Now where I got them is $120 per tire.
Thanks... it has been a good back day.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 22nd 2021, 8:35 am
That was one of the nice things about executioners, lot of tire for cheap.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 23rd 2021, 10:50 pm
Little video reveal for The Green Machine!
  • I will be using an 18hp Briggs and Stratton Opposed twin running 90' clockwise from the factory location.  This will give a non-twist belt configuration for the tractor.
  • The Roper 122419X (craftsman ver 633a) will be locked.
  • The front axle will be moved forward 8-10 inches.
  • New rack and pinion steering.
  • Repainted
  • Finish rear bumper?
  • Add toolbox
  • New tires
  • New LED light upgrades
  • New exhaust (since old was was taken for kal then chopped up)
  • Brake lights? Again?
  • Completely rewired.
  • 4 on 4 hubs on front axle
Things re-used:
  • Front bumper and winch
  • Rear hitch mount created for patriot
Looks like I got everything on my list checked!!!
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 23rd 2021, 11:59 pm
It looks and sounds great! Super job!
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeOctober 25th 2021, 10:19 am
TGM is now in the shed with Red and Bowser... I'm going to need to do my fall shed cleanout soon.  Also get the dog area ready for the outside dogs.  Well, just one of the outside dogs.  The other one will be coming in unless it gets really cold, then they both come into the garage.
Budget_gokart
Budget_gokart
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeNovember 10th 2021, 1:03 pm
not to clog your thread mighty but on my GT same frame and transmission with stock steering and clutch my engine sits as far back as i could and i cant figure out a space for the belt would i have to run the belt over the steering or under it and if i ran it over would it effect the clutch?
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeNovember 10th 2021, 9:04 pm
At one time I tried and I ran it over the steering.  You are limited to a smaller pulley and it may rub.  Didn't affect my clutch.
MightyRaze's The Green Machine - Page 3 03101918
Budget_gokart
Budget_gokart
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeNovember 11th 2021, 8:19 am
with the angle my belt will enter a bigger pully will work on mine so should i just add a tensioner for the bottom so it goes around the steering?
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeNovember 11th 2021, 2:55 pm
I don't see why that wouldn't work.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeFebruary 4th 2022, 12:26 pm
Little update on the Green Machine.  Got it out yesterday and had some fun.  Ran it for a little over an hour no issues!  It fired right up in the 12-degree temps.
Little highlight vid.
Unfortunately, Li'l Red was temperamental so no video there.  Bowser was just dead and full of gas in the sump from trying to start it.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 3 Icon_minitimeFebruary 4th 2022, 12:30 pm
btw: bowser has an electrical gremlin I'm fighting.  I have a plug that keeps popping out even though it is crimped and hard to slide on/out.  I may need to re-look at what I got going there.  Maybe even engine selection.
Page 3 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
» The green machine
» Murray "Green Machine" Mud Mower
» The Green Hornet's Dynamark Street Machine [2017 Build-Off Entry]
» Little green Craftsman.
» "LGC" Little Green Craftsman
