 MightyRaze's The Green Machine
BlakeGroce
LJHunter429
Nevadablue
Budget_gokart
Rustbucket Garage
MN mudder
15 posters
MightyRaze's The Green Machine - Page 5 Empty
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJune 28th 2023, 3:07 pm
Finally got around to taking this pic.
See the issue?  I do.  Now to figure out how to fix it.
MightyRaze's The Green Machine - Page 5 Img_2542
Here, for those that don't see it right away.
Green line would be a straight path.  Red line is left edge of belt.
MightyRaze's The Green Machine - Page 5 Img_2543
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJune 29th 2023, 12:36 pm
Video update.
MightyRaze's The Green Machine - Page 5 Sig115PROJECTS:
MightyRaze's The Green Machine - Page 5 Sig214MightyRaze's The Green Machine - Page 5 Sig314
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 1st 2023, 9:32 pm
OK!  Another update.  Popped some holes in the sides of the hood.  Seems to help a LOT.  I can set my hand on the hood now after a few minutes riding without burning my hand.  I'll say win!
Here I am marking and about to drill four 1/2 inch pilot holes for a tool I purchased for this job.
MightyRaze's The Green Machine - Page 5 Img_2546
Here you can see the pilot holes, the tool and a popped hole with bevel.
Basically you run the 1/2 bolt through the hole, there is a cup on the back side to catch the cutter and top bevel maker.  I just used my impact to squeeze it together.  This metal seems to be on the upper end of thickness the tool works on, but turning the cutter 90 degrees draw it together again finishes the hole.
MightyRaze's The Green Machine - Page 5 Img_2544
Holes cut on one side.  The tool seems to cut nice burr free holes.  I was able to rub my finger around the inner seam without catching or sharp points.
MightyRaze's The Green Machine - Page 5 Img_2545
With some touch-up paint, all finished. I think it looks pretty good actually.
MightyRaze's The Green Machine - Page 5 Img_2548
MightyRaze's The Green Machine - Page 5 Img_2547
As mentioned, it helped reduce the temp under the hood enough that I could not touch the top of the hood where the upper vent is before this mod.  Post mod, I can hold my hand on it.
Danceparty
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 1st 2023, 9:53 pm
That looks awesome! Those tools work great I've wanted to get one myself.
My All Terrain Tractors:
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 1st 2023, 10:34 pm
It worked pretty well for me. It seemed to come with an extra bolt. That was nice, since after 3 holes the bolt was getting pretty hot. I swapped to the nice cool one for the next three. I think that helped keep me from stripping it.
https://www.amazon.com/dp/B09W9B91X4?psc=1&ref=ppx_yo2ov_dt_b_product_details
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 2nd 2023, 3:34 pm
Looks great mighty! I have a set of knockout punches like that to pop holes in electrical enclosures for different conduit sizes, but they don’t make nice bevels like that. Awesome job!
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 2nd 2023, 11:52 pm
Thanks, the more I look at them the more I like them. I am now considering doing 6 more on each side in the upper hood. Something like this poor photoshop mockup.
MightyRaze's The Green Machine - Page 5 Idea10
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 6th 2023, 9:11 pm
OK, small review on that tool.  On the 9th hole drilled in the hood, the base stripped out and destroyed the bolt.  I was able to run to the hardware store and bought a grade 5 7/16ths x 4 inch bolt and nut that worked great for the last 9 holes I popped no problem.  Decided on 5 more on the top of each side of the hood.
MightyRaze's The Green Machine - Page 5 Img_2553
If the chain is any indication, yet I am putting it to work right now.  I've been dragging limbs to my burn pile. Dragging them over to trim them down for the burn pile. Some of the limbs were in excess of 25-30 feet. The first couple limbs I pulled with Red, but it's not quite heavy enough. I was spinning the tires pretty bad.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 6th 2023, 10:08 pm
That's awesome, what a great looking way to solve a problem!
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 6th 2023, 10:13 pm
Thanks, TGM has become pretty reliable now after some "tweaks".  Seems to have resolved the heat issue.  Even in the 90-100 heat! Hood gets hotter sitting in the sun now than the engine.  That is what I was hoping.
It's looking a little rough.  Still can see where I had the paint blemished by the chemical leak.  Maybe I'll take it back to metal since there are so many levels of paint on this beast.  Original silver, Kubota orange, black with flames, blue, and now black and green.  Maybe I'll take it back down primer and paint it sometime in the future.  I do like the green, that will stay for now on.
Last edited by MightyRaze on July 6th 2023, 10:42 pm; edited 1 time in total (Reason for editing : spelling.)
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 6th 2023, 10:22 pm
On the knockout punches I use, I put gray never seize on the threads as a sort of anti galling and high pressure lubricant measure. Might be a good idea here. Definitely don’t want to run a thread with that much use dry.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 6th 2023, 10:45 pm
Good call! I did spray it with wd40 this time around. It seemed to help. Anti-seize may work better!
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 7th 2023, 6:51 pm
WD is better than nothing, grease would be fine, but you know that never seize sure does stick to stuff!
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 7th 2023, 11:01 pm
Yeah, that stuff... once it is on your finger, in about 10 minutes you look like the tin man.
Ran TGM for about 30 minutes this evening dragging limbs. Ran great and didn't get hot at all!  I could put my hand on the hood over the exhaust pipes and it was only warm!
MightyRaze's The Green Machine - Page 5 Tree10
Also, the belt stayed on the whole time.  I did notice one of the idlers is starting to get noisy.
Very pleased with the tractor today.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 10th 2023, 11:15 pm
New video update. Yay!
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 11th 2023, 9:10 pm
Now I am torn. I gave the Green Machine a workout today and was not happy with the clutching. I have tweaked and tweaked, and it just doesn't feel right or seem to clutch quite right. I am highly considering putting it back the way it was. Yeah, I don't get speeds over 10-12 but that is still pretty good for a utility build. Maybe I can do a half and half. We'll see, I'm pretty sure the double pulley was much better. Just need to resolve the flat idler pulley issue.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 12th 2023, 3:54 pm
New config on the belts.  Back to the smaller pulley on the engine.  Decided the tractor was too fast for it's build.  Death wobble was too bad at higher speeds.   Don't really need the speed at this time.
MightyRaze's The Green Machine - Page 5 Img_2556
Double pulley clutch back on.  Yes, that bottom length of belt is pretty close to the clutch pulley, but only touches when the belt flaps.  Seems ok right now.  No unusual wear so far.
MightyRaze's The Green Machine - Page 5 Img_2558
Back to nice clutching and full belt stop when pressed in.
MightyRaze's The Green Machine - Page 5 Img_2557
Been using it to pull a lot of limbs lately due to storms.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 13th 2023, 11:09 pm
Trunk reinstalled.  Could not find the old one, plus I cut and re-welded the hitch so it is straight and not slightly pointed down. as it use to be.
MightyRaze's The Green Machine - Page 5 Img_2564
Once I got it installed, guess what I found plain as day on the workbench under the pole saw?  Yep the old trunk. (ammo box)
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJuly 15th 2023, 10:29 pm
Lots of work for The Green Machine today. Lots of limb dragging.  This pile stopped at about 10 feet high and about 15ft around.
MightyRaze's The Green Machine - Page 5 Img_2566
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeNovember 8th 2023, 6:52 pm
Green Machine has seen some work this week.  This is load 2 of at least 4.
MightyRaze's The Green Machine - Page 5 Img_2965
Neighbor wanted the wood gone, so I am snagging it.
Rustbucket Garage and Hammernco like this post
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeNovember 8th 2023, 11:09 pm
I thought they made pills for that.MightyRaze's The Green Machine - Page 5 1098998679 (The meaning of that statement may be left to your own interpretations)
In all seriousness, glad the old girl is getting to stretch her legs. I enjoy firewood, it’s a zen thing I find, at least when my knees ain’t buggering up.
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeNovember 9th 2023, 3:30 pm
Giving the Green Machine a break today since it is raining.  I don't usually like to leave a tractor in the rain.  It's a light rain, so it shouldn't be too big a deal.
MightyRaze's The Green Machine - Page 5 Img_2970
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJune 25th 2024, 9:31 pm
I stole the engine out of the Green Machine for the Red Bandit so I could get it to Haspin. Thanks to @RichieRichOverdrive, I have a parts engine that I broke down and was able to use it to fix the original engine destined for RB. Now that engine after being fixed, will now go into The Green Machine.
The process has begun!
MightyRaze's The Green Machine - Page 5 Img_4123
MightyRaze's The Green Machine - Page 5 Img_4122
MightyRaze's The Green Machine - Page 5 Img_4124
RichieRichOverdrive likes this post
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJune 26th 2024, 1:16 pm
I thought I posted last night.
MightyRaze's The Green Machine - Page 5 Img_4125
That was last night. At lunch today I got the rest buttoned up. Minus the exhaust brace and I forgot I stole the key switch. I have one of those on order and should be here tomorrow. Then The Green Machine should be complete again.
RichieRichOverdrive and ranch king pro 08 like this post
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeJune 27th 2024, 10:32 pm
The green machine is back together and I was able to drive it back to the shed. All good there now.
MightyRaze's The Green Machine - Page 5 Img_4110
PostSubject: Re: MightyRaze's The Green Machine   MightyRaze's The Green Machine - Page 5 Icon_minitimeSeptember 4th 2024, 10:32 pm
OK, the Green Machine looks to get a new lease on life for this winter and next year's project.  I have some pretty extravagant plans, but need a little help.
Green Machine's engine plate has long been modified and parts missing for years from it's "STOCK" days.  I am looking for a picture of that pulley carrier that would take the backwards facing Briggs or Kohler engine down and through 2 pulleys bend the belt for the transaxle.  I know that part was scrapped/repurposed at least 7-8 years now.  Back in my Sasquatch 1 days.
What I am looking for is a clear picture of this pulley set in the picture below.  I will need to fabricate it I think.  Unless I can find one for sale online.  Not really sure what it is called at the moment.
MightyRaze's The Green Machine - Page 5 Pully10
Also, if I remember right, (Top side engine pulley) the frameside (Flat?) pulley was clutch and (bottom side engine pulley) the inward (V?) pulley went to the transaxle.  The pulleys for the V and Flat bend were not parallel I don't think.  I think the V was slanted over more at the top.
Page 5 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
» The green machine
» Murray "Green Machine" Mud Mower
» The Green Hornet's Dynamark Street Machine [2017 Build-Off Entry]
» Little green Craftsman.
» "LGC" Little Green Craftsman
