| [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] | |
+18TheCollector MatthewD CraftsmanQuad19 SebastianAlbrecht Buck TheBeal RichieRichOverdrive Dave 007 mrshaft696 Crazy_Carl Dave.MTD Doug prancstaman AllisKidD21 biggasmowers Double W Cross Ranch muckmudd MightyRaze 22 posters |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 17th 2018, 9:30 pm | |
| Lol. Was doing some stresses today. Speed and hit the off road fast too.
Top speed is 18mph right now. Maybe some tuning and may see 20mph not worried about going faster. While forcing the front to flex I ended up busting the u joint off my steering gear. Nothing a re-weld won't fix. I may try to shorten the steering too.
Also I was surprised how much that old frame flexes. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 18th 2018, 2:50 pm | |
| Quiet until you let off the gas. Then there is a whine. Little bit disk brake rub sound.
The thing that shocks me is the amout of frame twist this thing has. I think it twists more than Li'l Red. It's enough to make me reconsider it being primary. | |
Crazy_Carl Veteran Member
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 19th 2018, 11:08 pm | |
| - MightyRaze wrote:
- Lol. Was doing some stresses today. Speed and hit the off road fast too.
Also I was surprised how much that old frame flexes. Got the steering fixed tonight! Turns out I only tack welded the socket to the shaft. Go me. It's burned on this time. I was thinking about the twisting. I think most of this is due to the wide rear end. I think I will take off the rear spacers when I get the chance. Make sure the tires do not hit the foot boards. I may end up trimming them up. | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5093 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 21st 2018, 12:11 am | |
| All good ideas... i was looking at some twisting and it appears to be from the monolink point forward. I was thinking of welding in an X brace up there on the underside and see if that would help. We are not talking serious bend, but maybe about quarter to half inch twist in extreme surface. Enough to jack up the hood. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 21st 2018, 6:18 pm | |
| - Crazy_Carl wrote:
- Where was the oil leaking from? the head gasket?
Inside the cylinder chamber and out where the head gasket was loose. All this time I thought it was a loose plug. It's slow enough that I don't blow white smoke yet. The pic above is the opposite side, it was just carbon build-up with some blowout where it was loose too. I forgot to take a pic from the side in question. My hands were very oily at that time and momentarily lost my phone. LOL | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 24th 2018, 11:58 pm | |
| LOL...
Started working a few other things I hope pan out. Also, looking at those pix...Kal is starting to get dusty. HAHA..
Age : 23 Join date : 2018-02-27 Points : 3843 Posts : 1299
George Gooding Member
Age : 50 Join date : 2018-06-15 Points : 2496 Posts : 133 Location : Joplin Missouri
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 25th 2018, 10:00 pm | |
| Cool deal Mighty! Looks super sturdy, should work great for sure. It'll definitely be handy to have some decent storage space. I like your pup as well! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 25th 2018, 10:56 pm | |
| - Crazy_Carl wrote:
- Great RACK! You're tractor looks more complete now. So where's the toolbox going?
Still thinking of some tweaks for it. I have contemplated maybe a midrange shelf? Something to put a toolbox or something in under there? Still thinking as I do not know what toolbox to use at this time. I may go with a ammo canister. Still in brainstorming. - AllisKidD21 wrote:
- Cool deal Mighty! Looks super sturdy, should work great for sure. It'll definitely be handy to have some decent storage space. I like your pup as well!
Thanks AK! | |
