 [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]
TheCollector
Dave 007
Dave.MTD
22 posters
Go to page : Previous  1 ... 16 ... 28, 29, 30
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Empty
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 2nd 2018, 1:44 pm
Dave.MTD wrote:
New profile pic looks awesome Mighty.  Did I miss you putting new shocks on Kal?  I don't recall pics but those new ones look sweet!
Good eye.  LOL  That didn't take long.  Since the beans have been somewhat spilled.
Yeah the whole front was changed out.
Before...
Code:
[img]http://mightyraze.com/wp-content/gallery/pops/37140315_2597264620498183_1091241419139448832_n.jpg[/img]
After...
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 10011810
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 09261810
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 09241810
Yeah she looks fantastic. I have a feeling there's something new with the front axle that you're not showing us Mighty, I'm not gonna rack my brain trying to figure it out though.
Up till today, @AllisKidD21, was the only one with the full update.  No more rack ing brains and getting o-pinions LOL
Changed made:
  • New front frame
  • new monolink rebuild
  • new bumper
  • added 2nd NiLight
  • new shocks
  • exited exhaust out in front of tires.
  • changed engines
  • new rack-n-pinion steering
  • ammo box trunk on the rear rack
  • horn
  • Dual USB 2.1 amp charging port
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 2nd 2018, 4:32 pm
Well I'm blown away!  I love everything.  This thing has every feature you could want!  I like the stinger on the front bumper how you covered it with sheet metal.  I'm excited to see what kind of video you make with it.
Dave.MTD
Dave.MTD
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 2nd 2018, 8:13 pm
Wow...you've been busy Mighty. Front end looks killer, rack and pinion should work awesome, and I love the exhaust exiting in front of the rear tire there. This build looks amazing! How's she handle with the new goodies up front?
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 2nd 2018, 8:23 pm
Looking really good! Is she particularly heavy on the front end?
man, everybody is getting a rack but me...
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 2nd 2018, 8:41 pm
A bit front heavy, but I make a pretty good counter weight.. LOL
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Sig115PROJECTS:
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Sig214[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Sig314
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 4th 2018, 2:52 pm
Is it bad that I have thought of some changes down the line? LOL
Decided that I will not use the brother of Kal in another build but to part it down as spare parts for Kal.
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Img_2032
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 4th 2018, 6:11 pm
Great work Mighty! A parts mower is always a nice luxury Smile
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 4th 2018, 9:00 pm
very cool what is that rack and pinion from?
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 4th 2018, 10:23 pm
yerf dog. not 100% happy with it as the inner tie rod links are pretty flimsy. Should it fail, I will weld in some heim links or something. Other than that, after modifying the tie rods, it works good.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 7th 2018, 12:17 am
MightyRaze wrote:
Doing some compression tests because of some power loss.
Kal - 18hp Oppy 63 psi and Leak down passed (lack of power).
Red- 17hp Oppy 78 psi no leak down tested (Lots of power).
Squatch - 16hp oppy 59 psi no leak down (Lots of power).
Doing some research, Briggs does not give compression values but recommends leak down tests.  I've read people getting anywhere between 50-100psi compression running good.
I'm thinking now that I may need to look into the carb.  Maybe a good cleaning.  Runs good, but has a bog down on mashing of the gas.  Before I take it apart, I will try some other things like new gas, and re-adjust low end jet.  I think I can do that on this carb.  Also a new set of plugs.  I had one busted that was arching, so I do have an older set in right now.
Other things to check or have checked.
Gas cap is venting well.
Maybe replace the fuel filter?
So, cleaned the garage today and then I put Kal's old engine up on the table.  Found that both valve covers were leaking out the bottom running under the pistons.  Also when I went to pull the vacuum line I found that it was busted in half.  Imagine that... I wonder if that was the source of power loss or lack of fuel at faster RPM?  Sure makes sense. Anyways, I think I will give that engine to my dad to work with.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 7th 2018, 1:09 pm
Sounds like simple problems but tricky to diagnose when it’s covered in oil on the tractor
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 15th 2018, 9:24 am
Engine given to my dad.  Hope I got all the bugs out.  Wouldn't you know, the day I finally can maybe film my final video it is 35*f outside.....  GRR...and brr
EDIT: And 20-30 mph winds....  affraid
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 16th 2018, 12:38 am
COMPLETE....
I'm walking away from this topic to enjoy the ride.  Vote Kal-El!
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 16th 2018, 7:39 pm
Nice video you put together.  It really does the tractor justice.  I like the decal for the shift pattern.  It really fits the theme nicely.  Looked like the tractor handled really well too.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 16th 2018, 8:54 pm
I was really hoping to take it down to the river, but with all this rain... Bah...
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 17th 2018, 7:04 pm
I know my tractor is complete, but ...
I put it to work today.  Pulled some poles out that I wasn't able to pull out myself.
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 10171811
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 10171810
Worked like a champ.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 21st 2018, 7:55 pm
Hard to believe a year ago this was KAL...
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 09301710
Kal Today
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 10151810
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 21st 2018, 9:17 pm
What happened to walking away from the thread 'til the end of the Build-Off?? lol! lol!
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 21st 2018, 9:48 pm
At least I didn't change the tractor. LOL!
TheCollector
TheCollector
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeOctober 27th 2018, 1:11 am
Very nice machine you have built. Love the detail
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeNovember 12th 2018, 4:07 pm
Thank you.
Here is a better Idea of the difference for a before and after side by side.  Basically the same tractor.
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 11121811
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 11121810
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 11121812
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeNovember 18th 2018, 10:14 pm
Liked the one box so much.  Added a second.
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 11161810
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeNovember 18th 2018, 11:20 pm
Hmm... my old coleman ice chest fits nicely back there!
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 11181810
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 11181811
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Icon_minitimeDecember 1st 2018, 11:06 am
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 30 Kal10
Page 30 of 30Go to page : Previous  1 ... 16 ... 28, 29, 30
» [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]
» [Complete] Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]
» [Complete] Redzz02's Haspin Build [2018 Build-Off Entry]
» [Complete] Mr.Modified's Craftsman HE [2018 Build-Off Entry]
» [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2018 Archive :: Finalist Archive-
