 [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]
TheCollector
Dave 007
Dave.MTD
22 posters
Go to page : Previous  1 ... 15 ... 27, 28, 29, 30  Next
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Empty
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeAugust 28th 2018, 12:40 am
Yikes.... 3 months left.  I need to wrap this tractor up!  I think I just pulled the trigger on the last parts for the rig....
Crosses fingers!
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeAugust 30th 2018, 9:28 am
Ugh... this engine is still LEAKING!
I hate to say it, but I think I will go to my backup engine.  While I have this engine off, I will look it over.  I fear a crack at the base of the jug.  The backup is less HP but has more than enough power for my build!
LOL, 3 months left and the whole front end will be torn apart!
Pix to come.  Work won't let me upload.
Edit from phone:
Backup engine...
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 08301811
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Sig115PROJECTS:
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Sig214[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Sig314
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeAugust 30th 2018, 6:00 pm
Nice backup engine, but I would put the one you have and look it over really closely and go from there.
Front end being torn apart? Why?
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeAugust 30th 2018, 9:15 pm
I plan on going over it pretty well once I have it up on the work bench with good lighting.  Like I said, I fear there may be stress fractures where the jug meets the inner block.  If so, I have another OPPY that is a parts engine that I can build up into a good engine.
Torn apart....   Shocked
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Giphy
Lets just say I am pulling a similar stunt that I did with the 2017 build-off machine.  All will be revealed later.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeAugust 30th 2018, 9:22 pm
I think you're really gonna rack in the votes with this next modification you have planned Mighty.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeAugust 30th 2018, 9:35 pm
Do you know something we don’t know? Spill it! We have WAYS of making you talk mister!
lol!
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeAugust 30th 2018, 9:49 pm
I don't know if I will  rack  in many if any votes with my final mods.  lol!
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeAugust 31st 2018, 12:02 am
Well the 18HP is done...
1st bad... the one that can be fixed easily.   I got everything disconnected from the engine and drained the oil.  Immediately, I figured out one issue.  It was full of GAS!  The crank had 3x the amount of fluid in it.  I'm thinking, thats an easy fix, clean the carb, maybe carb kit.  Just make sure the needle is seating.  OR, it could be some of the gas that didn't burn off while on one cylinder.  I would think it would blow that out.  OR, worst case, the crank vent was sucking gas from the fuel pump?  (Possibly the latter due to further inspection)
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 08301812
I didn't even get it on the work bench before I seen some issues before I took the engine off since I had a bunch cleared away.  First, oil coming out the governor.  Probably due to blow-by.  I could see some oil leaking from under the lower cylinder.  Possibly further investigation there as it is not coming from the valve cover.  Need on bench and take off tins.  Now for the kill shot.  I saw another leaking location below the valve cover on the high side.  I wiped it off to find this little bugger.
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 08301813
Yep, that  is about a 3/4 inch long crack in the block.  It had quite a bit of leak from this location.
SO....
I'll put the backup engine in.  This one will now become a parts engine.  I do have another oppy that was my parts engine, but I will use this one to build that one back up.  The other needs a coil, starter, and ALL the intake parts.
There you have the most current update on KAL.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeAugust 31st 2018, 7:15 am
Just throw some JB weld on that crack
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeAugust 31st 2018, 8:05 am
LOL, i actually thought about that for a few minutes.  Smile
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeAugust 31st 2018, 10:31 am
Not like it’s stressed. Likely what caused it was the excess oil slapping the side of the crankcase
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeAugust 31st 2018, 9:31 pm
Is your fuel tank above your carb?
That's crack looks pretty small like a jb weld fix would work pretty well.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeSeptember 1st 2018, 12:17 am
Tank is below carb and a shut off.
I'm totally with a
So much oil everywhere that I cannot figure out how and where this is leaking outside.  Good news, the crack didn't turn out to be a crack once I got it up on the table.  Just a casting mark.  I really don't see anything wrong with this engine at this time except...  I will say one of the head's bolts don't seem to torque to spec... I fear they are stripped or I am just too cautious.
SO....
I am going to go ahead with the engine swap.  Leave this engine up on the table and maybe go through the engine top to bottom for use later.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeSeptember 1st 2018, 1:20 am
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 08311810
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeSeptember 1st 2018, 9:19 am
It wasn't a crack.  Turned out to be a casting mark.  [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 2731072446
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeSeptember 1st 2018, 8:50 pm
I'd look the engine you're about to swap in really carefully first.
Maybe you could clean up the old engine, then put it back on your engine test stand to look for where the oil is coming from.  Hey there's plenty of time in the build off to fix it if it's something simple.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeSeptember 1st 2018, 10:54 pm
The engine I am putting in I was using until June in another machine.  It ran well and had a lot of power.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeSeptember 2nd 2018, 9:21 am
That's great that you already have hours of testing with it.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeSeptember 2nd 2018, 11:22 am
... and it does not leak oil.  LOL
I probably just jinxed myself.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeSeptember 2nd 2018, 12:18 pm
OK, I was hoping to work on this thing today, but it is just to darn hot and sticky outside.  I have worked on this thing with it was 100f out.  Today was already 88f by 9am with dewpoint of about 75.  Needless to say it is a bit thick out there.  I'll hold off.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeSeptember 3rd 2018, 11:40 pm
Finally got to work on Kal this evening.  Started ripping some stuff off the monolink and creating some new brackets.   Man, if i would practice and do this more often, I think I might could get a hang of this welding thing.  Now to get some straighter welds.  LOL
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 09031810
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeSeptember 8th 2018, 6:59 pm
So everything I have done in the past month was a bust....  I think I am making some new progress, but it looks like a reset so to speak.
YIKES!
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 09081810
My goal is to make this thing as safe and solid as I can.  I had gotten faster messing with the old engine and had started to deal with a death wobble that I did not like.  Also, the steering had gradually got worse with steering slop.  These are issues I am working and in the process I have extended the front axle out another few inches.  I am hoping this will also help with better shock attachment.  We will see how this all folds out.  Also, I seem to have lost the knob to my winch free spool.  It just so happened to be the same size as an air breather nut for a briggs opposed.
Hoping this thing goes back together nicely
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeSeptember 8th 2018, 8:46 pm
Sounds like you have some suspension and steering geometry issues you are sorting out.  Where was the steering play coming form?
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 28 Icon_minitimeSeptember 8th 2018, 9:13 pm
I have it pretty much worked out now.  I just need to bolt it back together and I am going to fab up a new front bumper.  It was good, but I was not happy with the "basket" around the grille.  The new one I have designed up will eliminate that basket for the shocks.  I chose this tractor because I like the looks of it... I hate covering it all up!
As for the steering slop, it was due to the universal I replaced the rag joint with.  Also, the plastic bushings in the gears was worn down.  I was going to make a sort of steering brace but that would only take out a little slop.
My biggest issue right now would be to find some 4 inch angle to fab up the new sub-structure for the suspension which will no longer be straight up and down. Also for the bumper. I may be able to get away with 3 inch which is easy to find.
Page 28 of 30Go to page : Previous  1 ... 15 ... 27, 28, 29, 30  Next
» [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]
» [Complete] Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]
» [Complete] Redzz02's Haspin Build [2018 Build-Off Entry]
» [Complete] Mr.Modified's Craftsman HE [2018 Build-Off Entry]
» [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2018 Archive :: Finalist Archive-
