| [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] | |
+18TheCollector MatthewD CraftsmanQuad19 SebastianAlbrecht Buck TheBeal RichieRichOverdrive Dave 007 mrshaft696 Crazy_Carl Dave.MTD Doug prancstaman AllisKidD21 biggasmowers Double W Cross Ranch muckmudd MightyRaze 22 posters |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5093 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] July 28th 2018, 10:37 pm | |
| Thanks... I ended back where I started in a way with the exhaust. Duals out the back, but this time the pipe is bent around things like the axle, footpads, and such. I don't have pix at this time. I'll take some monday as I have all day events tomorrow to take them. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] August 12th 2018, 2:13 am | |
| Doing some compression tests because of some power loss.
Kal - 18hp Oppy 63 psi and Leak down passed (lack of power). Red- 17hp Oppy 78 psi no leak down tested (Lots of power). Squatch - 16hp oppy 59 psi no leak down (Lots of power).
Doing some research, Briggs does not give compression values but recommends leak down tests. I've read people getting anywhere between 50-100psi compression running good.
I'm thinking now that I may need to look into the carb. Maybe a good cleaning. Runs good, but has a bog down on mashing of the gas. Before I take it apart, I will try some other things like new gas, and re-adjust low end jet. I think I can do that on this carb. Also a new set of plugs. I had one busted that was arching, so I do have an older set in right now.
Other things to check or have checked.
Gas cap is venting well. Maybe replace the fuel filter? | |
muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3558 Posts : 825 Location : In the shop
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] August 12th 2018, 2:36 pm | |
| - muckmudd wrote:
- That's a pretty vague compression range, that's surprising.
That was my thought. If I had a good bench belt sander I thought about shaving the head a bit, but I do not have that. Maybe a piece stuck to the work bench but that might take a while. LOL | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] August 12th 2018, 6:27 pm | |
| OK... What a cluster.... 1st, that busted spark plug from little over a week ago. 2nd, I was actually running out of gas (pulling another @alliskidd21) it was sucking in a lot of air bubbles. 3rd, checked the spark. One side was weak and the other side was non existent. I swapped the plugs and those conditions followed those plugs. (They were the old plugs from the engine that I did not toss). Pulled the plugs from my spare engine. I was shocked they were not black, but clean with a little white. They have been in that engine for 3 years and running regular up till last year. Checked spark and it was bright blue. Phew! Not the coil! I fired it up and it was back to being perky again. It will lean me back in the seat again on accelleration. I just need to adjust that idle jet a little. It is 2 turns out. I'd like to take it back down to 1.25-1.5 turns and see what happens. So in short my engine is back in order in the power dept. Now I can work on some things like maybe some steering slop. | |
Crazy_Carl Veteran Member
Buck Member
Join date : 2017-11-01 Points : 2879 Posts : 282 Location : Eastern Ontario
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] August 22nd 2018, 7:55 pm | |
| Thanks!
Yeah that is my remote to the winch.
I need to look into finishing this thing up. Per rules, I can call it complete, but there are a few things that I really want to get done. May need to sink a little $$ into it to wrap it up. | |
Age : 23 Join date : 2018-02-27 Points : 3843 Posts : 1299
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] August 23rd 2018, 1:43 pm | |
| So, the wife and I are thinking about making some changes with our vacationing in the future. Hopefully starting next year. With these changes, the likelihood of taking Kal or Red with us is pretty good. With that in mind, I will probably change the exhaust "AGAIN" at some time to be sure that I can meet Sound and USFS approved Spark Arresting ordinances in most states. Another thing I may need to look into is registering it as a UTV/ATV vehicle. Unlike some of our NE friends here in ATLTF, to my knowledge Oklahoma and many central and midwest states it would not be required. Funny, I started this build to just be a fun mud mower, has started evolving into a full on Rec vehicle. | |
