| [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] | |
+18TheCollector MatthewD CraftsmanQuad19 SebastianAlbrecht Buck TheBeal RichieRichOverdrive Dave 007 mrshaft696 Crazy_Carl Dave.MTD Doug prancstaman AllisKidD21 biggasmowers Double W Cross Ranch muckmudd MightyRaze 22 posters |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] September 8th 2018, 9:13 pm | |
| I have it pretty much worked out now. I just need to bolt it back together and I am going to fab up a new front bumper. It was good, but I was not happy with the "basket" around the grille. The new one I have designed up will eliminate that basket for the shocks. I chose this tractor because I like the looks of it... I hate covering it all up!
As for the steering slop, it was due to the universal I replaced the rag joint with. Also, the plastic bushings in the gears was worn down. I was going to make a sort of steering brace but that would only take out a little slop.
My biggest issue right now would be to find some 4 inch angle to fab up the new sub-structure for the suspension which will no longer be straight up and down. Also for the bumper. I may be able to get away with 3 inch which is easy to find. | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5329 Posts : 2561 Location : Rochester, New York
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] September 8th 2018, 9:48 pm | |
| The Lowes here near my house has a good supply of metals and they keep it in stock. Lots of farmers around that use it. One good thing about being in a farming area out here. Way better than the TSC. The TSC metals also seem to be thinner and melt easy on welding. Oh, one more thing added to that geometry thing. I realized my panhard bar was in the wrong. It was not centered well. I'm sure that messed with some flexing. | |
Age : 23 Join date : 2018-02-27 Points : 3842 Posts : 1299
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] September 9th 2018, 9:11 am | |
| Man I hate that.... In my case a few weeks ago was... I worked all day just to realize my thoughts all day was wrong and I had to tear it all back apart. This time it's working well. I have the monolink attached again, I just don't have the front side attached yet. This will probably be the last pic between now and finish. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] September 12th 2018, 9:35 pm | |
| Little welding practice. I started off worrying about heat penetration, then working with the molten puddle and such... still learning and getting the feel for things. This is my latest playing around! | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5092 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] September 12th 2018, 11:52 pm | |
| Blue/grey is a good color on the back side. Yup, the speed is the hardest part on stick, well for me anyways. I lean the rod backwards of the direction I'm going to push the puddle back to get the ripples needed (laying dimes) It's hard for me because you need to have the tip that is welding to do tiny circles while the rod is getting shorter. Need alot of amps to, just to start the weld or the rod gets stuck on the part and shorts out the welder. The parts you did in the pic, what was the amps at? I would thing you would need at least about 100 amps for that, for a clean easy start and good penetration. | |
mrshaft696 Established Member
Join date : 2016-07-10 Points : 4055 Posts : 870 Location : Phillydelphia
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] September 28th 2018, 11:02 am | |
| Some minor tweaks, I fixed it where I can remove the hood and grill now without removing my new front end mounts and extension. That was quite a pain as I put my exhaust on last after rebuilding the front. The criss-cross pipes go on MUCH easier with the new front end. Last tweak before 100% is to hopefully create some kind of resonator for my exhausts to deepen the tone a little more. Hoping to have pix and maybe final video this upcoming month! | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] October 1st 2018, 3:33 pm | |
| DONE!I'll have the video up hopefully soon (we are expecting another flooding rain this weekend) to complete RULES of the build. Plan is to do some recording then, I do have a backup location planned, but riding there isn't quite exciting. I do have some time to record, but I will need some edit time too. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] October 2nd 2018, 12:36 pm | |
| So, outside of changing out the front, I went ahead and moved to my backup engine. Even though it is 3 HP less than the 18 HP I was going for, it seemed like it had 5 more HP. Very snappy and a lot more powerful. | |
Dave.MTD Member
Age : 24 Join date : 2017-01-11 Points : 2906 Posts : 37 Location : Hamilton, Ontario
Age : 25 Join date : 2016-07-10 Points : 8583 Posts : 5190 Location : Ontario Canada
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] October 2nd 2018, 1:42 pm | |
| Yeah she looks fantastic. I have a feeling there's something new with the front axle that you're not showing us Mighty, I'm not gonna rack my brain trying to figure it out though. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] October 2nd 2018, 1:44 pm | |
| - Dave.MTD wrote:
- New profile pic looks awesome Mighty. Did I miss you putting new shocks on Kal? I don't recall pics but those new ones look sweet!
Good eye. LOL That didn't take long. Since the beans have been somewhat spilled. Yeah the whole front was changed out. Before... - Code:
[img]http://mightyraze.com/wp-content/gallery/pops/37140315_2597264620498183_1091241419139448832_n.jpg[/img] After... - AllisKidD21 wrote:
- Yeah she looks fantastic. I have a feeling there's something new with the front axle that you're not showing us Mighty, I'm not gonna rack my brain trying to figure it out though.
Up till today, @AllisKidD21, was the only one with the full update. No more rack ing brains and getting o-pinions LOL Changed made:
- New front frame
- new monolink rebuild
- new bumper
- added 2nd NiLight
- new shocks
- exited exhaust out in front of tires.
- changed engines
- new rack-n-pinion steering
- ammo box trunk on the rear rack
- horn
- Dual USB 2.1 amp charging port
Last edited by MightyRaze on October 22nd 2018, 4:55 pm; edited 1 time in total | |
