| [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] | |
+18TheCollector MatthewD CraftsmanQuad19 SebastianAlbrecht Buck TheBeal RichieRichOverdrive Dave 007 mrshaft696 Crazy_Carl Dave.MTD Doug prancstaman AllisKidD21 biggasmowers Double W Cross Ranch muckmudd MightyRaze 22 posters |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] April 22nd 2018, 11:38 pm | |
| If you get a minute Mighty, could you maybe grab a couple pictures of how you changed out that rag joint for a U-joint? I wanna do that as well on my LT11 when I eventually build it. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] April 23rd 2018, 12:02 am | |
| - AllisKidD21 wrote:
- If you get a minute Mighty, could you maybe grab a couple pictures of how you changed out that rag joint for a U-joint? I wanna do that as well on my LT11 when I eventually build it.
I have not done that yet. I'll definitely get some pix when I do it. - RichieRichOverdrive wrote:
- Looks good mighty. Does your front axle have any positive caster? It looks like it does. She might not autocenter so well.
I ended up with about 1 degree negative. Wasn't too happy about that, but we'll see how it goes. Didn't want to scrap and do it over just yet. If it was to sink about 1 inch in the front it would be 0 caster. | |
Age : 23 Join date : 2018-02-27 Points : 3843 Posts : 1299
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] April 23rd 2018, 10:48 am | |
I have not done that yet. I'll definitely get some pix when I do it. Oh sorry, for some reason I read your post thinking you said that you already did it, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 20 Join date : 2017-06-09 Points : 5489 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] April 23rd 2018, 5:38 pm | |
I was looking last night and I was wrong. It has about 1-2* positive caster. - Double W Cross Ranch wrote:
- That should work, but I'd try to keep away from hardened metal.
I need to check the shaft diameter and I would prefer an actual steering u-joint that I can attach via set screw etc. | |
Crazy_Carl Veteran Member
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] April 23rd 2018, 11:14 pm | |
| Zinc isn't too bad. Still need to measure my steering shaft on the frame. I was thinking of welding a socket in my tube on the steering shaft. Still wondering if I want to do something completely else with it.... In other news.... I was thinking of doing the black like I did with Lil Red, but I think I like the solid blue way better. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] April 24th 2018, 7:10 am | |
| Blue sure does fit your theme perfectly. I thought those U-joints were zinc plated not made from zinc. I would buy a steel one if I were in your shoes. This is going to be your main tractor so its steering is really important. I like your socket idea too. That can be done for cheap. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] April 24th 2018, 8:45 am | |
| I did measure out the little shaft last night and it was 5/8. I was thinking I could square off the head and attach (and weld) one of those "black" impact universals to it. I have also found that a 7/8 socket fits nicely into the bottom of my steering column. Maybe drill out the snap in bearing and I could put a release pin in there possibly so I can still remove the steering if needed. Or drill out the other side. It may be easier.
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] April 24th 2018, 12:56 pm | |
| Kind of a half and half thing. Weld the U joint to the steering gear shaft on the frame side. Then the steering wheel side I would set it up with a release pin so I can still disassemble from that side. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] April 24th 2018, 4:21 pm | |
| Loving the look of the blue grille Mighty! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] April 24th 2018, 11:07 pm | |
| THanks! I am waiting for some PAR36 LED headlights to come in so I can finish wiring them. I need to hit up TSC to find a small round taillight. I think they are like 3 bucks. I may have to go to town and find an LED one should they not have an LED one. Here is that thought I had with the universal. That socket will be jammed into that steering shaft and welded. Then maybe drill out a hole for a pin where that connects to the universal that will be welded to below. | |
